Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Posted: Sun Jan 19, 2020 2:06 am Post subject: Help to ID this distributor |
Hi everyone, I have this distributor on the '56 engine that came with my '54 oval. I was thinking of putting it on my 1.6 engine. The problem is that the ID plate is damaged behind the br code, the number after it is missing.
Do you know guys how can I know if it is a br8 or a br25?
There are some photos
_________________ '54 vintage speed beetle slow project
Visit my workshop site and leave a like:
https://www.facebook.com/talleresalacreu/ |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76900 Location: Sneaking up behind you
Posted: Sun Jan 19, 2020 5:25 am Post subject: Re: Help to ID this distributor |
VJ4BR18
At first i thought it was a VJ4BR8 as the VJ4BR25 has the "knob" on the front and the VJ4BR8 has it on the left. But I can see it has a double stacked weight under the breaker plate and the second weight also looks double stacked. That would make it a VJ4BR18.
The VJ4BR18 has a 2 screw condenser mount while the VJ4BR8 has a single screw.
The VJ4BR18 has 32* advance which is way too much for for a VW 36hp engine. The VJ4BR8 has 17* and the VJ4BR25 has 22* which are both VW distributors.
VJ4BR8 - single condenser screw
VJ4BR25 - knob in front
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Jan 19, 2020 5:54 am Post subject: Re: Help to ID this distributor |
Thanks Glenn!
So I shouldn't use it on a vw engine… Will it work on a performance vw engine or will it be too much for it too? _________________ '54 vintage speed beetle slow project
Glenn Mr. 010
Posted: Sun Jan 19, 2020 8:03 am Post subject: Re: Help to ID this distributor |
Albertoprop17 wrote: |
Thanks Glenn!
So I shouldn't use it on a vw engine… Will it work on a performance vw engine or will it be too much for it too? |
It's for a Porsche 356, don't use it on a VW, even a hi-po.. it has too much advance.
Sell it and get a VJ4BR25 or a 010. _________________ Glenn
Member #1009
#BlueSquare |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Jan 20, 2020 6:17 pm Post subject: Re: Help to ID this distributor |
If you do decide to sell it you will get more money for it by replacing the badge or at least including it with the distributor unattached when you sell it. You can find a BR 18 badge at Stoddard Porsche parts. In order to properly install the badge the entire distributor must be disassembled. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Glenn Mr. 010
Posted: Mon Jan 20, 2020 7:44 pm Post subject: Re: Help to ID this distributor |
The Stoddard (right) is pretty close to the original (left).
You don't need to take it apart, you can carefully remove the hollow rivets and install the new badge.
Member #1009
#BlueSquare |
Posted: Tue Jan 21, 2020 9:52 am Post subject: Re: Help to ID this distributor |
I've found that driving the badge pins from the inside out leaves the head in good condition. _________________ Roads Scholar &
Glenn Mr. 010
Posted: Tue Jan 21, 2020 11:21 am Post subject: Re: Help to ID this distributor |
I just install new ones. _________________ Glenn
Member #1009
#BlueSquare |
