raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Mon Feb 17, 2020 1:08 pm Post subject: Re: GD engine with auto vs. standard cam installed |
SGKent wrote: |
this is the absolute last time I'll waste my time saying this. The cam profile in the Webcam 142 is the profile that Porsche used in the high performance 2L street engine for the 914-4 and 912e know as the GA engine.* It is a 100 HP engine from the factory. They discontinued using that cam because it was a tad bit too aggressive for purists who wanted a perfectly idling engine, and it caused a little hunting and lower vacuum signature at idle. My Webcam 142 shows these signs of hunting and reduced vacuum as well but you have to be a tuning freak at idle to notice it. The Webcam 73 and 86 are even more aggressive and don't belong in a street bus regardless whether you have one or are considering it. If you plan to street race your bus put one of the 73 or 86 in it, add headers and large dual carbs, and you can keep it making lots of power when you want to go fast, but off idle the webcam 142 will run better.
The webcam 142 has a split duration of I 247/ E 242 (peak 4800 RPM +/-)
The webcam 73 has a non-split duration of I 262 / E 262 (peak 5200 RPM +/-)
The webcam 86 has a non-split duration of I 273 / E - 273 (peak 5500 +/- RPM)
In contrast, the stock cam your bus came with peaked at 4200 RPM
Compared to us old farts, Carlos is a young and immature guy. Go with his cam if you believe like he does, that the old guys don't know sh_t.
*the only reason I know this for a FACT is because I found a NOS GA cam in 2009, and took it to Steve at WebCam to see how the profile compared to their cams. It turned out to be the exact same profile as the stock one used to set up the 142. If you degree a stock GA cam, and a Webcam 142 degree by degree and lift by lift they are the same profile exactly. The ramps, slope, degree and lift are the same. That explained to me why my bus pulls so strong in the upper RPM range and why the idle hunts a little. Keep in mind that the ECU in a late FI bus has a rev limiter in it that cuts off fuel to the injectors at redline. You can't push a late FI engine past that cutout. Doing so wouldn't be a bright idea anyway with the long stroke and well aged by now cast iron flywheel and cast aluminum fan. |
Actually the web 73....maxes....at 5200 rpm. Not exactly "peak". Thats a poor descriptive word.
Its best usable hp and torque combination for a street vehicle is in about the 4500-4700 range.
It also has a bit of strange idle....but again....not unmanageable. Your results will vary with gearing, weight and tires.
A lot of people have succesfully used 73 in buses. I don't know enough about the 73/86.
Is this saying that the 142 may not be a better cam? Not at all. Just saying the 73 is known to be better than virtually anything stock. It will work well in a bus. It has before.
Also remember that the 142.....if it is as you say.....virtually the same as the one used in the "EURO" 914 2.0....has an augmented intake valve opening event timing point.....to be used with the 2.0....which all had D-jet. 😉
That intake valve timing pattern is virtually identical to that used on the web 73.... which came from the V-grind originally used with 1.7L type 4 914s, 411 and 412 and later the Z grind used on the 914.
Regardless of which 914 2.0L used what cam.....if it used D-jet.....it had some variation of this specific cam timing. That timing is the prime cause of the odd idle. Ray |
SGKent Samba Member
Posted: Tue Feb 18, 2020 2:32 pm Post subject: Re: GD engine with auto vs. standard cam installed |
There is so much misunderstanding on cams in this site.
Car owners want free power. Meaning, someone wants to choose an item, or a bolt on accessory that makes them power. It is and isn't that easy.
To make more power the car engine needs more air. Specifically it needs Oxygen to make more power. The more oxygen that passes thru it the more power it has. The simplest fix is move to a spot below sea level like Death Valley, or the area around El Centro CA. Move to a cold dry climate. The air is denser in both places.
So what do people do otherwise - they add turbos, they add super chargers, they change cams, they go to larger displacement engines, they add nitrous oxide to the engine etc.. Any of those things gives an engine more oxygen.
