UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Feb 16, 2020 11:35 am Post subject: Re: 1+3 spark plug access |
Did that 40 years ago.
Top wrench.
_________________ Glenn
Member #1009
#BlueSquare |
Dale M. Samba Member
Posted: Sun Feb 16, 2020 11:37 am Post subject: Re: 1+3 spark plug access |
People have been known to put access doors on inner panel for just that purpose....
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Feb 16, 2020 12:26 pm Post subject: Re: 1+3 spark plug access |
Next time you have the engine out and a little time on your hands,
http://www.hookyspanelshop.com/our-panels/hipacs.html
I'm thinking of doing this.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Posted: Sun Feb 16, 2020 12:52 pm Post subject: Re: 1+3 spark plug access |
UK Luke 72 wrote: |
Although I'd bung it personally |
Did it.
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun Feb 16, 2020 1:16 pm Post subject: Re: 1+3 spark plug access |
Full access:
I had to because my injectors stick out, too.
I did the little hole with bung for my carbed beetle. |
Posted: Sun Feb 16, 2020 1:53 pm Post subject: Re: 1+3 spark plug access |
UK Luke 72 wrote: |
FreeBug wrote: |
Full access:
Decent!
Why not just put the injectors inboard? |
But then they're not pointing down to the back of the valve....and I'm using DCNF pattern throttle bodies, not so many options. |
Posted: Sun Feb 16, 2020 1:59 pm Post subject: Re: 1+3 spark plug access |
When I queried injector placement, the consensus was that it didn't really matter. I expect low speed/off idle to be slightly affected but I guess the uninformed (me) could argue the higher up/inboard injector has far longer to fully mix with the intake.
Who knows, several ways to skin the cat.
FreeBug wrote: |
UK Luke 72 wrote: |
FreeBug wrote: |
Full access:
Decent!
_________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172 |
Posted: Sun Feb 16, 2020 2:01 pm Post subject: Re: 1+3 spark plug access |
UK Luke 72 wrote: |
FreeBug wrote: |
UK Luke 72 wrote: |
FreeBug wrote: |
Full access:
Decent!
Look where the car industry puts them... |
Posted: Sun Feb 16, 2020 2:39 pm Post subject: Re: 1+3 spark plug access |
I don't feel knocked at all! I think you and others are right. It doesn't really matter. I imagine the industry does it for emissions?
Anyway, it forced me to make those access covers, and I am so happy I did, plug changes are a doddle, once you remove the rear tires (sorry, tyres), which I do anyway to adjust valves. Almost makes it fun, and keeping the skin on your knuckles is the "in thing" these days. I don't even hardly ever get burned these days, either. Boring. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sun Feb 16, 2020 5:38 pm Post subject: Re: 1+3 spark plug access |
The closer you get the spray to the valve, the more control you can have over injection timing. That’s if you have a cam sync. Without it, you sometimes end up spraying the closed valve, so you waste more fuel.
And btw, I just learned this, as I’m getting into injection for he next engine. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sun Feb 16, 2020 11:10 pm Post subject: Re: 1+3 spark plug access |
bugguy1967 wrote: |
And btw, I just learned this, as I’m getting into injection for he next engine. |
Are people now often running sequential injection? I'm still on old-fashioned batch fire. Oh, well. |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 977 Location: Las Vegas, NV
Posted: Mon Feb 17, 2020 7:28 pm Post subject: Re: 1+3 spark plug access |
I have a cheap stamped sheet metal spark plug socket I bought off ebay. It's the style where they take a tube and expand one end into a hex, the other end just has a couple holes for you to put a screw driver through to turn it. I've had good lock with that on dual carb setups and an unmodified engine bay. PITA but also 100% do-able. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
Posted: Tue Feb 18, 2020 3:14 am Post subject: Re: 1+3 spark plug access |
petrol punk wrote: |
I have a cheap stamped sheet metal spark plug socket I bought off ebay. It's the style where they take a tube and expand one end into a hex, the other end just has a couple holes for you to put a screw driver through to turn it. I've had good lock with that on dual carb setups and an unmodified engine bay. PITA but also 100% do-able. |
That sound like the stock plug "socket" in the "modern" tool kit. Does this mean you manageto pull plugs without taking out parts of the intake Carbs, manifolds, or both)?
P.S. When i read "stock 36 hp '56 European delux oval" I started to drool so
bad...... you owe me a new computer! Where's the envious emoji? |
raygreenwood Samba Member
Posted: Tue Feb 18, 2020 11:06 am Post subject: Re: 1+3 spark plug access |
bugguy1967 wrote: |
Yes....
And yes....injector spray angle DOES matter. But there is no rule for it. You will find engines that run at different rpms, have different port velocity ....use paired injection, batch fired injection, constant injection.....have different load sensing.....MAP, MAP + MAF or hotwire or hotwire + MAP.....have vacuum indexed fuel preszure or not.
All of these things affect running from millisecond to millisecond....which affect airflow and map....which affect signal and fueling. Leverage all of that with cam and rpm range (say constant high rpm versus light to light,street driving).......and all or that makes a difference when leveraged by injector position and spfay pattern.
Anyone who tells you that one way is ALWAYS correct....will be right on some applications and totally wrong on others.
Spray pattern width, droplet size and distance from valve and port wall can all make a difference.
The problem with valve carbonizing in modern direct injection engines....some 9f them are solving this with "dual injection"....meaning a normal set of low pressure upstream injectors that only run at certain times or cycles.....just for keeping the valves clean. Ray |
