jlrftype7 Samba Member
Posted: Mon Feb 24, 2020 9:08 am Post subject: Wiring repair for Sliding Door switch |
I'm guessing the grounding wire is the last Mouse chewed wire I need to replace in my Passenger Vanagon.
Tested the switch, and grounded the wire at the switch, and checked with a meter while I had the switch out as well. Mouse 1, Human 0...
But, how did VW tie the sliding door switch to the circuit originally?[ don't have my Bentley in front of me] Splice into the Drivers Dome light and run the wiring across the Headliner/Roof.?
Or did they tie into the Passenger Door wire and run it up the A Pillar, along the roof and down the B Pillar to the switch?
along those lines, can I easily use like a Electricians Fish Tool to get above the headliner and pull a wire across , or are there metal ribs /bracing I'll run into on the roof that I can't see.? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Mon Feb 24, 2020 10:43 am Post subject: Re: Wiring repair for Sliding Door switch |
edit: Sorry for any confusion. I deleted my images and text as they aren't really relevant.
Looking at pics of my slider door switch install on an '81 that did not have a slider door switch, I'd guess that the stock wiring for the slider door switch takes the switched ground from passenger door switch up, rearward, down pillar to slider door switch. IF it runs above the headliner, there will most likely be insulation up there, as my bus had, so that would make fishing a new wire difficult; you'd need to at least partially lower the head liner.
1988 West DIY 50º ABA
VE7TBN |
Posted: Mon Feb 24, 2020 11:04 am Post subject: Re: Wiring repair for Sliding Door switch |
Thanks Neil, I had forgotten about possible insulation issues. I had read about people discussing new wiring runs, and in particular that up, backward , and then down into B pillar effort. With removing the intake grill out of the bottom of the leading face of the B Pillar to see and access your new wire when pulling it down near the switch on the opposite side.
So, I think that’s the plan for me. Splice into the wire as it sits behind the glovebox and go at it. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Feb 24, 2020 11:13 am Post subject: Re: Wiring repair for Sliding Door switch |
jlrftype7 wrote: |
So, I think that’s the plan for me. Splice into the wire as it sits behind the glovebox and go at it. |
You're welcome. Sounds like a plan. It sounds like the ground wire you'll run new wire from, is functioning.
I had a similar issue with those flippin' mice chewing wires [edit: and more]. Sounds like you're lucky; you don't have to pull the dash. LOL.
Neil.
VE7TBN |
Posted: Mon Feb 24, 2020 6:49 pm Post subject: Re: Wiring repair for Sliding Door switch |
Vanagon Nut wrote: |
jlrftype7 wrote: |
Neil.
My red wire, like yours, was chewed. Once I repaired it, I had both drivers side bulbs off the drivers switch, and both again on the R/F door switch once I cleaned the contacts up on that one.
I am pulling the dash for various reasons this weekend if all goes well, so that would be the ideal time to add it to my rewiring list of redos and add-ons.
It remains to be seen what lurks in my heaterbox area, my nose says , hmm, something not so good.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Feb 24, 2020 6:55 pm Post subject: Re: Wiring repair for Sliding Door switch |
jlrftype7 wrote: |
It remains to be seen what lurks in my heaterbox area, my nose says , hmm, something not so good.... |
Hopefully not what happened to me! Glad I had spare parts....
VE7TBN |
