Vanagon Nut Samba Member
Posted: Fri Jan 31, 2020 4:31 pm Post subject: Rain Water In Snorkel, Burned by Engine? |
Hi folks.
If 2 days worth of heavy rain drips into the OE snorkel, can that amount of water get sucked past the air filter and be burned by the engine and cause a lot of white exhaust, power loss, engine cut out?
On my Jetta engine swapped '88 with Ford air box, when it rains heavily, first start of the day, what usually happens: exhaust is billowing white, engine looses power and will cut out a few times under load. This all passes pretty quickly then it runs fine. I have yet to see this happen on dry days.
I'm nearly certain water is causing this. I'm leaning towards water getting in the fuel tank but the way the van is parked overnight, a stream of water appears to come down through the passenger side rear grill. I wonder if it's getting into snorkel or in via a poor connection between snorkel and hose. IIRC, the snorkel opening faces rearwards.
Fuel injectors were serviced, regulator, etc are fine, I really doubt I'm burning coolant. I've put methyl hydrate in fuel tank but nothing conclusive from doing that.
Thanks
1988 West DIY 50º ABA
VE7TBN |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
?Waldo? Samba Member
Posted: Fri Jan 31, 2020 5:10 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
How is the airbox oriented? It should be oriented so that clean air is pulled through the filter in a manner that will leave water behind and allow it to drain out on the dirty side. If it is a flat filter airbox it should be installed with the filter horizontal and the clean side above the dirty side. It should have an appropriate slope for the bottom of the box for the water to flow to a drain hole. For inspiration, this not-so-sexy curve was caused by an air filter system that even had a decent sized drain at the low spot.
Considering the performance issues you describe it is a significant concern.
Another common culprit would be the rollover valve gaskets in the top of the fuel expansion tanks. Those like to funnel water into the fuel system. |
82westyrabbit Samba Member
Posted: Fri Jan 31, 2020 7:01 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Hi Neil. As you know I basically copied your aircleaner design. I my case the air box is behind the left taillight instead of the right. Just by chance my air box Angeles down about 30 degrees towards the snorkel. I also have drain holes just like the air box did in the car it came out of. I am daily driving my van at the moment in Dallas TX in some pretty heavy and I am not having those problems. John |
Posted: Fri Jan 31, 2020 8:36 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Very helpful replies guys. Much appreciated.
dobryan, ?Waldo?
Yes, thank you. I am considering that there might be water getting into the fuel tank via a failed roll over gasket(s).
Ok, so, in some kind of overly determined manner, , though this hole is not a drain, I think, I plugged the hole shown (arrow) on my Ford Escort air cleaner. I think in the Ford, the lower opening where I attached hose acts, in part, as a drain. In the OE application, air is taken in via opening I closed off with duct tape and clamp. So bojangled. LOL.
I did not put a drain hole on flexible hose or air cleaner. D-oh! Now I know.
IF adding a drain and/or reconfiguring things cures this issue, I'll be extremely happy. Though the head checked out to be UN-warped at time I rebuilt the engine, since I'm a newb to rebuilding engines, my concern was that there might be some kind of intermittent coolant burning issue.
Neil.
Looking down through rear grill at flex hose where it joins snorkel. Lower 1/3 of snorkel is wet as is area near clamp. You can see rust at reenforcing spring in hose
VE7TBN |
Posted: Fri Jan 31, 2020 9:12 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
?Waldo? wrote: |
How is the airbox oriented? It should be oriented so that clean air is pulled through the filter in a manner that will leave water behind and allow it to drain out on the dirty side. ..... It should have an appropriate slope for the bottom of the box for the water to flow to a drain hole.
The box is sort of cone shaped and oriented pretty much horizontally level. If the small half oval shaped hole shown in image below is the OE drain hole, it is currently not at the bottom of box.
