djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Thu Jul 15, 2021 5:16 pm Post subject: Re: The mania deepens: 1991 Full Westy rescue |
djkeev wrote: |
Are we fixing your A/C this year? |
no, 2022. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Mon Jul 19, 2021 10:05 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
painting on a humid day means less than perfect results.
cleaned and painted, not perfect but a good start. i need to do some minor fixing in a few places and give it another coat. overall, worth the 2 hours of work.
before:
after:
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
4Gears4Tires Samba Member
Posted: Mon Jul 19, 2021 10:39 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
Freshly painted grills are so easy to do and make such a difference. That looks awesome. _________________ '87 Syncro
Posted: Mon Jul 19, 2021 5:10 pm Post subject: Re: The mania deepens: 1991 Full Westy rescue |
4Gears4Tires wrote: |
Freshly painted grills are so easy to do and make such a difference. That looks awesome. |
thank you, it is a stupid simple* enhancement.
*offer not valid with 87% humidity in July. _________________ 1991 Vanagon GL Camper
Posted: Mon Jul 19, 2021 5:39 pm Post subject: Re: The mania deepens: 1991 Full Westy rescue |
dabaron wrote: |
these are the remaining "major projects" in order of importance:
overhaul suspension (already paid for)
change out headlights for e-codes, add DRL ($450)
new door cards - add power window relays and relocate switches ($400)
fix failed seam on rear left panel and deal with rusty front ($500+)
hammer out crushed rear right wheel arch and add terrawagen fender flares to hide the sins ($500)
maybe get the a/c working, maybe ($1000+) |
some light house keeping:
-the suspension is almost finished, just need to wrestle with the rear arms to do the bushings.
-converted to rounds for a fraction of the square codes. might wire the DRL, on the fence
-door cards and power window switch mod will be happening in 2022
-body work coming in 2022
-terrawagens in the budget for 2022
-a/c absolutely happening in 2022
of course this all depends on the 68 Beetle and what it needs.
Vanagons. _________________ 1991 Vanagon GL Camper
Posted: Tue Jul 20, 2021 4:30 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
dabaron wrote: |
dabaron wrote: |
Vanagons. |
Here in the East with our short highway sight distances due to curves and hills, DRL isn't really "needed".
Travel West where the horizon 10 miles away is in sight, DRLs are a must have!
Vehicles vanish in the mirages of distance.
Ghia
Vanagon
Beetle
Posted: Tue Jul 20, 2021 5:46 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
djkeev wrote: |
Dave |
I'll go the opposite on that thought. Here in the East where sight lines are short we need every opportunity to see a vehicle as soon as possible. DRLs help a lot in that regard. They are sometimes the first thing I'll notice as a vehicle comes around a corner. _________________ Dave O
The Western Syncro build
Posted: Tue Jul 20, 2021 5:53 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
dobryan wrote: |
I'll go the opposite on that thought. Here in the East where sight lines are short we need every opportunity to see a vehicle as soon as possible. DRLs help a lot in that regard. They are sometimes the first thing I'll notice as a vehicle comes around a corner. |
limited sight lines and dancing in and out of shade with the sun at the right angle, cars can become invisible. for whatever reason, i have had more people cut me off or turn across my path while driving a Vanagon than any other car i've owned.
the Vanagon must be some form of Tardis, because clearly they are larger on the inside given no one seems to be able to see them on the road. _________________ 1991 Vanagon GL Camper
Posted: Tue Jul 20, 2021 6:00 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
dabaron wrote: |
dobryan wrote: |
the Vanagon must be some form of Tardis, because clearly they are larger on the inside given no one seems to be able to see them on the road. |
Definitely Tardis shaped but who knows.
I have the old terrawagon 'fog light' version of DRL's and I really like them. They are not in any way fog lights but they are good DRL's. Come to think of it I do not get cut off very much these days at all.... _________________ Dave O
Posted: Mon Aug 02, 2021 5:42 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
the weather Friday was pretty decent so it was time to freshen up the cladding.
wet sanded both door pieces with a little simple green mixed in.
not perfect, but better then they were.
more wet sanding and then a few coats.
the driver's side was damaged and repaired by a PO. it's not a great fix, but until i want to tackle it, the fresh paint will hide it for now.
before
after - not perfect, but from 10 feet away, it looks great. _________________ 1991 Vanagon GL Camper
Posted: Mon Aug 02, 2021 7:00 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
It's looking better and better. Soon it'll be looking great from NINE feet! _________________ '87 Syncro
Posted: Mon Aug 02, 2021 8:59 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
It's looking better and better. Soon it'll be looking great from NINE feet! |
whoa whoa whoa, let's not get crazy. _________________ 1991 Vanagon GL Camper
Posted: Mon Aug 02, 2021 9:19 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
dobryan wrote: |
Seems to look great when you are lying in a ditch.... |
don't judge me _________________ 1991 Vanagon GL Camper
Posted: Wed Sep 22, 2021 9:28 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
part of the plan for the Westy is to use it for ham radio operating. when i was putting together the 150Ah battery system, i included two 30 amp circuits.
the circuits are wired to a set of Anderson Power Poles next to a set of USB jacks for charging devices.
the vent plate came from CamperVanCulture.com in the UK and included the USB jacks and a jack for a 12V receptacle which i replaced with a PowerWerx jack set.
there is ample power to run my Elecraft KX2 HF radio (9 bands). it draws up to 2 amps at key down. i could operate for many hours with the house battery and still have cold beverages and frozen ice cream.
i have an Elecraft K2/100 which can output up to 100watts. it draws 20 amps at key down. setting the output to 50 watts reduces the current load to 10 amps at a cost of 3dB on my signal. in harsh band conditions, the 100 watts will be needed, or for contest weekends like CQWW.
the table makes for a comfortable operating position. i have yet to find an elegant solution to pass the coax into the Westy, i'm just running it out the open slider for now... or a cracked window or thru the pop top front screen. i have considered a bulk head connector, but i'm not sure where to put it.
the antenna system is a 20/40m trap dipole for up to 100w operation and an End Fed Halfwave for 40/20/15/10 for 10w operation. a Buddipole/Buddistick might be a future purchase... but i like instant band switching.
overall the Westy has been serving it's purpose being the foundation of some "epic" adventures. i plan to get on the radio a bunch this fall.
73 de WM3O _________________ 1991 Vanagon GL Camper
BiWerks Design, LLC
ProspectiveOwnergon Samba Member
Posted: Thu Sep 23, 2021 8:34 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
Have you thought about using one of the hookups for a coax pass through? You could probably double up solar and coax in one box |
Posted: Thu Sep 23, 2021 11:47 am Post subject: Re: The mania deepens: 1991 Full Westy rescue |
ProspectiveOwnergon wrote: |
the thought had crossed my mind, maybe when i switch to the Shur Flo faucet and eliminate the city water hookup... _________________ 1991 Vanagon GL Camper
