How do I remove the horn button of the 912 steering wheel?
Peter - Belgium
Peter - Belgium is offline
PostPosted: Mon Feb 17, 2020 1:30 am    Post subject: How do I remove the horn button of the 912 steering wheel? Reply with quote
On my 68 912 the horn is very sensitive and wants to go off at any moment it feels like.. .so need to remove the circular horn button. What would be the right way to do this before I start breaking it?
I though it just needed to rotate counterclockwise and should come off... but sofar I had no luck with this?
the one I have looks like:
Thanks!
Peter
356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
Ovally
Ovally is offline
PostPosted: Mon Feb 17, 2020 10:56 am    Post subject: Re: how do I remove the hornbutton of the 912 steeringwheel? Reply with quote
http://forums.pelicanparts.com/porsche-911-technic...moval.html
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Tue Feb 18, 2020 8:49 am    Post subject: Re: how do I remove the hornbutton of the 912 steeringwheel? Reply with quote
Push in and turn counter clockwise 1/4 turn and it will pop off. Make sure that when you reinstall that you have a good and soft horn boot, and you press down on the button as to compress the horn stalk or you will break it
Peter - Belgium
PostPosted: Tue Feb 18, 2020 8:58 am    Post subject: Re: how do I remove the hornbutton of the 912 steeringwheel? Reply with quote
Thanks! will give it another try since before it did not want to move (and I did not want to force and break it). might need some more force though...
Once removed I hope I can find the cause of that very sensitive horn? You think it can be that horn boot that could have gotten bit too hard over time? or any other item anyone can think of?
Peter - Belgium
PostPosted: Wed Feb 19, 2020 1:54 am    Post subject: Re: how do I remove the hornbutton of the 912 steeringwheel? Reply with quote
got is off:-) and found that the plastic of that little copper earth-part to be cracked... so guess that is the cause of the very sensitive horn activity!
time to order and replace!
[email protected]
PostPosted: Thu Feb 20, 2020 9:02 am    Post subject: Re: How do I remove the horn button of the 912 steering wheel? Reply with quote
we have plenty on the shelf
