Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Mon Feb 17, 2020 1:37 am Post subject: 912 front suspension - adjustment block |
Hello,
i'm still struggling a bit to understand the front suspension adjustment block and how it actually stays on the car?
As far as I can see it just slides in from the end over the splined bar, bit there is nothing to prevent it from working its way back out of it?
There is a circlips which is basically preventing the bar to slide out, but nothing which really attaches the block to this bar?
Thanks!
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Joined: December 28, 2016 Posts: 280 Location: atlanta ga
Posted: Mon Feb 17, 2020 9:26 am Post subject: Re: 912 front suspension - adjustment block |
there is a circlip and a cap and when under tension will not move nor slide out |
Posted: Tue Feb 18, 2020 8:55 am Post subject: Re: 912 front suspension - adjustment block |
[email protected] wrote: |
The circlips is there indeed, but would not prevent the cap from sliding towards the back of the car.
Just hoping indeed the tension will keep it all together (even on cobblestone roads etc)
Thanks! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
