pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Feb 13, 2020 5:39 am Post subject: 65 Bug |
Just got a 65 Bug. While it is mostly solid, needs its ass fixed. What other model years are compatible with it regarding the deck lid, the rear apron clip and the driver’s side rear fender?
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Thu Feb 13, 2020 5:46 am Post subject: Re: 65 Bug |
Well, any pre 67 deck lid, fender, and apron will fit but wont be correct. The deck lid needs to be a 65-66 style and I’m not sure about the fender and apron so dont quote me, but I think any fender and apron up to 67/68 will work but you still want to get a rear clip as close as possible to the OG year. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Feb 13, 2020 7:12 am Post subject: Re: 65 Bug |
Rear apron is the same shape from I believe 62-66, however the latch for the deck lid changed in either 64 or 65 (push button vs tee handle).
The 62-67 fenders are the same due to the rear light assemblies. Earlier or even later fenders would fit though, would just have to modify for lights.
67 apron and deck lid is a one year only item
*Not sure of rear apron change...maybe 60 is the year it changed
pyrOman Fire Master
Posted: Thu Feb 13, 2020 7:15 am Post subject: Re: 65 Bug |
Thanks! Been perusing the gallery and does look like the apron/lid combo it’s the same for 65/66. The fender has a broader range but I will take some measurements since the ones on my 70 bug seem to be one slightly wider than the other. _________________ Some people are so busy being clever they don't have time enough to be wise. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Feb 13, 2020 10:03 am Post subject: Re: 65 Bug |
As far as the apron goes, if you have in incompatible year you can change the catch. Not that big of a deal. Your rear fenders are pretty interchangable with exception of over rider holes and the size of the bumper bracket cut out. I have used later fenders and fabbed plates to reduce the bumper cut out. Not hard to do. _________________ D-Dubya Manx clone - 63 Short pan,1914.
pyrOman Fire Master
Posted: Thu Feb 13, 2020 1:07 pm Post subject: Re: 65 Bug |
All fenders on this one have already been sealed up for the "euro look". _________________ Some people are so busy being clever they don't have time enough to be wise. |
TimD_66 Samba Member
Joined: February 01, 2005 Posts: 1170 Location: San José, California
Posted: Fri Feb 14, 2020 12:24 pm Post subject: Re: 65 Bug |
Any year parts would technically "fit" but assuming you want it to look correct for '65, you need:
a late '64 to '66 rear apron (for push button latch),
'65-'66 decklid (same shape but if you get a '66 on it will have 3 holes in it for the "1300" script which you could easily fill,
'62-'67 fenders (other year fenders would fit just as easily, but you'd have to put holes in the right place for the tail light). _________________ '58 Ragtop bug - 2276T (Re-assembly in progress!)
'65 13 window deluxe bus (SWR/BG)
'04 VW R32 - 3.2L VR6
B.L.T.N.
N.A.G. |
KTPhil Samba Member
Posted: Fri Feb 14, 2020 1:05 pm Post subject: Re: 65 Bug |
If you are looking for correct '65, those earlier front turn signals would be changed. But they look fine as-is. |
Posted: Fri Feb 14, 2020 3:09 pm Post subject: Re: 65 Bug |
KTPhil wrote: |
NAH...they should be changed or else some asshole at a car show is gonna point out that you have the wrong turn signals on the car.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
pyrOman Fire Master
Posted: Fri Feb 14, 2020 8:17 pm Post subject: Re: 65 Bug |
It’s all good! This car is a flipper. Already have a motor to go in it. Probably ran like total shit though. Just replaced all solid motor mounts and the slamma jamma scrapeORamma narrowed front beam was so slammed that the only “give” it had was the tiny tires!
Iffin I don’t find a decent rear clip tomorrow, I’ll probably just order a new apron and sides for it. They have all that stuff new now. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Sat Feb 15, 2020 8:37 am Post subject: Re: 65 Bug |
pyrOman wrote: |
Iffin I don’t find a decent rear clip tomorrow, I’ll probably just order a new apron and sides for it. They have all that stuff new now. |
ya, but most of the new stuff is either junk, or expensive. i would keep looking for a nice original unit. nothing beats factory quality and fitment. i bet if the future owner finds out you replaced that sheet metal w/ run of the mill khloker holme(or however you say it) junk they're not gonna be pleased. |
pyrOman Fire Master
Posted: Sun Feb 16, 2020 8:35 am Post subject: Re: 65 Bug |
Ok, you go with that!
If I was ever to try and fool anyone, why post these details for all to see. The sides of the rear clip with the bumper mounting fixtures are totally rusted through. An og clip would be just as roached. It’s actually a blessing that reproduction parts are available nowadays. And FWIW, I scored on a very decent deck lid and an og fender at the OCTO yesterday. Once I get done with it feel free to not buy it. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Sun Feb 16, 2020 9:25 am Post subject: Re: 65 Bug |
pyrOman wrote: |
If I was ever to try and fool anyone, why post these details for all to see. The sides of the rear clip with the bumper mounting fixtures are totally rusted through. An og clip would be just as roached. It’s actually a blessing that reproduction parts are available nowadays. And FWIW, I scored on a very decent deck lid and an og fender at the OCTO yesterday. Once I get done with it feel free to not buy it. |
ok, then good job doing it the right way. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Mon Feb 17, 2020 7:43 pm Post subject: Re: 65 Bug |
Now that you have a good used rear fender, how about trying some undenting on your damaged one after you remove the taillamp assembly? The large dent looks imposing, but might be workable. Try setting the fender upside-down on the lawn, wearing some thick-sole work boots, and stepping around the perimeter of the dent. Your weight should press down the dent downward/outward. Don't jump in the center all at once- try working your way inward from the outer edges of the dent.
Or, set the end of a baseball bat along the dent edges, and pound on the grip end with a hammer or just by pounding the entire bat down. Work your way around the perimeter, then spiral inwards.
Once you have the majority of the dent pressed out, you can continue with hammer/dolly. If you don't have a dolly, a slightly curved heavy metal object such as a tree cutting wedge could work, though your hand will get tired holding it.
You may get reasonable results. |
pyrOman Fire Master
Posted: Tue Feb 18, 2020 7:52 am Post subject: Re: 65 Bug |
Will probably try that anyway, but did get a replacement og fender which has been cleaned to bare metal showing only some surface rust and no dents. Will be ordering a new apron and both sides. Here’s what I’ve got so far...
pyrOman Fire Master
Posted: Fri Feb 28, 2020 11:05 am Post subject: Re: 65 Bug |
Was a bitch to "fit" the sides and apron!
As I did with my 70, the apron is a bolt-on/removable set up. Makes for much easier engine drops!
Also, pounded out the left fender. May fix it instead of using the bare one which is straight but does have some rust issues.
Other stuff done: new brake hoses, cylinders and master, rear bumper installed. _________________ Some people are so busy being clever they don't have time enough to be wise. |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
pyrOman Fire Master
Posted: Fri Mar 06, 2020 11:36 am Post subject: Re: 65 Bug |
Here's more pix...
Replaced the driver's side window regulator
pyrOman Fire Master
Posted: Wed May 13, 2020 4:03 pm Post subject: Re: 65 Bug |
Not that I don't spend most of my time in the Garaj Mahal anyway but with the cornyvarious house arrest nonsense I've been dicking with the Green Bug enough to be ready for sale!
Got it all pretty much sorted out, all lights work, brakes, engine fires right up and runs like a bat out of hell! Also finally got the paint done AND buffed.
