frankthetank81 Samba Member
Joined: November 26, 2012 Posts: 238 Location: Belleville, Mi
Posted: Thu Feb 13, 2020 6:57 am Post subject: Freeflyer Feasable? |
So once I get my 36hp engine rebuilt, I was wondering if I could do the "Freeway Flyer" 4th gear. My trans is leaking everywhere, so it needs to come out, plus I would really like to have a synchro for first.
Looking at doing the all the period correct hop ups on engine, Okrasa Dual carb and head kit, storker crank, cam and bigger slugs & jugs
Basically I just want to be able to take this thing on the highway as needed, and cruise at 65-70 with out pushing the car to it's limits.
Looking at the ratio difference, between a normal 4th and the flyer, it is not as big of a difference as I thought it would be. 4th gear normal is .89 the flyer is .82
Any advice is appreciated |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Thu Feb 13, 2020 10:34 am Post subject: Re: Freeflyer Feasable? |
Do you have a splitcase transmission still? The stock splitcase already has a .82 4th and 4.375 r&p which makes it slightly taller than a 4.125x0.89 late model trans. As far as I know the 4.125 and 3.875 tunnel case r&p won't fit the splitcase trans though. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
slalombuggy Samba Member
Posted: Sat Feb 15, 2020 3:18 pm Post subject: Re: Freeflyer Feasable? |
The drop from a .89 to a .82 with the same r/p isn't worth the effort. And to go to a 4.12 with a .82, you'll need more engine. If you are going to switch to a tunnel case, I would just go with stock gearing and a 4.12.
brad |
