Oil specifications for JX (1.6TD) motor
rsvp
Location: Annapolis, MD(but usually travelin' somewhere else)
rsvp is offline
PostPosted: Mon Jan 20, 2020 8:34 am    Post subject: Oil specifications for JX (1.6TD) motor Reply with quote
I did a quick search and canít find anythingÖ
What did VW recommend for the turbo diesel 1.6 in terms of oil?
I have easy access to Rotella T4, which is what Iíve used on my CS 1.6na motors. Rotella T6 is also available, but itís lower viscosity always concerned me.
Thanks all!
Steve
old_man
old_man is offline
PostPosted: Mon Jan 20, 2020 9:38 am    Post subject: Re: Oil specifications for JX (1.6TD)motor Reply with quote
I'm using the T6 right now because I drive mine in the winter. I'm sure someone will point out that it doesn't have VW505 approval but I, personally, am not overly concerned.
I am curious what you mean by the lower viscosity concerns you? They are both 40 weight at temp (in theory).
?Waldo?
?Waldo? is offline
PostPosted: Mon Jan 20, 2020 10:47 am    Post subject: Re: Oil specifications for JX (1.6TD)motor Reply with quote
The 5w vs. 15w is the cold viscosity. The viscosity at normal operating temperature is 40 for both. In fact due to the more consistent viscosity of the 5W-40, in the hotter ranges of temp, it is likely that it has a higher viscosity which is when it matters most.
VW did not spec 505 for the JX. I forget the C rating but any oil that has a C rating will meet it. Make sure it has a C rating, though.
old_man
old_man is offline
PostPosted: Mon Jan 20, 2020 10:58 am    Post subject: Re: Oil specifications for JX (1.6TD)motor Reply with quote
Interesting, I did not know this. I was going off a sticker found on my valve cover. Hard to see but it says 505. Where that sticker came from I have no idea.
rsvp
rsvp is offline
PostPosted: Mon Jan 20, 2020 11:19 am    Post subject: Re: Oil specifications for JX (1.6TD)motor Reply with quote
The Rotella T65W 40 has a whole lot of meats API service codesÖ All of them prefaced by the letter ďCĒ
?Waldo?
?Waldo? is offline
PostPosted: Mon Jan 20, 2020 11:20 am    Post subject: Re: Oil specifications for JX (1.6TD)motor Reply with quote
I stand corrected. My recollection was faulty.
clift_d
clift_d is offline
PostPosted: Tue Jan 21, 2020 3:39 am    Post subject: Re: Oil specifications for JX (1.6TD)motor Reply with quote
Ideally the JX should be run with a 15W40 Mineral oil with VW 50500 or 50501 specification.
1988 LHD T25 1.6TD Westfalia Club Joker syncro
