Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Posted: Mon Jan 20, 2020 2:25 pm Post subject: Getting the axel nuts off is a snap... Help! |
Think this should be separate also, not lost in Ruby's build thread (really need to update).
Seems getting the rear axel nuts off is a snap...
Proto
SK Tools
I only have a 3/4 inch drive breaker bar, so need the adapter. I am then using a six foot piece of pipe and laying onto it, with my 185 pounds (which is deceptive as vary from 31 to 33 inch waist). Been many years since had to do science math, that is 1,100 foot pounds, so am I pushing the adapters too far?
Looked at the torque multiplier and only comes half inch drive. Not sure help, thus why here, as rather not waste $100 if no point.
Has anyone had this much trouble and if so, how does one get them off when this stuck?
Thank y'all in advance! _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation |
nreslifer Samba Member
Posted: Mon Jan 20, 2020 2:44 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Torque Meister |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Mon Jan 20, 2020 3:15 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Doesn't matter what size drive you use as long as it terminates in an 11mm socket... Anyone tried 1/4" ?
Then you undo those nuts with one hand while whistling a merry tune. _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Mon Jan 20, 2020 3:19 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Get a 3/4" drive 36mm socket. And don`t use the adapter. _________________ If you`re going to do something, do it right. |
cbeck Samba Member
Posted: Mon Jan 20, 2020 3:21 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Isn't the torque miester only available in 1/2 drive? Don't 1/2 ratchets grow on trees? _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
74 Thing Samba Member
Posted: Mon Jan 20, 2020 3:28 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
You need a quality 3/4 to 1/2 inch adapter, or a quality 1/2" breaker bar, or a quality socket that you can use with your current 3/4" breaker bar, or get the Torquemeister. |
Zundfolge1432 Samba Member
Posted: Mon Jan 20, 2020 3:32 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Ace hardware sells and warranties craftsman tools now. Torque multiplier is what you need. I use 3/8 drive ratchet and torque multiplier to install flywheels no problems. |
Posted: Mon Jan 20, 2020 3:40 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Zundfolge1432 wrote: |
According to the information for the multiplier, "24FT LBS = 216 LBS", meaning, must use my pipe on a breaker bar.
Good to know Chinese Craftsman is still available, appreciated. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Mon Jan 20, 2020 4:04 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Adriel Rowley wrote: |
That is different than the others. Link? |
Common must-have VW tool; all the parts houses should have them. A worthy investment.
https://vwparts.aircooled.net/Flywheel-and-Brake-Drum-Torque-Tool-Kit-36mm-p/torque-tool.htm _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
bad91teg Samba Member
Joined: February 13, 2007 Posts: 473 Location: florida
Posted: Mon Jan 20, 2020 5:04 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Posted: Mon Jan 20, 2020 5:18 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Bryan67 wrote: |
Get a 3/4" drive 36mm socket. And don`t use the adapter. |
Just wanted to confirm that would work, since need at least 1,200 foot pounds. |
1200 foot pounds? Where did you get that number from? More like 300 _________________ If you`re going to do something, do it right. |
Posted: Mon Jan 20, 2020 5:21 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
A final word of caution. Break these loose car on ground I’ve seen people knock a car off jack stands. Not saying you’d do this but someone reading this thread might. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Mon Jan 20, 2020 5:43 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Huh? No. The torque multiplier is a 9x multiplier. The drive accepts an 11mm socket.
If you put 24 ft lbs of torque on the 11m socket you get 216 ft lbs. at the axle nut.
Axle nuts and gland nuts come free easy with an 11mm socket and a standard 3/8" drive ratchet - I have yet to need more leverage than that.
When reinstalling, put that 11mm socket on a torque wrench. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Jan 20, 2020 6:03 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
Bryan67 wrote: |
Bryan67 wrote: |
1200 foot pounds? Where did you get that number from? More like 300 |
Isn't torque force times distance? If not, then what is it?
If is force times distance, I applied at least 185 pounds at a distance of six feet, therefore, at least a half British ton. In other words, the nut does not budge at 1,100 foot pounds, needs more than that. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Mon Jan 20, 2020 6:07 pm Post subject: Re: Getting the axel nuts off is a snap... Help! |
And proper jack stands. Since my Dad used scissor jacks only, thought safe until the Beetle fell of them. Good thing me or the pup wasn't under there!
Further, before going under a vehical, have an idea how to get out. I have hyper mobile joints and somehow wedged myself between the wall and under the vehical. I only got out because my previous Service Dog helped pull me out, otherwise would have been there at least a week if not more. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