The shape and current position of the box may allow any water that enters it to flow "downhill" towards the MAF then onwards. I still find it hard to imagine that water can get pulled past the filter but then the engine is pulling quite a vacuum.
Neil.
My box is mounted like this but end for end and is level. i.e. the inlet end is up higher than shown here.
the small half oval hole might be the OE drain hole?
VE7TBN |
bluebus86 Banned
Posted: Sat Feb 01, 2020 12:19 am Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Drilling a hole in a low spot of a snorkel system kind of defeats the purpose of a snorkel. When you drive thru high water, that low spot hole you drilled when submerged will suck water into the intake.
Perhaps you can add a 180 degree bend near top of the snorkel to keep water from getting in?
if water is getting into the tank, fix it asap so your tank dont rust, water in the fuel can cause other damage, such as ruined pump, rust contamination, clogs, etc...
use gasoline water remover, i.e. gas dryer additive in the meantime.
tank should be drained or use a good deal of the dryer after you fix the source of the water leak. you got to get that water out of the tank, water will stay in the low spots, and not be fully removed by the outlet port, unless dryer is used.
also water steam from the tailpipe can be normal in humid conditions, specially if van was been driven short distance i.e. not fully warmed up, on prior run, as an unwarmed motor will leave water build up in the cylinders, and exhaust system, muffler, which will be released as steam later, if atmosphere is humid, then a lot of vapor will be visible out the tail pile anyways, as water is a normal byproduct of combustion.
I had to replace my catalyst, with cold engine, started it and moved van 30 feet to place to work ln it, engine never got warm, pulled the catalyst off and drained about a 1/8 th cup of water out. and that was only from running van for less than a minute! water collected in the cold exhaust system, had I run van for 15 minutes, that water would have evaporated in the hot exhaust system, but being cold, it condensed in there.
also in cold weather with temp changes, night to day, , and humidity, i.e. rain, when the metal,of the muffler is colder than the air, say in morning as the air heats up faster than the steel,, water from atmosphere will condense on the muffler, inside and out, and that inside will run to the lowest part and pool up.
Bug On in a Van! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
newerwesty1987 Samba Member
Posted: Sat Feb 01, 2020 2:09 am Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Maybe look into a dust dump valve or duckbill (or Vacuator valve) that are on many industrial air cleaners. Allows water and dust out but closes when there's a vacuum.
https://www.donaldson.com/en-be/engine/filters/tec...ust-water/ |
Posted: Sat Feb 01, 2020 10:13 am Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
82westyrabbit wrote: |
John: that's great you're daily driving your swap. Ok. Helpful real world information!
bluebus86: I may remove the Vanagon snorkel then run hose so it points downward or run a hard plastic pipe in the same manner. I do wonder if the existing hose got punctured during install. On my first swap, I originally used a smaller Dodge Caravan air box. I may go back to that .... if I can find one. Or, I might be able to make room in engine bay for the WBX air box but intake routing between MAF and box would be a pita.
newerwesty1987: Thanks. I'll look into that. I"d be curious to see a youtube video of it in action.
Neil.
Dodge box is fairly small and top can be reversed:
metropoj use of same:
intake snorkel I'd used with old dodge box. IIRC, I just ran it at an angle. I think it came from the Mk3 air box.
VE7TBN |
tjet Samba Member
Posted: Sat Feb 01, 2020 10:22 am Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Maybe add a Syncro water trap? |
Posted: Sat Feb 01, 2020 10:57 am Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
I guess it depends on your intentions. If you're planning on fording water deep enough to submerge your intake to the filter box then the drains will not work. If you're not planning on submerging your entire engine under water, then the drains and proper orientation of the airbox are the easy way to avoid hydrolocking the engine and bending your connecting rods. For some reason I don't think that Neil is planning on driving his westy through water 3 feet deep but I might be wrong about that. |
Posted: Sat Feb 01, 2020 2:57 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
?Waldo? wrote: |
This has been a "bucket list" item for some time!
