Braeska Samba Member
Joined: December 18, 2017 Posts: 66 Location: Charleston, SC
Posted: Sun Feb 09, 2020 2:57 pm Post subject: [71 Automatic] Question about timing and altitude |
Howdy, So I just got my car shipped to Salt Lake City from The Bay Area, (now at ~4,000 ft above sea level compared to basically at sea level) And I've re-tuned the carbs and everything best I can and its running okay, but I've noticed its a bit under-powered from what it used to be like, especially going uphill. Also my transmission shifts just a bit harsher with a slight jolt which was unnoticeable beforehand. I've come to observe that my car is SUPER picky with timing when it comes to a smooth shift in the past. (for what reason I still don't quite understand but trust me). So my question is would such a change in altitude affect my timing? I've seen some people say yes and some say no, I'm assuming if it does I shouldn't have to adjust it very much, but if I do would I want to retard or advance it?
It's a shame because I had my timing set so perfect for so long XD. But oh well. I'm running dual 34 ICT Webers and the original fuel injection distributor with vacuum advance and pertronix electronic ignition (i'm too lazy to go look up the exact model # sorry) _________________ || groovy baby yeaaa ||
'71 Squareback (Eileen) |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun Feb 09, 2020 4:04 pm Post subject: Re: [71 Automatic] Question about timing and altitude |
Altitude does affect what your timing can be in the sense that an increase in altitude is an effective reduction in compression ratio. So you can advance the timing more than you could at sea level.
Do some google research, but for some reason the axiom of advance it one degree for each 4000 feet above sea level is sticking in my head, but don't take my word for it.
You may have to re-jet your carbs for altitude, as they may be too rich now if they were initially jetted for sea level. At altitude you're just not getting as much air into the cylinders so there will be a reduction in power. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Tue Feb 11, 2020 7:50 pm Post subject: Re: [71 Automatic] Question about timing and altitude |
Just updating this for anyone who might come across it sometime. I'm by no means an expert in any of this so take it with a grain of salt, but it fixed my shifting issue.
After some trial and error and doing the math, I've found that for an automatic type 3 with vacuum advance, every 900 ft. (+/- 100) in elevation you climb, you can advance the timing by 1 degree.
Don't know if this will be consistent with everyone but it worked for me without re-jetting my carbs. Cheers! _________________ || groovy baby yeaaa ||
KTPhil Samba Member
Posted: Tue Feb 11, 2020 11:46 pm Post subject: Re: [71 Automatic] Question about timing and altitude |
Another argument for late D-Jet FI... automatic altitude compensation! |
Posted: Wed Feb 12, 2020 2:00 am Post subject: Re: [71 Automatic] Question about timing and altitude |
KTPhil wrote: |
I know I should just learn how to throw my old FI parts back on, stupid of me to agree to have had it taken off _________________ || groovy baby yeaaa ||
Bobnotch Samba Member
Posted: Wed Feb 12, 2020 11:47 am Post subject: Re: [71 Automatic] Question about timing and altitude |
sjbartnik wrote: |
You may have to re-jet your carbs for altitude, as they may be too rich now if they were initially jetted for sea level. At altitude you're just not getting as much air into the cylinders so there will be a reduction in power. |
I know when we went out to Colorado Springs (for the Invasion), I stepped down in octane of the fuel I was burning (had been running premium). This seemed to help a little, but I never changed my settings, because I knew that in 5 days I'd be back to normal elevation for the engine.
More than likely, you'll need to re-jet your carbs, and maybe add a smidge of timing for your altitude. Remember, the more above sea level you are, the less air there is to make power. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Feb 13, 2020 3:26 pm Post subject: Re: [71 Automatic] Question about timing and altitude |
Bobnotch wrote: |
More than likely, you'll need to re-jet your carbs, and maybe add a smidge of timing for your altitude. Remember, the more above sea level you are, the less air there is to make power. |
I did end up going down in octane (luckily UT has ethanol free 88 unlike California ) and that did seem to help a bit with power uphill. I'm still getting a little bit of slip when shifting but not nearly as bad as I had it. But I'm moving back to Cali in a few months so i'd rather not mess with the jetting at the moment. Also because i'm still not very familiar with jetting and sizes yet lol.
I've been doing more and more research on the Fuel Injection setup. I still have the old parts and i'm really considering trying to slap them back on now that I have more experience working on my car and more familiarity with how FI works. (The reason we had a mad mechanic throw webers on was because when I had my car shipped back east to SC it wasn't idling and acceleration was suuper slow, it barely had any power, in hindsight it was probably something totally fixable). How hard is it really for a kid like me to set this system back up, undoing everything? Think it's worth trying? _________________ || groovy baby yeaaa ||
gt1953 Samba Member
Posted: Thu Feb 13, 2020 6:59 pm Post subject: Re: [71 Automatic] Question about timing and altitude |
Elevation does take its toll on HP and torque. Running at 6500 feet the majority of the time, like I do jetting and timing have to be adjusted. Some other thing came mind;
As a general rule, a naturally aspirated combustion engine will lose 3% of its power for every 1,000 ft of elevation gain. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Fri Feb 14, 2020 3:04 am Post subject: Re: [71 Automatic] Question about timing and altitude |
Braeska wrote: |
I'm still getting a little bit of slip when shifting but not nearly as bad as I had it. But I'm moving back to Cali in a few months so i'd rather not mess with the jetting at the moment. |
The trans slipping is not a function of jetting, but of vacuum. Don't keep driving it like this, you can burn up the fiber plates, and warp the metal plates in your clutches. before we continue, how are you pulling trans vacuum, and when was the last time you checked the hoses?
Assuming everything is correct, you can adjust your modulator to get rid of the slipping. I know, that I always preach gauges, but not everyone has them. So lets do some gross adjustments to get rid of the slipping, then fine tune it a little. Back the Allen screw of the modulator out 1/2 turn and go for a test drive. Is the slipping worse or better. If its worse turn the screw the other direction.
We want to make large adjustments initially until the trans shifts hard. Then adjust in the opposite direction slowly to find our sweet spot. I would rather have a trans that has a slightly hard shift, than one that slips. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Wed Feb 19, 2020 5:20 pm Post subject: Re: [71 Automatic] Question about timing and altitude |
Sorry I may have misspoke, my transmission isn't quite slipping, it changes gears immediately like it should and stays in gear, but it's just proceed by a slight jerk, most noticeably between gear 1 and 2. 2 and 3 is smoother. I believe my vacuum comes from two hoses connected to the intake manifolds under the carbs. But like I said it seems like my timing is what determines weather or not the transmission shifts smoothly (which I don't quite understand, and i'm sure that's not how it's supposed to be, but it's what I've noticed). A few months ago when I set my timing with a light for the first time it took away that jerk for me but when I shipped my car up to higher elevation it came back. So I was able to smooth it out a bit by advancing my timing but I still have it come back when driving every now and then, mostly when i'm accelerating hard from a stop. If I don't give it as much gas from a dead stop though it shifts smoother.
Where can I actually find the modulator on the transmission? _________________ || groovy baby yeaaa ||
