gday kombis Samba Member
Joined: July 19, 2006 Posts: 3 Location: Oxfordshire U.K and OZ!
Posted: Wed Jan 29, 2020 4:19 pm Post subject: main bearings for 36HP (30) HELP!! |
Hi There,
my first post in this section, but I have researched the forum a lot over the last few months.
I am in the process of building a vintage speed engine for my original paint '58 RHD beetle here in Australia.
I am from the U.K originally and have sourced parts from the U.S and U.K for the project.
WW twin port kit with carbs
WW sports cam
WW crank 69.5mm
WW 81mm P/L
Abarth exhaust
AA Rods for 36hp
AA 2 piece lifters
empi ally cut to length push rods
ratio rockers from AA
WW fram filter etc etc
Along with lots of other parts
My Main (EXCUSE THE PUN) issue is that no one has the bearings I need!! through my research it seems they all come via BBT?
We intend to machine the case to:
0.020 Case
Std crank
Std trust or oversize
But we haven’t machined the case yet so could go bigger on the mains?
I ordered these as they were in stock, later to be told they aren't and no lead time...
Part#: 111 198 451/50
https://aapistons.com/collections/main-bearings/pr...ndard-case
Please help if you have a a set or supplier send me some info.
Billy |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Jan 29, 2020 4:39 pm Post subject: Re: main bearings for 36HP (30) HELP!! |
Check the classifieds here, there are some listed. I bought mine on e bay, look there also. And post a wanted to buy ad in the classifieds. Wolfsburg West is another place to look.
https://www.thesamba.com/vw/classifieds/detail.php?id=2272937 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
RWK Samba Member
Posted: Fri Jan 31, 2020 7:51 am Post subject: Re: main bearings for 36HP (30) HELP!! |
I have 2 sets, std,std, but no main in either set, Repco and ML, had them since the 80's thought they were 40 hp, which I plan to rebuild. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Fri Jan 31, 2020 8:43 am Post subject: Re: main bearings for 36HP (30) HELP!! |
I got those pm me
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Tue Feb 04, 2020 9:01 am Post subject: Re: main bearings for 36HP (30) HELP!! |
those are std. std. not what he needs.
he's looking for 111 198 451 /50 (case)
or 111 198 451/os in k/s brand
or 111 198 451b glyco
different brands label them differently .
anyhow the 451 means standard crank.
453 .010 under 455 .020 under 457 .030 under crank
Steve
cip1.com shows they have them in stock _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Braukuche Samba Member
Posted: Sun Feb 09, 2020 6:52 pm Post subject: Re: main bearings for 36HP (30) HELP!! |
I've always got mine from Wolfsburgwest are they out or something? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Mon Feb 10, 2020 10:42 am Post subject: Re: main bearings for 36HP (30) HELP!! |
Braukuche wrote: |
I've always got mine from Wolfsburgwest are they out or something? |
they have been out of them for a long time.
he must of found them. cip1 has them .
sinter metal brand. I have them as well.
also in k/s _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6590 Location: Houston, Texas
Posted: Mon Feb 10, 2020 7:08 pm Post subject: Re: main bearings for 36HP (30) HELP!! |
I've got a few set's of 36HP laying around that I need to measure. let me know what you need. If I do not have them I know other folks with stacks of them.
The Glyco ones can get pricey. _________________ www.vwnos.com [email protected]
Posted: Tue Mar 03, 2020 3:52 am Post subject: Re: main bearings for 36HP (30) HELP!! |
Thanks for all the help. Someone gave me the heads up that CIP had them and so and order was placed. excellent service from these guys and the motor is being built up at last! |
heimlich VWNOS.com
Posted: Tue Mar 03, 2020 9:48 am Post subject: Re: main bearings for 36HP (30) HELP!! |
Do you know what kind of bearings they have available? _________________ www.vwnos.com [email protected]
