2.1 take 2
aplusbisme
aplusbisme is offline
PostPosted: Mon Jan 20, 2020 6:56 am    Post subject: 2.1 take 2 Reply with quote
Picked up another engine core (thanks for recommending Valley Westys!) in hopes of having something better to work with than my ďrebuiltĒ one. The heads look much better. There is some pitting though none of it is close to the water jacket seal. A small crack between the valves which I havenít measured yet. Iíd like to clean it up some more. What do you recommend for cleaning the heads? The cylinders are noticeably better than the last ones with clearly visible crosshatching. Pulled the other head last night but havenít cleaned it up at all. Thanks for any feedback
dabaron
dabaron is offline
PostPosted: Mon Jan 20, 2020 7:26 am    Post subject: Re: 2.1 take 2 Reply with quote
the second engine looks way better.
do you plan on splitting this engine's case? how many miles are on it? i would not run heads with cracks between the valves, it's only going to get worse so why not get a pair of tencentlife heads.
1990 Vanagon GL
1991 Vanagon GL Camper
Seems like the Venn diagram of "poorly maintained Vanagons" and "unreliable Vanagons" is a circle.
-Paulbeard
Your bringing the atomic Bomb of fact to a knife fight of trivia.
-Abscate
aplusbisme
PostPosted: Mon Jan 20, 2020 9:47 am    Post subject: Re: 2.1 take 2 Reply with quote
My plan is to not split the case on this one. Not sure how many miles were on it but the shop I bought it from said it ran well. Iím not opposed to getting new heads if that makes the most sense. At that point rings? Dehoning cylinders? Iíd like to split the case on the first engine and do a thorough rebuild as money and time allow, so Iíd like to get this one running and hopefully get some miles out of it. How does one get in touch with tencentlife?
MarkWard
MarkWard is offline
PostPosted: Mon Jan 20, 2020 9:48 am    Post subject: Re: 2.1 take 2 Reply with quote
Easy Off oven cleaner is a nice DIY carbon dissolver when you don't have an arsenal of tools etc to clean carbon off.
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper Syncro conversion.
aplusbisme
PostPosted: Mon Jan 20, 2020 9:50 am    Post subject: Re: 2.1 take 2 Reply with quote
Oven cleaner and scotch bright pads?
IdahoDoug
IdahoDoug is offline
PostPosted: Mon Jan 20, 2020 10:12 am    Post subject: Re: 2.1 take 2 Reply with quote
Careful with scotchbright pads on aluminum. People often think "these are plastic, how abrasive can they be?" but they should be treated the same as sandpaper, not plastic.
On the head cracks, I would not be worried. Every head I've seen and used has had a crack on one side or the other and it's so common VW actually has a spec for it. This engine looks pretty good visually but I'd be curious about the oil pressure, which you'd only know if the seller knew or once you start it up.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Mon Jan 20, 2020 10:13 am    Post subject: Re: 2.1 take 2 Reply with quote
redshiftt.com
'87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '65 Split Deluxe 'Henry', '63 Notch
aplusbisme
PostPosted: Mon Jan 20, 2020 10:20 am    Post subject: Re: 2.1 take 2 Reply with quote
Thanks. So what to use if itís not scotch bright? Iíve searched samba but havenít found anything. I havenít measured the crack yet but I am aware there is a tolerance. The mechanic said it had good oil pressure though Iím replacing the oil pump since Iím already in there.
aplusbisme
PostPosted: Mon Jan 20, 2020 11:03 am    Post subject: Re: 2.1 take 2 Reply with quote
dabaron
dabaron is offline
PostPosted: Mon Jan 20, 2020 11:13 am    Post subject: Re: 2.1 take 2 Reply with quote
i used oven cleaner and the blue scotch brite pads, they are non-abrasive and worked very well.
1990 Vanagon GL
-Paulbeard
-Abscate
aplusbisme
PostPosted: Mon Jan 20, 2020 5:12 pm    Post subject: Re: 2.1 take 2 Reply with quote
Left head. No cracks. Not too much pitting around water jacket seal. Getting the carbon build up off ainít easy. Havenít tried the oven cleaner yet. Maybe I should be putting more elbow grease on it?
?Waldo?
?Waldo? is offline
PostPosted: Mon Jan 20, 2020 8:34 pm    Post subject: Re: 2.1 take 2 Reply with quote
It's interesting that a core engine is in better condition than a supposedly recently rebuilt one. The big question is, are you going to swap over the hand-planked rods?
dabaron
dabaron is offline
PostPosted: Mon Jan 20, 2020 8:53 pm    Post subject: Re: 2.1 take 2 Reply with quote
pure gold. this and the rods.
1990 Vanagon GL
-Paulbeard
-Abscate
aplusbisme
PostPosted: Tue Jan 21, 2020 4:46 am    Post subject: Re: 2.1 take 2 Reply with quote
The hand planked rods are a collectors item now. Anybody interested? How about these heads though? Definitely better but usable?
dabaron
dabaron is offline
PostPosted: Tue Jan 21, 2020 6:13 am    Post subject: Re: 2.1 take 2 Reply with quote
what is your end goal? are you hoping to put the engine together quickly and have it back in and running while you do a for real rebuild of the original "rebuilt" engine?
i think you should rebuild the 2nd engine with tencentlife heads and consider that time and money as insurance down the road. that "rebuilt" is a waste of time. you already know it's a basket case.
1990 Vanagon GL
-Paulbeard
-Abscate
mikemtnbike
mikemtnbike is offline
PostPosted: Tue Jan 21, 2020 6:31 am    Post subject: Re: 2.1 take 2 Reply with quote
So yeah, in best case scenario, you get heads from tencent and work with your "new" core.
If that's not in budget this year and you want to use your van, there's nothing wrong with trying to reuse those heads IMO. I'm running heads that had very small cracks on both sides and pitting that I did the JB Weld repair to; no leaks for over 3 years now.
This also makes sense if, like me, you anticipate putting in a higher power motor at some point in the future; save your money and run what you got until you have the money to get what you want.
1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie"
In an abundance of water, the fool is thirsty.
aplusbisme
PostPosted: Tue Jan 21, 2020 6:54 am    Post subject: Re: 2.1 take 2 Reply with quote
My end goal is to do a proper rebuild with my first motor. Iíd like to get this one in and running as quickly as possible. Iíd hope to get 20-30k miles before putting in the rebuilt engine. Not opposed to buying heads from tencent but Iíd rather put that money towards the first motor. Hmmmm????
dabaron
dabaron is offline
PostPosted: Tue Jan 21, 2020 7:02 am    Post subject: Re: 2.1 take 2 Reply with quote
have you split the case on the first engine? that is really going to be the determining factor of your next step.
1990 Vanagon GL
-Paulbeard
-Abscate
aplusbisme
PostPosted: Tue Jan 21, 2020 9:10 am    Post subject: Re: 2.1 take 2 Reply with quote
I have not split the case on engine 1. Thanks for the advice everyone. Much appreciated
dabaron
dabaron is offline
PostPosted: Tue Jan 21, 2020 9:19 am    Post subject: Re: 2.1 take 2 Reply with quote
post the photos of the hand planked rods, we are all on seat's edge waiting.
1990 Vanagon GL
-Paulbeard
-Abscate
