ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Fri Jan 24, 2020 9:39 pm Post subject: Bracket identification? |
I am missing this bracket, what is it called and does anyone have a part # for it?
I believe it’s number 34.
The part circled in red.
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
airschooled Air-Schooled
Posted: Fri Jan 24, 2020 10:13 pm Post subject: Re: Bracket identification? |
That was a bracket designed to take the weight of the heat exchangers and exhaust system off the head studs. It hangs the muffler (72-74) or the exhaust elbow (75-79) from the fan shroud M8 holes.
Stick an M8x1.25 stud in the fan shroud, and make your own bracket out of metal stock from the hardware store. It will cost single digit dollars but add life to the heads and exhaust system. Late setups are a simple bend or two, while earlier exhaust setups require a 90° twist as well as the bends. Use anti-sieze on all the threads, and enjoy keeping your exhaust studs happy while discouraging exhaust leaks.
See you on the road,
www.airschooled.com |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sat Jan 25, 2020 6:25 am Post subject: Re: Bracket identification? |
Originals are difficult to find, as they get rusty even though they are 3mm thick steel, removed and never put back on, damaged, etc.
If you make one, use thick material, as they provide much needed support for a heavy system, and my thinking is that thin material would flex too much or not provide sufficient support.
Part number is 021 256 303B.
asiab3 wrote: |
Late setups are a simple bend or two, while earlier exhaust setups require a 90° twist as well as the bends. |
I have not noticed this, and have put originals on the 72-4/79 style (see pic below), as well as the 75-78 style (like shown in the pic above) without modification or twisting. The bracket mounts at different locations, depending on the exhaust style and possibly the fan housing. Can you explain what you mean?
72-74/79 exhaust style mounting location:
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sat Jan 25, 2020 7:17 am Post subject: Re: Bracket identification? |
hazetguy wrote: |
asiab3 wrote: |
I have the same exhaust setup as in the original picture in my first post, will the bracket you pictured work for my setup? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sat Jan 25, 2020 7:32 am Post subject: Re: Bracket identification? |
Its a pretty simple bracket, what you need to know to make one is the center to center distance for the holes. A tad short is likely better than a tad long. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Apr 23, 2020 4:16 am Post subject: Re: Bracket identification? |
hazetguy wrote: |
asiab3 wrote: |
Thanks for posting those pics, Hazetguy.
I'm wanting to make and install one soon.
Does anyone happen to know what the center-to-center measurement is for that bracket?
Also, is there a similar bracket installed on the right side of the engine? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
busdaddy Samba Member
Posted: Thu Apr 23, 2020 7:45 am Post subject: Re: Bracket identification? |
KentPS wrote: |
Also, is there a similar bracket installed on the right side of the engine? |
The alternator bracket serves two purposes on the RH side. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 23, 2020 2:35 pm Post subject: Re: Bracket identification? |
busdaddy wrote: |
KentPS wrote: |
The alternator bracket serves two purposes on the RH side. |
Thanks once again, BD.
My alternator bracket is rusted off at the bottom connection.
So it must be time to source a replacement. _________________ -Kent-
---williamM |
SGKent Samba Member
