Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Sun Feb 23, 2020 10:18 pm Post subject: Welded connecting rods |
Yes I know "crazy " ... ..ive was looking around the internet and was just looking around and found this ..
http://www.dlkweb.org/phpBB3/viewtopic.php?f=23&t=5970
Seems like in the 60s guys were welding big end 36hp rods and welded 40 or 1500 rod small end for a custom ratio rod and seems like they welded the i beam of the rod for strength "h beam style " ... does any of you old timers have experience with those type of welded rods and how safe were they ??? I love how guys in those days weren't scared to do the unthinkable... |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Tue Feb 25, 2020 2:32 pm Post subject: Re: Welded connecting rods |
I looked into doing this, and found a few shops that have and do still weld them. Mainly used in the vintage tractor pulling world. _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Wed Feb 26, 2020 12:23 am Post subject: Re: Welded connecting rods |
Yep, since most OE conrods are just good quality mild steel.....they can be welded.
I think it would work fine.
Why do you never see it done.......
it's "unthinkable" .... only because nobody has ever thought to ask. |
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Thu Feb 27, 2020 7:48 pm Post subject: Re: Welded connecting rods |
I was always thinking about tacking the rod bolt heads, my self _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Posted: Thu Feb 27, 2020 7:55 pm Post subject: Re: Welded connecting rods |
Yeah I can see where a couple of pieces of flat sheet metal with a good weld will in fact make an "I" beam "H" beam hybrid rod almost bomb proof ,albeit a bit heavier. _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
Posted: Thu Feb 27, 2020 7:56 pm Post subject: Re: Welded connecting rods |
I thought about having the rod bolt holes of the 36hp rod welded and redrilled and tapped for smaller bolts 1.4x 1/4 bolts so that it would have better clearance for a bigger lobe ...but I told that if I did that the rods would fail but who knows if they would ... |
Posted: Thu Feb 27, 2020 8:04 pm Post subject: Re: Welded connecting rods |
I think I would go with the larger stock thread diameter ,and just modify the depth of the threads in the cap and use a allen or twelve point external "aka arp "rod bolt. That alone if adjusted correctly should achieve the room you need to clear the cam. _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
TomSimon Samba Member
Posted: Thu Apr 09, 2020 4:39 pm Post subject: Re: Welded connecting rods |
I beam rods w/sheetmetal 'caps' welded over the beam, V8 stuff, show up at old car swap meets once in a while. VW rods are old school heavy 'clubs' by comparison to anything modern. With the availability of inexpensive and decent quality Chinese H beams, you don't see the rods when you pop the decklid, so why bother? _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sun Apr 12, 2020 7:39 pm Post subject: Re: Welded connecting rods |
Hey, If MacGyver could do it with a half dollar as the welding rod any body with a flux core welder should be able to handle it fine!
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
