unibagel Samba Member
Joined: December 02, 2004 Posts: 528 Location: Bflo, NY
Posted: Thu Jun 11, 2020 3:46 am Post subject: Re: All things uniWerks Design |
Great write up VicVan!! Thank you for supporting my innovative little company!! _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
www.uniwerksdesign.com |
Posted: Wed Jun 24, 2020 1:43 pm Post subject: Re: All things uniWerks Design |
I came up with this little number to help those who camp with kiddos. Its an Upper Bunk PowerPod with an LED to illuminate the main area where you would step into the van after opening the slider. It has a dual USB to allow charging of devices in the upper bunk. And a built in red LED nightlight that shines upwards!
https://uniwerksdesign.com/product/upperbunk-2-switch-lightpod-w-usb-and-nightlight/
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Wed Jun 24, 2020 2:30 pm Post subject: Re: All things uniWerks Design |
Jake de Villiers wrote: |
Is there a hot wire travelling in the air vent channel there? |
IIRC, there is not but it's easy to splice into the driver's dome light and fish a wire above the headliner to the air channel. I'm pretty sure that's what I did when I added lights above the slider door. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Wed Jun 24, 2020 4:26 pm Post subject: Re: All things uniWerks Design |
I would HIGHLY recommend running a new and properly fused power lead to this location for installing this or any product that I offer for this location.
It literally took me 15 minutes to do this. Ran wire up the driver's side B-pillar, unscrewed the headliner screws and dropped it down slightly, ran wire across. Pop it through. put screws back into headliner. Crack a beer... _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
Posted: Sat Dec 19, 2020 10:24 am Post subject: Re: All things uniWerks Design |
Big news! Two months ago I was approached by the legend Jay Brown (thatvwbusguy on thesamba.com) asking if I'd like to take over the manufacture of his famous Hard Start relay Kits for Vanagon. To say that I was honored would be an understatement! I am so proud to carry the baton and offer these for sale. Manufactured per his exacting instructions and using the same parts from the very same suppliers. 🙂
https://www.uniwerksdesign.com/product/vanagon-hard-start-relay-kit/
Cheers!
Chris _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Sat Dec 19, 2020 6:34 pm Post subject: Re: All things uniWerks Design |
unibagel wrote: |
Cheers!
Chris |
Nice ! Now if you're bored in the upcoming weeks, you can look for a way to make them work on a van that has both an auto trans and cruise control.
(edit: cruise control, not air conditioning) _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Tue Mar 30, 2021 4:01 am Post subject: Re: All things uniWerks Design |
April Fools Day sale
Use the coupon code:
notfooling10
for 10% off all Vanagon and Eurovan products
One day only 4/1/2021 until midnight EST.
I appreciate your enthusiasm for the products I create. 30 years of engineering experience, the last 15 years spent designing plastic parts used in medical devices have given me a strong background. I'm also named on 5 US Patents for Medical Device Design.
Thank you for your continued support of my innovative, one man show, enthusiast run, small business. _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4772 Location: Bemidji, MN
Posted: Tue Mar 30, 2021 4:57 am Post subject: Re: All things uniWerks Design |
thanks for being so responsive in making widgets!
so i'm trying to shop your website and all the vanagon menus extend out to the left beyond my screen. not using a large monitor but man it's frustrating to see your items! what am i missing, besides a large monitor! _________________ -dan
www.thefixitworkshop.com |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Tue Mar 30, 2021 7:00 am Post subject: Re: All things uniWerks Design |
Hit ctrl minus a couple times ... ctrl- shrinks your text, and the menu's become useful.. then ctrl+ to get your text larger again later _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Apr 20, 2021 11:44 am Post subject: Re: All things uniWerks Design |
New product: Vanagon Instrument Cluster Bulb Reflectors.
These are hard to find now as they get brittle from the dashboard getting so much sun hitting it for years and years. My design mounts the same way as stock, it slides in and snaps tight. I spent quite a bit of time working on a design for this product and took a different approach to the the design. Rather than relying on complex angular shapes and little metal reflectors, I simply made mine round. I have tested it in my van using an LED bulb and I am happy with the performance. Now available in the webshop:
https://www.uniwerksdesign.com/.../instrument-cluster.../
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Tue Apr 20, 2021 2:04 pm Post subject: Re: All things uniWerks Design |
Looks cool...
If I recall correctly - you were looking for ideas on things to make.
One item - and I'm not sure how to solve this - would be a sunglass or glasses holder around the rear view mirror? I'm not sure how to describe this - but my wife's subaru outback has something like this, and my in-laws have it in their Honda.
It would be handy... _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
TrashPanda Samba Member
Joined: December 25, 2021 Posts: 119 Location: Oakland, CA
Posted: Wed Feb 16, 2022 2:56 pm Post subject: Re: All things uniWerks Design |
I started a separate thread just for photos of Chris' stuff.
But I thought I'd bump this thread with the custom grille badge he made for me.
I wish I'd had it when my van was stolen. It's home, now. And if anyone actually defeats my new counter-measures, I can always say mine's the van with the raccoon badge.
Anything that makes your van visibly unique is a theft-deterrent!
_________________ 1991 2.1L 4spd Tintop |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Thu Feb 17, 2022 6:29 am Post subject: Re: All things uniWerks Design |
What about the plastic nuts on the back of the late tin top AC evaporator housing? I'm only seeing these available overseas for 5 bucks a piece. Probably will be extinct soon. **EDIT*** sorry, i see that you have already made these. Thank you! _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 181 Location: Bellingham, WA
Posted: Fri Oct 14, 2022 12:52 pm Post subject: Re: All things uniWerks Design |
I still want a 3 pod cluster for one 60mm and two 52mm gauges for my tdi swap! |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Fri Oct 14, 2022 1:19 pm Post subject: Re: All things uniWerks Design |
Do you have pictures of the different colored vent covers? _________________ Currently:
Posted: Thu Nov 10, 2022 8:01 am Post subject: Re: All things uniWerks Design |
^ Not all in one photo. But if you poke around at different products you can see the colors.
95% of my products are made from high quality ABS plastic, just like modern car interior parts. Spray paint adheres quite well to ABS... _________________ Founder: uniWerks Design, LLC specialty 3D printed Vanagon parts
