robp1999 Samba Member
Joined: September 11, 2016 Posts: 29 Location: Missouri, USA
Posted: Mon Feb 10, 2020 2:56 pm Post subject: Beetle idle issues |
I'm a little lost trying to get the beetle idling properly when engine temp somewhere between cold and warm. 1776, Engle 100, refurbished German 34pict3 from Volkzbitz, refurbished German 034 SVDA from Bill. 135 main, 65 idle and 75 air correction Jets. Valve clearance set, base timing 7.5 btdc. Car cold starts easy, runs rough for a couple minutes then smoothes out. As it warms up as soon as the choke releases and it comes of the high idle cam it doesn't want to idle until fully warm. When warm it idles at 900rpm but will drop below that momentarily as the throttle is released then recover when pulling to a stop. Do I start with adjusting the choke a little tighter? I'm at a loss here. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Feb 10, 2020 10:28 pm Post subject: Re: Beetle idle issues |
I am betting the throttle plate stop screw is incorrectly set. I would start with setting the basics. Check for any vacuum leaks. Then go through fine tuning. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Feb 11, 2020 4:19 am Post subject: Re: Beetle idle issues |
Okay I'll start from the beginning. I've never checked the throttle plate stop screw. |
beetlenut Samba Member
Posted: Tue Feb 11, 2020 7:20 am Post subject: Re: Beetle idle issues |
I have that same carb and distributor combo from those same two people. I started the tuning process by backing the throttle plate stop screw out until it was not touching the fast idle cam at all. You need to make sure the throttle plate is closing completely so that it covers the bottom most progression hole in the throat of the carb. The best timing set-up I got was with vacuum hose off and plugged, with a timing light at 30-32 degrees at max advance. This produced a strong high idle that I was able to then tune the carb with (small screw), and then set my idle with the bypass screw. Then once warmed up, I screwed the throttle plate stop screw in until it barely touched the bottom cam of the fast idle cam. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
74 Thing Samba Member
Posted: Tue Feb 11, 2020 7:51 am Post subject: Re: Beetle idle issues |
What kind of exhaust are you running and are your preheaters cleaned and not clogged?
As mentioned above, start by warming up the engine and adjusting the carb properly. |
Posted: Tue Feb 11, 2020 9:55 am Post subject: Re: Beetle idle issues |
Vintage speed exhaust and preheaters work great |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Tue Feb 11, 2020 10:47 am Post subject: Re: Beetle idle issues |
robp1999 wrote: |
Yes. It sounds like your choke is disengaging too early.
The choke adjustment is a duration adjustment. Closing the choke further means it will take longer for the heating element to warm up enough for the choke butterfly to go vertical. Yes it could also mean the throttle arm screw will sit on a taller step of the fast idle cam, but that is just happenstance.
Adjust your choke first thing in the morning before you turn the ignition switch ON. Pull the throttle arm to release the fast idle cam and allow the butterfly to snap closed. Loosen the three screws holding the choke coil in place and rotate the choke butterfly a bit more closed. No need to fully close the butterfly unless you need it to rotate that far, in some cases you may need to rotate even past the point the butterfly fully closes. Just remember more closed means longer time on the choke.
Start the engine and take it for a drive immediately. No need to warm it up in the driveway. At the 1st stop the choke+fast idle cam should keep the idle rpm up so it won't die. As the engine warms up the cam will drop to progressively lower steps, but still keep the idle from stumbling when you come to a stop. Only after the engine is fully warmed up should the choke turn OFF.
Once the morning gets warmer you will need to close the choke even more to keep it ON long enough to warm up the engine. _________________ AshMan40
Posted: Tue Feb 11, 2020 5:33 pm Post subject: Re: Beetle idle issues |
I have my son warm it up in the driveway since his commute is really short plus it misfires for about a minute when first started. I'll adjust the choke tomorrow morning and see what that does for us. I'll mark it so I can go back if it doesn't help. Trying to do one thing at a time so I don't get lost. We will get the cable for our air fuel gauge next week and gain real data to go by if we can't get it figured out before then. Thanks so much for all the responses. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Tue Feb 11, 2020 5:53 pm Post subject: Re: Beetle idle issues |
On these carbs the idle screw that contacts the fast idle cam is NOT used for setting the idle speed when the engine is fully warmed up. You may be aware of this, if not check youtube for setting the idle speed. |
Posted: Tue Feb 11, 2020 6:00 pm Post subject: Re: Beetle idle issues |
Oh yeah I'm cool. Tim gave me a tuning sheet with the carb. I bet it's the choke. I checked for vacuum leaks last night and it runs pretty great when warm. |
Posted: Tue Feb 11, 2020 6:28 pm Post subject: Re: Beetle idle issues |
robp1999 wrote: |
Besides the same carb and distributor as you have, I'm also running the Vintage Speed SS exhaust as you. I'd be interested in hearing more about the cable for your air fuel gauge you have, and the set-up you're planning on using it on. I assume you're using one of the bungs on the muffler. _________________ scrapyards are for quitters
Wetstuff wrote: |
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6616 Location: Houston, Texas
Posted: Tue Feb 11, 2020 9:49 pm Post subject: Re: Beetle idle issues |
You should get your rebuilders on an email together to help with the diagnosis. They built the units. They know all about them.
