Mexican dash pad didn't work for me!
Page: Previous  1, 2
72VWSB Premium Member
72VWSB is offline
PostPosted: Mon Feb 10, 2020 10:20 am    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
Well, it looks like the front vents on the dash are going to be fun getting them into the holes on the WCM dash pad! It appears that after looking at the old dash, these two front vents were pushed through the holes with the plastic side lugs melted on the inside to keep them in place! Should be fun...guess I'll have to try to glue the damn things in!!
72 VW Super Beetle
AlmostHeavenWV_VW Premium Member
AlmostHeavenWV_VW is offline
PostPosted: Mon Feb 10, 2020 10:47 am    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
If there's enough post sticking through just use something like these that will slide down and grip the posts
"Starlock washer"
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
72VWSB is offline
PostPosted: Mon Feb 10, 2020 10:54 am    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
Thanks for the response! However, I'd have to take the dash back out again and it took me quite awhile just getting stuff hooked up again!
72 VW Super Beetle
sb001
sb001 is offline
PostPosted: Mon Feb 10, 2020 12:12 pm    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
How is the glove box door area on a WCM pad? Others have had issues there so that is of primary concern to me.
I'm the humblest guy on this board.
1969 autostick sedan, owned since new
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
lboos
lboos is offline
PostPosted: Mon Feb 10, 2020 12:44 pm    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
I did not have that much trouble putting the vents in, i did have to play with them, binding them and using a screwdriver, i don't remember the lugs being melted, just the lugs that held them in. again i did not hook up the other end under the hood.
The padded dash was installed when i put in the vent's, and mine is a 72 super.
Are you using your old vents, or the one's that came with the new dash ?
Good luck.
PostPosted: Mon Feb 10, 2020 1:14 pm    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
JB ClearWeld for the win! Just a dab will do it!
https://www.lowes.com/pd/J-B-WELD-Clearweld-Clear-Epoxy-Adhesive/50149636
1600DP AK case
Solex 34PICT3 Carb
72VWSB is offline
PostPosted: Mon Feb 10, 2020 4:36 pm    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
Do you just epoxy the little studs that go through the dash and epoxy them on the inside of the dash?
72 VW Super Beetle
PostPosted: Mon Feb 10, 2020 4:56 pm    Post subject: Re: Mexican dash pad didn't work for me! Reply with quote
I'd just put a small dab on the studs, yes. Then just stick them through in place.
Once cured, the PSI strength on that epoxy is ridiculous. You'll tear the foam way before it'd give way.
1600DP AK case
Solex 34PICT3 Carb
Page: Previous  1, 2
Page 2 of 2
