Posted: Fri Feb 14, 2020 2:14 pm Post subject: Re: RMW Aluminum FUEL Expansion Tanks or Stock Replacement |
tencentlife wrote: |
I'm sure you've pointed that out before, Mark, and I just as surely forgot, but thanks.
Nonetheless, considering only a small minority of vans got factory fuel heaters, a tank with the missing volume restored would have been nice to have standard, and the old style offered with the heater options. |
I have wondered if anyone has modified their stock tank to get back the lost volume? |
tencentlife Samba Member
Posted: Fri Feb 14, 2020 2:24 pm Post subject: Re: RMW Aluminum FUEL Expansion Tanks or Stock Replacement |
I grabbed one at a junkyard years ago to experiment with welding in a roof over the saddle that would increase the volume. Then I moved into my Syncro and that tank's still sitting behind the shop, just wasn't an issue for me any more. But the 2wd range is not great, it would be a boon to those drivers. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
bluebus86 Banned
Posted: Mon Feb 24, 2020 9:38 pm Post subject: Re: RMW Aluminum FUEL Expansion Tanks or Stock Replacement |
Anyone checked to see if new tanks are available from VW? and at what price? |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Sun Jun 07, 2020 8:48 am Post subject: Re: RMW Aluminum FUEL Expansion Tanks or Stock Replacement |
I just installed the RMW tanks this morning. They are beautifully made and fit like a charm. Yes they are expensive, but my plastic tanks were toast. Plenty of room in the wheel well without removing the wheel to get the job done. _________________ -- 1987 Westfalia automatic (Captain Vino) |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Mon Jul 26, 2021 12:05 pm Post subject: Re: RMW Aluminum FUEL Expansion Tanks or Stock Replacement |
Perales wrote: |
I just installed the RMW tanks this morning. They are beautifully made and fit like a charm. |
Wifey had a great year at work and jumped into "let's bling out the van" mode . Along with some mundane replacement parts she also bought us the RMW expansion tanks.
Mine did not fit like a charm. I suspect that the OEM plastic tanks have a bit of flex to them that allows them to "adjust" for different thicknesses of undercoating applied to the wheel wells. The problem I ran into was that tightening the nut on the single mounting bolt would pull the "socket" on the rear of the tank out of the indent on the passenger's wheel well. I had to cut away some undercoating which is a big concern - gonna need to reapply that - and add a couple washers between the tank and the body. The driver's side went better but I still had to add a washer or else the tank would rotate enough to pop out of the indent. A rubber mallet came in handy too. I'm a bit worried about the metal-on-metal contact with the plug/socket over time too.
I think it's a great product, especially with no other options for broken OEM tanks, but just know that this job can take way longer than you may think. Maybe one of those "don't fix what ain't broke" kinda things. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
jlrftype7 Samba Member
Posted: Mon Jul 26, 2021 12:13 pm Post subject: Re: RMW Aluminum FUEL Expansion Tanks or Stock Replacement |
Mine fit with no issues. Since it's Aluminum being shoved up against painted Steel, I added grease on that 'socket' or 'tab' at the rear to help lessen the issue of dissimilar metal corrosion or trapped water.
I then sprayed a Body Cavity Wax all over the tanks once they were fully hooked up, this way any touch ups later on will be easy and that wax really sheds the water too, which is nice since the tanks are basically Fender Splash Shields with either stock versions or aftermarket due to their location near the front tires.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
