Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue Jan 28, 2020 5:40 pm Post subject: New Elring flywheel seal too loose. |
On another site, a guy showed a new out-of-the-box Orange Elring flywheel seal that was way too loose for his engine. Anyone else had this issue? No way was that seal in the video going to seal anything. The guy pushed it in and out with no resistance at all.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
vamram Samba Member
Posted: Tue Jan 28, 2020 5:43 pm Post subject: Re: New Elring flywheel seal too loose. |
Did he lube it w/WD-40 or something? That makes it easy to install by hand w/almost no help from any special tool. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
KTPhil Samba Member
Posted: Tue Jan 28, 2020 6:13 pm Post subject: Re: New Elring flywheel seal too loose. |
Fixed it for ya:
vamram wrote: |
Did he lube it w/WD-40 or something? That makes it easy to uninstall by itself w/almost no help from any special tool. |
modok Samba Member
Posted: Tue Jan 28, 2020 7:13 pm Post subject: Re: New Elring flywheel seal too loose. |
My first response would be to measure the hole.
If the hole is the right size I'd try another seal.
probably equal chances of one or the other being the problem, maybe even both.
The seal is sold separately. if you need ONE try CB or ACN |
Posted: Tue Jan 28, 2020 7:34 pm Post subject: Re: New Elring flywheel seal too loose. |
This guy’s video shows him taking the orange Elring seal out of the box. Then he sticks it in the hole. It doesn’t even slide in, but rather falls in. It fits as if he had something other than a Type 1 engine. I’m thinking it may be a Chinese counterfeit, or something.
He also shows the old VW seal that he removed. It fits snugly.
Richard O'Brien |
Posted: Tue Jan 28, 2020 7:48 pm Post subject: Re: New Elring flywheel seal too loose. |
Okay, I was able to read the part numbers on the seals. The old one that fit had a VW symbol on it. Part # 113 105-245-2
The new Elring’s part # 113 105 245 FS.
This last is the one that was too small. The part numbers are the same except for the last part.
Richard O'Brien |
modok Samba Member
Posted: Tue Jan 28, 2020 8:41 pm Post subject: Re: New Elring flywheel seal too loose. |
Each seal does have a specification for what range of hole size and shaft size it fits.
Unfortunately elring being a more..... foreign outfit I don't have quick access to those specs. |
modok Samba Member
Posted: Tue Jan 28, 2020 9:10 pm Post subject: Re: New Elring flywheel seal too loose. |
OR, maybe the seal is just WRONG.
Wrong happens.
If I may vent.....yesterday I'm assembling a toyota 2.7, with ITM parts kit.
The crank is ground .0005 oversize on both rods and mains, rod bearings have too much crush and are too tight. Main bearings have not enough crush and are too tight.
So, approching 100% wrong.
Today, tried daido brand bearings..... totally different. Crush is correct and clearances are at the high end of spec.
More and more I believing "ITM" is where defective parts go to be disposed of. There certainly is wrong out there. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1597 Location: The South Zone
Posted: Wed Jan 29, 2020 1:59 pm Post subject: Re: New Elring flywheel seal too loose. |
I just put a new Elring main seal in mine last summer, and now that you mention it, it did slide into the case a LOT easier than those seals ever did before. I was able to push it in with just my fingertips (and a good thing too, since I couldn't find my installation tool). I like to smear a thin layer of Loctite 518 around the outside of the seal to lubricate things and help it go in, so I don't know how much that contributed to the ease of installation. But like I said, I don't remember it ever being that easy before.
Personally, I kind of prefer it that way. As long as it doesn't just drop in, I don't mind not having to really press it in. It would also be nice if I could remove it if I had to without having to destroy it. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Jan 29, 2020 2:21 pm Post subject: Re: New Elring flywheel seal too loose. |
I use Elring and the double lip German seals. Have no idea how many we install a year...dozen or more? Never ran into them being too loose. Well, maybe there was one that was not a hard to get in, but definitely not slip in. I usually get them from CIP1, but get some on occasion from other vendors. _________________ D-Dubya Manx clone - 63 Short pan,1914.
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Wed Jan 29, 2020 3:58 pm Post subject: Re: New Elring flywheel seal too loose. |
FYI I have just this very minute finished installing a new Elring German main seal and it fit nice and tight as always. To be fair, I did buy it a few months ago. Manufacturing date on the package is June 2018.
No VW part number on the box.
Dimensions on the sticker are 70mm x 90mm x 10mm.
Elring part number is 513.326.
