New Speedometer Cable Install
Silverghost500
Silverghost500 is offline
PostPosted: Mon Jan 20, 2020 10:58 am    Post subject: New Speedometer Cable Install Reply with quote
I've got a new speedometer cable ready to install. I've got the cable, the grommets, and the circlip. Should I lubricate the cable before installation, and if so what's the preferred lubricant?
1986 Volkswagen Vanagon Westfalia "Von Westy"
Host of the YouTube Channel Von Westy
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA
goldtooth
goldtooth is offline
PostPosted: Mon Jan 20, 2020 11:31 am    Post subject: Re: New Speedometer Cable Install Reply with quote
A new cable from a reputable vendor comes pre-lubed.
nate
1987 Westy RJE 2.2L WBX
khughes
khughes is offline
PostPosted: Mon Jan 20, 2020 11:44 am    Post subject: Re: New Speedometer Cable Install Reply with quote
Make sure you can easily rotate the cable, by hand, before installation. If there are any "catches" or hard to turn spots, don't use it. Went through 3 last time I replaced mine to get one that ran smoothly. Any catching or binding mean bouncy speedo. All with a rebuilt speedo from GW - that works perfectly BTW and is adjusted for my taller tires. All of mine were purchased from our well known reputable vendors, but I don't think there are too many reputable manufacturers out there anymore.
'86 Westy GenV Turbo (Marvin)
Silverghost500
PostPosted: Mon Jan 20, 2020 12:27 pm    Post subject: Re: New Speedometer Cable Install Reply with quote
This is what I ordered. Thanks for the tip of checking for binding before installation!
khughes
khughes is offline
PostPosted: Mon Jan 20, 2020 1:33 pm    Post subject: Re: New Speedometer Cable Install Reply with quote
Doesn't look like any of the brand I got, based on the packaging. On one of mine the collar where the speedo connector was swaged onto the cable was a bit oval. So it bound on the squared corners of the "drive" part of the cable. The other I don't know, it just bound up unless it was perfectly straight, and then wasn't that easy to turn. Lubing didn't help. Finally my last one from VC was smooth turning by hand, and with a cordless drill it was smooth and quiet. Been fine for 2-3 years now but just about ready for a re-lube (fine around here, but when I go to the coast in the cool and damp, it grumbles for a while when I first start driving).
