harrymarlin Samba Member
Joined: June 07, 2018 Posts: 722 Location: Washington, DC
Posted: Thu Feb 06, 2020 12:21 pm Post subject: Grounding screws in bonnet |
During paint prep, the grounding screws on either side of the fender (inside of the bonnet) for the headlights were lost. Are these just sheet metal screws (size?), or were there bolts and nuts involved? Also trying to figure out the original location (appears just inside the jack when mounted, and just on the other side of the fuel filler neck) ...
Thanks! _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Feb 06, 2020 1:11 pm Post subject: Re: Grounding screws in bonnet |
Can't answer your questions, but my recollection is that they are like sheet metal screws, not unlike those that hold the door switches to the A-pillars. I'd recommend grinding the paint off and using a star washer to make sure they ground well. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Thu Feb 06, 2020 1:23 pm Post subject: Re: Grounding screws in bonnet |
Yep, they're just small slotted pan head sheet metal or tapping screws. Measuring one from my car it appears they're roughly 3mm by 7mm long. _________________ 1960 Ragtop w/Semaphores "Inga" |
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Thu Feb 06, 2020 3:20 pm Post subject: Re: Grounding screws in bonnet |
This is on a '68, but I guess it shouldn't have changed that much. Poor quality but might help locate.
_________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
bluebus86 Banned
Posted: Fri Feb 07, 2020 1:52 pm Post subject: Re: Grounding screws in bonnet |
Ah - great information. Thanks to all of you! _________________ -Harry