_________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Wed Jan 29, 2020 4:41 pm Post subject: Re: New Elring flywheel seal too loose. |
I’d show you the video, but don’t know how to transfer it from Facebook to here. The Elring seal just slipped in the hole with no resistance at all. I have used nothing but Elring in the past, but no way would I put one in that’s that loose.
Richard O'Brien |
modok Samba Member
Posted: Wed Jan 29, 2020 5:46 pm Post subject: Re: New Elring flywheel seal too loose. |
If you put a lubricant on it, it will slip in with very little force, maybe two fingers.
As i was explaining in ANOTHER thread, this is why you DON'T put lubricant or sealant on it, it won't STICK right.
But sometimes you WANT that, and then choosing the right sauce can be critical. For rubber parts I often use a lubricating soap. It's real slippery but within an hour it dries out and the rubber sticks fast in place.
518 would be my choice for a curing sealant, If the seal is loose, but make sure to prep the surface so it cures fast, and watch that it doesen't climb back out of the hole.
You can see how using a non-hardening sealant might bite you in the ass here. It never hardens So your NEW silicone main seal, or silicone pushrod seals, will SQUEEZE out later, and you will be sad.
You guys might think that mounting a tire to a wheel is DIFFERENt? than installing a seal, than installing an O-ring, but, it isn't, really it's exactly the same issues. Imagine a silicone tire. Not very good grip. |
Posted: Wed Jan 29, 2020 7:26 pm Post subject: Re: New Elring flywheel seal too loose. |
Tim Donahoe wrote: |
Tim |
Maybe he just got a bad one that slipped past QC. Either that or his case is all hogged out _________________ 1965 Volkswagen 1500 Variant S
Posted: Wed Jan 29, 2020 8:06 pm Post subject: Re: New Elring flywheel seal too loose. |
Sj, if you look at one of my posts, you’ll see the part numbers on the old seal (the one with a VW symbol), as well as the new seal. Their part numbers are almost identical. When the guy tries to put the old seal back in, its very snug. The new Elring slips in with no pressure to speak of.
I’m thinking he, either got a bad one from the production, or he got a counterfeit.
I mentioned this as a warning to others, in case they run into the same problem.
Richard O'Brien |
Ovally Samba Member
Posted: Wed Jan 29, 2020 10:12 pm Post subject: Re: New Elring flywheel seal too loose. |
Tim |
S = silicone seal.
Silicone is smoother and softer than rubber, which makes it easier to mount the seal.
There is also a disadvantage, because of the ease of assembly, you are quickly inclined to assemble it without a special tool.
Don't do that! Silicone is more vulnerable than rubber, so always use the right tool : https://www.jbugs.com/product/5774.html
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Posted: Thu Jan 30, 2020 12:13 am Post subject: Re: New Elring flywheel seal too loose. |
Ovally, the guy in the video hand installed (with two fingers, actually) the new Elring seal, a good 1/8th inch past flush. No installer needed.
By the way, I own that Jbugs seal installer. It works perfectly. But, I paid 25% less for it a few years ago.
Richard O'Brien |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Jan 30, 2020 8:40 am Post subject: Re: New Elring flywheel seal too loose. |
In 2016-2017 I used crankshaft seal AC105288 from RockAuto (IAP, $3). Note that IAP is just a distributor of parts, not a manufacturer.
I was fearful of using a 15-year-old "new" seal I had still, fearful that the rubber may have lost some flex. Permatex Aviation on the outer edge, tapped it in evenly with a 1/2" dowel.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Sat Feb 01, 2020 4:15 pm Post subject: Re: New Elring flywheel seal too loose. |
Hey guys!
I think the person in reference is me.
Here is my issue...
I’m cleaning up and resealing an engine that came out of a 71 super beetle. I pulled the rear main seal out and it was nice and tight and hard to get out, and went to install a new elrin rear main seal in. The elrin slides in with no pressure. Not tight at all. I then went to my local Napa and ordered a felpro. This seal is the same way. Then I measured the seals and the openings of the engine block. Nobody has seen this before so I’m hoping maybe you guys could please help. This is the last thing I need so that I can install the engine again.
The VW seal that I removed was nice and tight and measured 90.6mm
Part number 113-105-245-2
SABO O 1927 BR
The Erlin is 90.2mm
The felpro is 90.2mm
And the factory hole in the block is 90.3mm
So there’s a .4mm difference in my old and new seals and it makes a huge difference. I can literally slide the new seals in there with next to no resistance.
Any thoughts? I appreciate any info in advance. _________________ its not about what you say you will do oneday, its what you do today that actualy means something. |
modok Samba Member
Posted: Sat Feb 01, 2020 5:06 pm Post subject: Re: New Elring flywheel seal too loose. |
Hole is too big. Generally the seal bore is about 89.95 average size. |
