Question o n the Mount for a 1970 VW Bus
HarryFD
HarryFD is offline
PostPosted: Thu Feb 20, 2020 12:07 am    Post subject: Question o n the Mount for a 1970 VW Bus Reply with quote
Today, I was trying to find out why my reverse lights are not working (still have more work to rectify). When looking at the reverse switch on the transmission, I noticed that the lower bolt that connects the transmission mount to the nose of the transmission was loose. I tightened it up.
How do I access the upper bolt to check/tighten as needed?
1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2003 BMW Z4 3.0i
2009 MB C300
kreemoweet
kreemoweet is offline
PostPosted: Thu Feb 20, 2020 7:04 am    Post subject: Re: Question o n the Mount for a 1970 VW Bus Reply with quote
Those bolts are tightened before the trans is installed. Hopefully.
'67 bug: seized by the authorities
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Thu Feb 20, 2020 4:12 pm    Post subject: Re: Question o n the Mount for a 1970 VW Bus Reply with quote
check to make sure the fuse in the engine bay isn't blown for the rear lights. The wire comes off the coil.
the large black thing near the coil. Holds a fuse. I would check there first. Near the left blue arrow.
HarryFD
HarryFD is offline
PostPosted: Thu Feb 20, 2020 4:58 pm    Post subject: Re: Question o n the Mount for a 1970 VW Bus Reply with quote
Spent some quality time with the bus. Turned out to be a blown fuse and dirty connections at the bulbs. All is fine now.
1973.5 911 Targa
2003 BMW Z4 3.0i
2009 MB C300