Sometimes the timing will kick back when the diaphragm in the vacuum canister gives way after being under pressure.
Do you have a gold or a silver vacuum canister? _________________ www.vwnos.com [email protected]
heimlich VWNOS.com
Posted: Wed Feb 12, 2020 1:09 pm Post subject: Re: Beetle idle issues |
Here are pictures of what the vacuum canister looks like. Note the Bosch stamp on them.
Posted: Thu Feb 13, 2020 4:37 am Post subject: Re: Beetle idle issues |
Mine is silver but not Bosch. Good idea to get the rebuilders on a group email. Thanks for the advice.
Xevin Samba Member
Posted: Thu Feb 13, 2020 10:00 am Post subject: Re: Beetle idle issues |
Did you ever go through the choke adjustment procedure? Out of curiosity and perhaps unrelated. What style of air cleaner are you using? Do you have working thermostat and flaps? What coil and have you tested it lately? Did you set your timing with a timing light with hoses off? What are the setting details? What’s the timing numbers with vacuum hose on? _________________ Keep on Busin'
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Thu Feb 13, 2020 10:26 am Post subject: Re: Beetle idle issues |
Tightened choke which made it a little better. We use a factory air cleaner with warm air hose connected. Functioning flaps and thermostat. New Bosch blue coil. Timing with strobe light at idle is 7.5btdc with or without vacuum hose connected. at full advance it's around 42btdc with hose connected. |
Posted: Thu Feb 13, 2020 12:16 pm Post subject: Re: Beetle idle issues |
robp1999 wrote: |
Retest for total advance with the vacuum advance hose disconnected and plugged.
The idea of testing/setting the timing advance at high rpms is to confirm the mechanical/rpm advance does not over advance into detonation.
For a 4-stroke gas powered combustion engine, you generally do not want rpm-based ignition timing advance (mechanical advance) to exceed more than 35BTDC total. Above 3000-3500rpm the flame front in the combustion chamber will travel faster due to turbulence so additional ignition advance is not needed. Increasing initial+mechanical advance beyond 35BTDC will likely result in detonation if load is added at the higher rpms (eg. accelerating or going up hill). Because of things like age, oil bypassing the ring, chamber design and air-cooling... the max safe initial+mechanical advance total timing for your acvw should be around 28-32BTDC. You need to disable the vacuum advance to measure this.
The reason the ignition timing with vacuum advance can reach higher values (like 42BTDC) is because intake-based vacuum advance distributors (SVDA and DVDA) advance the ignition timing under low engine load (high intake vacuum) and retard (take back) that timing when the engine is under load (low vacuum). Your testing was done in the driveway with nothing loading the engine and does not confirm the under load ignition timing is set safely in the 28-32BTDC range.
Measuring the ignition timing at high rpms with the vacuum disconnected simulates a load (zero vacuum) and confirms the ignition timing remains at or below a safe 32BTDC total timing advance. _________________ AshMan40
wcfvw69 Samba Purist
Posted: Fri Feb 14, 2020 7:20 am Post subject: Re: Beetle idle issues |
Hello Rob,
Let Tim and I know how your doing via email. I hope some of the suggestions we both sent you via email helped you dial it in. You have a nice looking engine. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Feb 19, 2020 9:19 am Post subject: Re: Beetle idle issues |
Okay guys got to check things and found adjustments were all about right. I fine tuned the idle mixture, double checked timing, looked for any vacuum leaks, pulled idle jet and flushed it, and tightened the choke a little. To be honest everything got better when the temperature rose above 20°f. I'm having him drive around the neighborhood to warm it up and he has had no issues since. Seems it's the little things sometimes. Thank you guys very much for your help. I can't recommend Bill and Tim enough for their services. |
Posted: Wed Feb 19, 2020 9:26 am Post subject: Re: Beetle idle issues |
Glad you got it! _________________ Jimbo
TDCTDI wrote: |
