unibagel Samba Member
Joined: December 02, 2004 Posts: 528 Location: Bflo, NY
Posted: Fri Feb 21, 2020 10:17 am Post subject: Re: All things uniWerks Design |
I am now testing a new product idea, a hardwired night light for the upper bunk. Would there be interest in this vaguely worded product? LOL.
My daughter likes a nightlight, so I thought this would be an integrated option for cases like that..
I'd love to hear your thoughts. _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
www.uniwerksdesign.com |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Fri Feb 21, 2020 11:34 am Post subject: Re: All things uniWerks Design |
thoughts on nightlight -
features I'd like - a light sensor (ie it turns off automatically once it is light out, my kids leave their night lights on all night, unless I turn them off).
Perhaps a timer? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Merian Samba Member
Posted: Fri Feb 21, 2020 1:58 pm Post subject: Re: All things uniWerks Design |
kguarnotta wrote: |
make your kids push start the Van next morning - that will cure the problem _________________ .... |
fishgo Samba Member
Joined: June 21, 2018 Posts: 127 Location: Madison, WI
Posted: Fri Feb 21, 2020 2:39 pm Post subject: Re: All things uniWerks Design |
Chris:
Question for the "color options" of your dash pods: Is your "brown" color a lighter brown whereas most Westy dashes are "dark brown"? I'd like to get a dash pod but if it is a much lighter brown I'd probably pick black. Specifically the ash-try mounted pod. |
Posted: Fri Feb 21, 2020 4:03 pm Post subject: Re: All things uniWerks Design |
Yes it is not a match. I have black in my van. I like it. _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
Vanlife Geek Samba Member
Posted: Fri Feb 21, 2020 4:04 pm Post subject: Re: All things uniWerks Design |
Chris: I'd be interested to know how people are wiring their upper bunk (above the slider) vent units. It's not real obvious to me how to run a wire to that location. I love the idea of your light/level/USB unit.
Also, wouldn't it be cool if that light could come on automatically when the slider is opened. My sliding door switch doesn't do anything and it would be nice to re-purpose it somehow to work with your light with perhaps a 3-way switch so it would work like the driver door light. _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era) |
Posted: Sat Feb 22, 2020 8:25 am Post subject: Re: All things uniWerks Design |
Excellent question! I have a 85 Westy Weekender, so I just removed the screws from the headliner, dropped it down slightly and ran a new, fused power wire from my Aux battery. Up the drivers side B pillar, above the headliner and over to the vent channel to provide power for my upper bunk powerpod and an extra set of lights... _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Sat Feb 22, 2020 8:48 am Post subject: Re: All things uniWerks Design |
unibagel wrote: |
I'd love to hear your thoughts. |
You won’t be competitive with a battery operated LED. _________________ .ssS! |
Posted: Mon Mar 16, 2020 5:35 am Post subject: Re: All things uniWerks Design |
Well it seems like we all will have a lot of time on our hands in the coming weeks. So here is a bonus and a bonus-bonus for you! I'm running a 10% off sale now through Wednesday. Use coupon code: staythehellhome10.
As a special bonus to the bonus if you spend at-least $30, use an additional coupon code: uniwerksdesignfreebie to get a free uniWerks Design Ringer T-Shirt.(While supplies last) Be sure to put the shirt in your cart to use the coupon!
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Tue Mar 17, 2020 6:27 am Post subject: Re: All things uniWerks Design |
Can you send me a pic of the hole where your stock door light is?
[email protected]
Cheers
Chris _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10077 Location: Abiquiu, NM, USA
Posted: Sun Apr 05, 2020 8:11 am Post subject: Re: All things uniWerks Design |
Hey Chris, that looks like a nice product, pretty easy to improve on the flimsy OEM Hella domelight modules but you've done something special with these.
But, looking at your two wire-up concepts, may I offer a third way to wire it?
If you have the power feed come in on the center pole of your dual-throw switch, then one LED could be grounded by the door contact switch, working when the switch is left in that throw, and the other LED would have a direct ground and be turned on by the other switch throw. You'd just have to reverse the connections on the two LED's to correct the polarity.
That way if someone wanted the red light to come on with the door open, the red LED could connect to the door switch grounding circuit, and the dual-throw switch would power that side when selected. Then the switch could power the white LED on its other throw.
Or vice versa. It would be up to the installer. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Thu Apr 16, 2020 1:34 pm Post subject: Re: All things uniWerks Design |
You are home and bored, you should really knock out a couple of projects on your Vanagon. Here's some incentive, 10% off now thru Friday midnight EST.... Be sure to do some backyard camping as well!
Coupon code: workonyourdub10
https://uniwerksdesign.com/ _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
82bessieblue Samba Member
Posted: Mon May 04, 2020 6:26 am Post subject: Re: All things uniWerks Design |
Wanted to give a shout out to Chris for his help in customizing the fridge pod cover to allow mounting of my aux battery monitor! Fits like a glove! Thanks again Chris!
_________________ 1982 Aircooled 2.0L Vanagon - BessieBlue |
Posted: Mon May 04, 2020 6:43 am Post subject: Re: All things uniWerks Design |
^Looking good Bret!! It was a pleasure working with you to get your design ideas transformed into reality!! _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Wed Jun 10, 2020 1:56 pm Post subject: Re: All things uniWerks Design |
Hi all
I finally got around installing the light pod above the sliding door. Chris was kind enough to modify the design he sells on the website, to include two different colors instead of one, as well as a 3-way switch (ON-OFF-ON). Here's a quick run-down of how I did it:
Here's how it looks in the end. 1/ Remove the air vent cover where you want the light. I chose the front:
2/ Run the wires. I used a pair of wires that came with my radio, small gauge, long enough.
Remove a couple of screws here and there
Run the wire between headliner and roof
Elegant part: you can run the wire in there. Perfect size!
Not elegant part: The wire is visible here. For now (Not sure where to run it concealed though)
Finally, in the cabinet, and to the fusebox behind the driver's seat. They need to make fuses smaller than 5 A now. 1 or 2 A would do here I guess.
Tada!
Perfect for looking for stuff at night without waking everybody up. I wish the white LED's were on the warmer side, but that's me.
Looks great and works great. VicVan happy. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Wed Jun 10, 2020 3:34 pm Post subject: Re: All things uniWerks Design |
I like the over slider light and have been wanting to do this. i think you could run a ground wire down and put a door switch so that the light can be turned on by opening the sliding door. or you could run an extra wire and splice into the door-operated ground on one of the front doors. _________________ 1989 Bostig Syncro Westy |
VicVan Samba Member
Posted: Wed Jun 10, 2020 4:15 pm Post subject: Re: All things uniWerks Design |
I thought about doing so, and it's definitely possible, lie you've described. I've decided against it because I need to be able to use the lights with the door closed. But with a 3-way switch and only one lighting mode (only white for instance), one could set up the switches just like the front light: ON-OFF-DOOR _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6349 Location: Honolulu,Hawaii and France
Posted: Wed Jun 10, 2020 5:39 pm Post subject: Re: All things uniWerks Design |
shizzon wrote: |
I like the over slider light and have been wanting to do this. i think you could run a ground wire down and put a door switch so that the light can be turned on by opening the sliding door. or you could run an extra wire and splice into the door-operated ground on one of the front doors. |
Most vans have the hole for the switch and contact spacer on sliding doors _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
