nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Sun Feb 23, 2020 12:39 pm Post subject: IRS bushing replacement and 2" drop. |
Figured it was time to finally tackle the rear suspension of my 68 Sedan. I've already replaced 90% of the front end (ball joints, tie rods, etc...) including KYB shocks on all four corners.
Didn't realize what a PAIN taking apart an IRS suspension was. Keeping in mind this was in my garage. Mental note: Don't bother trying the keep the diagonal arm attached to car. The job is 100X easier if you remove it completely from the car.
Old vs New bushings. Yes, these are Polyurethane, because Race Car!
I purchased these from Amazon. The Torsion bushings are from Energy Suspension. The diagonal arm bushings are made by Empi (also Poly). Everything fit perfectly (bushings were rather tight but lube and elbow grease got them in).
While I was at it, I figured I would lower the rear a bit. Front end is sitting on 2.5" drop spindles with stock beam. I decided to lower the rear 2". Using a chart I found on this website I clocked the torsions +7 on the inner splines and -7 on outer splines. Worked perfectly!
Only thing left to do was test drive it!
Car still needs an alignment, but other than that... WOW what a huge improvement!!! Rear feels stiffer, more responsive, all around better handling. I strongly recommend doing the same!
-Nick- _________________ -Why buy it when you can BUILD it?- |
vwoldbug Samba Member
Posted: Tue Mar 03, 2020 1:37 pm Post subject: Re: IRS bushing replacement and 2" drop. |
Car looks nice , I would search beetle alignment on the samba . I wouldn't trust anybody else. If you did this work you will be able to do the alignment with a little help. |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Tue Mar 03, 2020 2:24 pm Post subject: Re: IRS bushing replacement and 2" drop. |
vwoldbug wrote: |
I mean, yah, doing an alignment yourself (string method) is 100% doable, but ill be damned if im not going to just pay some $150 instead of going through all that damn pain myself after doing it once.... _________________ '74 - front disks/lots more work to do |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
If you have a shop that has a clue, then get it done. I do a quick and dirty at the shop and its usually pretty close. I set the camber straight up and down and the front toe in 1/8". Not hard to do with an angle finder and a couple rulers and some odds and ends. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Mar 03, 2020 5:22 pm Post subject: Re: IRS bushing replacement and 2" drop. |
The trade school I teach at here in Dallas area has Hunter alignment rack. I plan to do it myself as qualified ACVW mechanics are in short supply.
After looking at the car, I feel I should come up on the rear. Looks a little too low. I did +7 on the inner splines and -7 on the outers. Perhaps I will reverse it two splines on both ends. I just don't feel like taking the rear end apart again.
