Bumper brackets
QRP
QRP is offline
PostPosted: Fri Jan 31, 2020 3:39 pm    Post subject: Bumper brackets Reply with quote
Are all the bumper brackets from 71 & earlier the same and are they different from bug brackets 🤔 ( the body to bumper part )
New to the ghia thing and gonna start collecting all the pcs for a 68
Thanks Rick
c21darrel
c21darrel is offline
PostPosted: Fri Jan 31, 2020 5:30 pm    Post subject: Re: Bumper brackets Reply with quote
All the same for ghia and completely different from beetle
GhiaBuild
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Sat Feb 01, 2020 1:23 pm    Post subject: Re: Bumper brackets Reply with quote
The Ghia front brackets are interchangeable left to right.
The rear brackets have a left and a right.
(Compression 8.7:1)
https://www.thesamba.com/vw/forum/viewtopic.php?t=696460&highlight=rose
QRP
QRP is offline
PostPosted: Sun Feb 02, 2020 9:30 am    Post subject: Re: Bumper brackets Reply with quote
Thanks for the info 👍
CanadaGhiadude
CanadaGhiadude is offline
PostPosted: Fri May 29, 2020 9:34 pm    Post subject: Re: Bumper brackets Reply with quote
This quote is NOT correct. The two front bumper brackets are specific left and right and not interchangeable
sputnick60
sputnick60 is offline
PostPosted: Sat May 30, 2020 12:15 am    Post subject: Re: Bumper brackets Reply with quote
Sorry, but not right either.
The parts book has 141 707 135C two per car at the front but at the rear bumper a different story. Those are different per side 141 707 335A left and 141 707 335B left.
The fatchick bumpers have a similar thing. Front symmetrical therefore interchangeable, rear asymmetrical therefore not.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
Sofia74
Sofia74 is offline
PostPosted: Tue Jun 02, 2020 1:41 pm    Post subject: Re: Bumper brackets Reply with quote
Does this bumper bracket info apply to 1974? Or are you guys only talking about earlier cars? I'm looking at some front and rear brackets for sale for my 74 coupe. They say they are for 73-74 and interchangeable between right and left for both front and rear. Does that make sense?
Thanks.
sputnick60
PostPosted: Wed Jun 03, 2020 2:35 am    Post subject: Re: Bumper brackets Reply with quote
Thanks.
I referred to Fatchick bumpers in a vulgar reference the later bumper style. 72 to 74. The parts book says the front supports on the later cars can go on either side but the rear bumpers have somthing specific that makes a left support bracket and a right support bracket. Probably there are holes for something on the bracket that means you just can't flip them over and that's why two part numbers.
Probably needs comment from a 72 and later Ghia owner
Nicholas
runamoc Premium Member
runamoc is offline
PostPosted: Wed Jun 03, 2020 6:13 am    Post subject: Re: Bumper brackets Reply with quote
The rear has a 'hold-down' loop attached to the bracket. The front 'hold-down' loop is attached to the front end. Might be able to hacksaw it off or something. I made my own brackets for my '72 so I could mount earlier model bumpers because I also think the fat chic bumpers are not very, umm, appealing.
Daily driver: '69 Baja owned 40 yrs. Plan B: '81 Rabbit Diesel LS Deluxe Plan C: '72 Ghia
In garage for rehab: '71 Beetle Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
Sofia74
Sofia74 is offline
PostPosted: Wed Jun 03, 2020 12:00 pm    Post subject: Re: Bumper brackets Reply with quote
I just checked my Parts Book and sure enough there are two rear brackets - right and left. But my Parts Book is dated 1972. I've found it to be very accurate for my 1974 coupe but is it possible this is an exception?
Perhaps the difference is the "hold down loop"? I know I have one or more on my brackets but I can't look at them right now to confirm.
And then there is this from CIP1:
VWC-141-707-335-B - (141707335B) EXCELLENT QUALITY FROM GERMANY - BLACK POWER COATED - REAR BUMPER BRACKET - FIT LEFT OR RIGHT SIDE - KARMANN GHIA 72-74 - SOLD EACH
I don't see a loop in the photo so perhaps absent the loop(s) they may be the same...?
Redlabel6
Redlabel6 is offline
PostPosted: Wed Jun 03, 2020 12:53 pm    Post subject: Re: Bumper brackets Reply with quote
Here are the stock rear brackets on my '73.
Left side with Loop, or Tow Point
Right side without
Other than the tow point they are identical. The front brackets are identical.
David
1973 Karmann Ghia Coupe
2005 Passat TDI
2005 Jetta
Sofia74
Sofia74 is offline
PostPosted: Thu Jun 04, 2020 1:32 pm    Post subject: Re: Bumper brackets Reply with quote
Good to know. Think the same is true about the rear brackets?
Thanks.