I'm joking of course; I have no plans to drive in deep water.
Hopefully, using "snorkel" in my subject wasn't misleading; the Vanagon is 2wd and does not have an external "snorkel" like some Syncro folks do.
It rained a LOT last night. For a short period of time, I parked van on slight incline with rear half exposed to rain then moved entire van under cover.
It's sunny today. At first start, idle was rough, then billowing white smoke started and engine cut out under load driving up hill. Symptoms were likely due, in part, to rain from days prior. As usually, once I drove it a few KM's, it ran great.
Engine cut out driving up hill could indicate water in fuel tank but hopefully, I'll find signs of water ingress at snorkel et al.
I have other Vanagon work to do first but will report back if I find signs of water at pre filter intake tract.
VE7TBN |
tjet Samba Member
Posted: Sat Feb 01, 2020 5:02 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Be sure to check your gas tank expansion tank. IanNJ had an issue with his - the seals were gone allowing water to get in the fuel.
I think a lot of the "bad running" issues here are from contaminated fuel & gas tanks with sludge (not necessarily your problem)
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100 |
Posted: Sat Feb 01, 2020 6:21 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
tjet wrote: |
Be sure to check your gas tank expansion tank. |
Thanks!
Close up view showing damp spot at bottom of MAF part that attaches to air cleaner. It appears water is coming out of air cleaner. After it rains some, I'll pull apart the air cleaner. (it's kind of a pita. Another reason to switch to a smaller air cleaner)
Ford Escort air cleaner in van in question. Arrow points to what is likely the drain hole
VE7TBN |
Posted: Sat Feb 01, 2020 6:43 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
I think if you drill the holes on the bottom your air filter housing your problems will go away. All so if you angle the air filter so the intake side is the lower than the engine side that would help to. Yes it is a pain to change or ck the air filter but it fits so nice in there mine is going to stay. If you really want to go to the Dodge air filter housing I have one I could send you if getting it across the border is not to much trouble. I also have a round air filter housing that will fit in the same space that I think comes from a Dodge as well. John |
Posted: Sat Feb 01, 2020 7:01 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Thanks for the offer of Dodge air cleaner John.
Well, maybe I'll just drill a couple holes and angle inlet side downwards.
The diesel Vanagon has a little more height between in opening to area in front of tail light. The Escort air box is a tight fit on my gas Vanagon. It butts up against a fair amount of sheet/framing metal.
Do you think much air cleaner noise gets transferred to vehicle frame if air cleaner box is touching body metal?
VE7TBN |
Posted: Sat Feb 01, 2020 7:45 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Probably not. I shortened the air filter housing buy cutting the trumpet end off and fiberglassing over it. I also angled the snorkel fitting a little bit so it I could send it straight up the D pillar. All my fiberglass stuff was out for another project anyway. Somewhere in my photo gallery there is picture of it before I installed it. I also covered it with Dinomat to make sure I shut it up. John |
Posted: Sat Feb 01, 2020 9:01 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
Nice tips.
Ya I can't recall why I positioned the air cleaner like I did. Particularly with the inlet at 90º or rather, 3:00. Maybe to allow easier access to the release on ring that allows air filter to be changed? I also cut off that trumpet and covered it. With duct tape, and hose clamp. Tres Trailer Park. Oh so chic.
"Devils' in the details" as they say.
I'm hoping that if water is indeed getting in through the air cleaner, and that IF water is also adversely affecting the idle control valve, that would surely make me happy. 95% of the time, the engine runs like top. I really enjoy driving it.
Neil.
Duct tape at its best?
VE7TBN |
Posted: Sun Feb 02, 2020 2:29 pm Post subject: Re: Rain Water In Snorkel, Burned by Engine? |
You have spent to much time with the red green show. They just do things different north of the border. That airplane was attacked by a bear. I think the owner left some food in it. That airplane was all over the aviation from’s at the time it happened. Thanks John |
