Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Feb 09, 2020 5:16 pm Post subject: Who sells dual carbs for a 1385 |
Looking for recommendations on a dual carb setup for a 1385cc single port _________________ Glenn
Member #1009
#BlueSquare |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Mon Feb 10, 2020 1:54 pm Post subject: Re: Who sells dual carbs for a 1385 |
Glenn wrote: |
Looking for recommendations on a dual carb setup for a 1385cc single port |
It's ether make your own ..or find some rethwish manifolds there's a guy name danny who sells repops but need a lot of work and are pricey for them ...once in a while 36hp and 40hp dual manifolds come up on the classified ads but I haven't seen any in a while ...thats why folks just make there own ....it would be nice if empi started once again made parts for 36hp and 40hp engine like they did back in the 60s but empi only does the bigger 1600 base engines now days 👎 lol |
Glenn Mr. 010
Posted: Mon Feb 10, 2020 1:56 pm Post subject: Re: Who sells dual carbs for a 1385 |
Erik G wrote: |
which heads? 36, 40, or "okrasa" |
All i remember is they are SP. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 10, 2020 2:06 pm Post subject: Re: Who sells dual carbs for a 1385 |
Glenn wrote: |
Erik G wrote: |
All i remember is they are SP. |
What engine 40hp or 36hp single port... there are two different intake gaskets the 36hp and early 40hp used a 32mm intake gasket and the later 40hp used a 34mm if your using the early 36 and 40hp heads you can open up the intake to the later 34mm but you have to make sure you use the right intake ends the rethwish manifolds I believe are for the early 32mm intake heads if you decide to make your own make sure you use the right intake end and gasket .. |
Glenn Mr. 010
Posted: Mon Feb 10, 2020 2:12 pm Post subject: Re: Who sells dual carbs for a 1385 |
[email protected] wrote: |
Glenn wrote: |
Erik G wrote: |
40hp. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 10, 2020 2:22 pm Post subject: Re: Who sells dual carbs for a 1385 |
Find out what intake gasket your head has ...32 or 34mm you measure the od of the intake gasket and it will be much easier to know what manifolds to get because I notice most of the manifolds folks make are the 32 I hardly find 34mm I don't know why 🤷♂️ but it's much easier to just cut off the ends of the stock manifold that matches the intake and make your own to your own specs like how tall you want them or short ..... |
Glenn Mr. 010
Posted: Mon Feb 10, 2020 2:24 pm Post subject: Re: Who sells dual carbs for a 1385 |
He just told me he's gonna contact Riechert in Germany. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 10, 2020 2:35 pm Post subject: Re: Who sells dual carbs for a 1385 |
I forgot about those lol I guess it's because I hardly see them around much ...i remember hearing they where expensive ...but anyways they have them in the early 32mm gaskets and 34mm ..but it's best to know ahead of time before asking them what head gaskets you have on the heads so that your buddy buys the right ones for his heads 👍 |
Glenn Mr. 010
Posted: Mon Feb 10, 2020 2:38 pm Post subject: Re: Who sells dual carbs for a 1385 |
I don't think cost is a real factor. I'm in the process of building a 2017cc Type 1 with EFI and crankfire for his 65 Bus.
Member #1009
#BlueSquare |
Erik G Samba Member
artguy1 Samba Member
Joined: July 23, 2007 Posts: 33 Location: Seattle, Washington Area
Posted: Thu Feb 27, 2020 3:56 pm Post subject: Re: Who sells dual carbs for a 1385 |
Riechert Kits are available_keep on the lookout. Look in Europe_that's the best bet. My oval has the Riechert Solex 34 PCI carbs and single port manifolds on a 1500cc H-block engine. Very smooth and always come back to idle nicely. Highly recommend!
<sp>
Glenn Mr. 010
Posted: Thu Feb 27, 2020 4:07 pm Post subject: Re: Who sells dual carbs for a 1385 |
You can buy them new from the manufacturer for 1470€. _________________ Glenn
Member #1009
#BlueSquare |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Feb 27, 2020 4:11 pm Post subject: Re: Who sells dual carbs for a 1385 |
sorry for the off topic post, but it sure looks like your taillights are mounted on the wrong sides. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sun Mar 01, 2020 12:16 am Post subject: Re: Who sells dual carbs for a 1385 |
Also fabricated using stock end flanges for heads and carb base, but ended up with a clean installation on a Beetle:
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
Gene Berg carb linkage would probably be easiest to adapt. Use either their universal down rods that would probably need one end cut and rethreaded, or make your own entirely to use the Berg (and/or Weber) ball socket ends. |
gregson1 Samba Member
Posted: Sun Mar 01, 2020 9:49 am Post subject: Re: Who sells dual carbs for a 1385 |
I like the use of the stock intake manifold end flanges because I have three with terminally clogged/burned out heat risers. Might try something like that in the future.
What I finally did was find a good pair of Euro 1200 dual port heads. Allows me to run whatever I want with aluminum intake manifolds. I've dialed in both Kadrons and Webers. I much prefer the Webers and will go back to them this year now that I've found the right manifold length to allow the decklid springs to stay in place on the Ghia. |