What you don't have going for you in your 1978 FI bay. First you have an air snorkel slightly larger than a quarter for all the air to flow into the engine. If you look at the back there are holes drilled in the housing. My guess is VW figured they had to find a cheap way to get more air into the air cleaner - answer, drill holes. The air cleaner entry is less than optimal. Next you have a weirdly shaped plenum once the air get thru the funky AFM and throttle body. Air has to do all sorts of contorsions to get thru that plenum. Then it runs down these lanky inlet runners, thru the cast ports and into the cylinder. The air that makes it burns with the addition of fuel to it, and it exits out these funky ports into a poorly constructed exhaust system. The F-pipes are anything but streamlined. Then comes a 180 degree turn thru a loop VW added to help give the exiting air longer to burn off the HC, CO, then thru a restrictive heater box, and out into a funky muffler. A very long path exists for the exhaust.
What this means is that your engine has the practicality of a tractor engine. It was designed to operate at a low RPM. If it were designed to operate at a higher RPM the intakes would be shorter and tuned to the higher RPM, and the exhaust route would be larger in diameter, less restrictive, and tuned to a higher RPM. You would not have heat provided by an exhaust system, and if you did it would be designed completely different.
Now, as the engine goes faster and faster the air needs to begin its journey in and out of the engine sooner and sooner. So the camshaft lobe duration gets lengthened, advanced, and has more overlap. That is great at higher RPMs but it sucks at lower RPMs. Modern cars have multiple camshaft lobes that are designed to operate at different RPMs. We have a single cam lobe because we are a 50 year old technology. But there is this guy from the 1950's named Eddie Iskenderian (Isky Racing Cams) who proved that you can harness the exhaust and intake pressure waves to go faster, just by timing when the valves open and close. It's just like pushing a kid on a swing. If the column of air in the intake system is moving towards the valve, you open the valve at that time and shut it before the wave heads back out into the intake from whence it came. That pushes more air into the cylinder which makes for more power. Then on the exhaust side you open the exhaust valve as the exhaust pressure wave is moving away so it pulls (scavenges) more of the exhaust gas, which makes more room for the incoming charge. If you do it well enough it even creates a little extra vacuum that helps pull more air into the engine.
So to do these things you have to choose a cam that will operate at the RPM you plan to run the engine. Choose wisely. If you choose a cam designed to operate at too high an RPM you will be pushing against the kid on the swing as he/she arrives and in effect stopping them, lowering performance. I have no gripes with the WebCam 142 on a 2L engine. I highly recommend it. Probably it is even a little too much cam but there isn't a cam that works between a stock GD bus cam, and a stock GA European Porsche cam. The 73 and the 86 are designed for higher RPM than the 142 is so they work against themselves at a lower RPM. Will you notice it, probably not but I would in a bus. If I was building a rally car to drive fast on country roads, I'd run higher compression than a bus has, a longer duration cam, dual carbs, a nice header system, and no heat. I'd probably find a 5 or 6 speed that fit it and a complete IRS suspension. Rims would be light, all brakes would be sprung and up on the trans etc.. But gee, this is a 50 year old VW bus so I have no interest in tying up my money in something like that.
It's a free country and people should buy the cam they think is best for them. But that said I've written all that you need to know in choosing a cam duration so unless you have lots of time and a dyno at your disposal, and a track for time trials, you won't be able to find the perfect cam. I won't name names but there are people who say X cam tested for blah blah blah, but when you have been around a long time you run into people who know who gets what where, and what it is. You'll be happy with the 142 on a 2L bus. But, I doubt if you would be happy with it on a rally or street racing 912e or 914-4, or especially a dune buggy you wail on. The vacuum signature at idle and very low RPM will fall with the 142 compared to the stock cam so you may need to richen the AFM a notch. If you have a 1700, or 1800 it will be geared lower than a 2L so with the carbs and less restrictive exhaust than the FI 2L you may want the 73. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
