Engine Serial # -help
Jeler
Jeler is offline
PostPosted: Thu Feb 06, 2020 10:54 am    Post subject: Engine Serial # -help Reply with quote
I've been scouring around here and there in search of information on my current
engine serial #. I haven't been able to locate it. It begins with an "H".
Currently seized and sitting in a '66 13 window bus.
Any help would be great thanks.
Jeff
crofty
Judas of the North
crofty is offline
PostPosted: Thu Feb 06, 2020 12:03 pm    Post subject: Re: Engine Serial # -help Reply with quote
H case would have been a 1493cc (1500) originally.
lots of numbers there. I did find "H5" listed as a ghia engine from '69
HamburgerBrad wrote:
Danwvw
Danwvw is offline
PostPosted: Thu Feb 06, 2020 12:34 pm    Post subject: Re: Engine Serial # -help Reply with quote
I think an H Case is an H Case not sure. H5 numbers show up here on the Samba above under Technical/Vin/Chassis Numbers/Giha in 1968. It still could be a VW dealership installed factory engine for your bus. Found this Thread: H engines cases 1968 soft metal?.
1971 Sundial Camper, Building a 74 mm Stroke by 88 mm bore with stock heads? And 1960 Beetle And 1679cc W-100 & Zeniths!
Jeler
Jeler is offline
PostPosted: Thu Feb 06, 2020 2:42 pm    Post subject: Re: Engine Serial # -help Reply with quote
Thank you. I also found the "H5" here. Just discovered an "H" series engine in this list http://www.clubvw.org.au/vwengines
which would match with the '66 Bus I have.
Jeff
PostPosted: Thu Feb 06, 2020 5:50 pm    Post subject: Re: Engine Serial # -help Reply with quote
H5 is listed in the Beetle VIN listing as 1968 Beetle:
https://www.thesamba.com/vw/archives/info/bugchassisdating.php
It's with M-code M157, which is some sort of emission control system
Your engine # is from August, 1967.
Jeler
Jeler is offline
PostPosted: Sat Feb 15, 2020 7:19 am    Post subject: Re: Engine Serial # -help Reply with quote
Everett,
Thanks, just what i was looking for. Guess I don't have to concern myself with rebuilding the engine now, since it's not a number matching engine.
Jeff in Iowa
