Ouch! My (diesel injection pump) Nipple Broke!!
rsvp
Location: Annapolis, MD(but usually travelin' somewhere else)
rsvp is offline
PostPosted: Sun Jan 19, 2020 6:06 pm    Post subject: Ouch! My (diesel injection pump) Nipple Broke!! Reply with quote
Hi all
The nipple on the vacuum module on my JX injection pump broke off. Whats my best way of fixing this? (Im thinking of J-B Weld, but not sure if itll hold.
Thanks again
Steve
campism
campism is offline
PostPosted: Sun Jan 19, 2020 6:17 pm    Post subject: Re: OUCH! MY NIPPLE BROKE!! Reply with quote
I would not trust JB Weld for that fix, not without reinforcement. Not familiar with the engine but have learned what JBW can't do.
I broke the nipple end off a fuel pump plastic piece and used tiny brass tubing as a sleeve JBWed on the inside, then wrapped the outside with fine mesh and slathered JBW on it. When dry I installed fuel line with a clamp but that piece is now my emergency spare that I hope will work properly if needed.
'87 Westy in Wolfram Grey Metallic
Sodo
Sodo is offline
PostPosted: Sun Jan 19, 2020 6:45 pm    Post subject: Re: OUCH! MY NIPPLE BROKE!! Reply with quote
I agree with campism.
That kinda looks soldered.
Is that possible?
Maybe it's silversolder?
I have a hard time believing an OEM would solder, but...
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
One apple every 8 hours will keep 3 doctors away - B Kliban
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sun Jan 19, 2020 6:49 pm    Post subject: Re: OUCH! MY NIPPLE BROKE!! Reply with quote
Cut new threads for a brake bleeder or other nipple?
I'd wonder how to keep metal shavings out from inside of that part though.
I agree. Looks like it might've been silver brazed.
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
Sodo
Sodo is offline
PostPosted: Sun Jan 19, 2020 7:02 pm    Post subject: Re: OUCH! MY NIPPLE BROKE!! Reply with quote
Thread a brake nipple in, then JB-weld a big structural fillet all around the brake nipple?
Could put it right at center, then cover the original nipple hole with JBweld .
If that's a diaphagm, it probably wont be bothered by little bits from drilling & threading, and most might shake out..
Drilling thru the membrane would be detrimental. Shocked
JB weld can be done like this.
Epoxy a steel tube on, with a structural blob for "strain relief".
Maybe steel brake tubing (or copper tube)?
Steve M.
Steve M. is offline
PostPosted: Sun Jan 19, 2020 7:06 pm    Post subject: Re: OUCH! MY NIPPLE BROKE!! Reply with quote
Recommend brazing if you can find someone willing to work on something that small.
Epoxies are not going to cut it.
old_man
old_man is offline
PostPosted: Mon Jan 20, 2020 1:59 am    Post subject: Re: Ouch! My Nipple Broke!! Reply with quote
New one. Pricey.
My only suggestion is to keep in mind that the hose doesn't have to go to that exact spot. You could patch that hole and drill a cleaner hole elsewhere. That area shouldn't see more than 15psi.
T3messie
T3messie is offline
PostPosted: Mon Jan 20, 2020 4:32 am    Post subject: Re: Ouch! My Nipple Broke!! Reply with quote
Title is not very catchy to a diesel vanagon enthusiast Rolling Eyes .
Is the diaphragm intact?
rsvp
rsvp is offline
PostPosted: Mon Jan 20, 2020 6:35 am    Post subject: Re: Ouch! My Nipple Broke!! Reply with quote
Hi all,
Thanks for the ideas... I'll thread it for a brake bleeder nipple and see how that works.
Ill keep you appraised!
regards,
Steve
ZsZ
ZsZ is offline
PostPosted: Tue Jan 21, 2020 1:28 am    Post subject: Re: Ouch! My Nipple Broke!! Reply with quote
its brazed (hard soldered) by factory
1.9 MTdi Multivan (ex Caravelle)
Van since 2006, engine since 2008
rsvp
rsvp is offline
PostPosted: Tue Jan 21, 2020 5:07 am    Post subject: Re: Ouch! My Nipple Broke!! Reply with quote
NIPPLE FIXED!! Laughing
Thanks everyone
I ended up threading a brake bleeder nipple on, and sealing it with JB-Weld. It seems to be holding a vacuum when I pull it open by hand.
Im not sure of the longevity of the repair, but well see.
Thanks again,
Steve Laughing
