Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Tue Oct 06, 2020 8:18 am Post subject: Re: My first type 3 - 1973 Squareback |
I like the detailed Fuchs wheels, but the car needs primer or Hot Rod Flatz paint. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
QRP Samba Member
Joined: April 27, 2008 Posts: 1703 Location: NORTH HOLLYWOOD,CA
Posted: Tue Oct 06, 2020 7:59 pm Post subject: Re: My first type 3 - 1973 Squareback |
Mike Fisher wrote: |
I like the detailed Fuchs wheels, but the car needs primer or Hot Rod Flatz paint. |
Thanks Fisher.
I'm really not a big fan of the primer look anymore but I get it.
I dont plan on doing bodywork anytime soon so the paint is what it is. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2073 Location: Gardnerville, NV
Posted: Thu Oct 08, 2020 10:23 am Post subject: Re: My first type 3 - 1973 Squareback |
QRP wrote: |
Only one side done but I still gotta roll out for some pics. |
look at that... man even fat chicks can be sexy good going bro! _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
QRP Samba Member
Posted: Thu Oct 08, 2020 7:19 pm Post subject: Re: My first type 3 - 1973 Squareback |
VWporscheGT3 wrote: |
QRP wrote: |
look at that... man even fat chicks can be sexy good going bro! |
Like lipstick on a Pig . . . LOL
Finished up the other side today, I'll get some pics tomorrow.
I'm beat. |
QRP Samba Member
Posted: Wed Oct 14, 2020 6:37 pm Post subject: Re: My first type 3 - 1973 Squareback |
Took a little time for some paint removal after it cooled off a bit, figure if I can do about an hour each day it won't be so bad.
Just water & a Scotchbrigh pad.
I'll get all this ugly green house paint off eventually. |
Posted: Thu Oct 15, 2020 7:26 am Post subject: Re: My first type 3 - 1973 Squareback |
atleast being down in Socal you have decent weather all year so you can work on it almost every day if you wanted.
one of the very FEW things i miss about being in Palmdale, the weather cooperated 363 days of the year _________________ Schnell, SCHNELL!
QRP Samba Member
Posted: Thu Oct 15, 2020 2:05 pm Post subject: Re: My first type 3 - 1973 Squareback |
Another day another hour of this crap.
Got the nose in a shady spot so it wouldn't be to bad.
calvinater Samba Member
Posted: Fri Oct 16, 2020 2:41 am Post subject: Re: My first type 3 - 1973 Squareback |
Have you tried acetone on a rag and drape over the house paint to soften it up? _________________ "Albatross"! |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Fri Oct 16, 2020 8:46 am Post subject: Re: My first type 3 - 1973 Squareback |
calvinater wrote: |
Have you tried acetone on a rag and drape over the house paint to soften it up? |
I had suggested some EZ off oven cleaner, as that should remove the house paint. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
QRP Samba Member
Posted: Fri Oct 16, 2020 9:10 am Post subject: Re: My first type 3 - 1973 Squareback |
I'll probably have to try both of those out cause getting into the louvers isn't gonna work with my method.
Thanks guys.
Once I brake through the top crust with sandpaper the water with the Scotch brite pads actually works pretty good.
I'm really trying to stay away from chemicals as much as possible. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Fri Oct 16, 2020 2:30 pm Post subject: Re: My first type 3 - 1973 Squareback |
look at that... man even fat chicks can be sexy |
It's all about the right shoes.. _________________ Bus Motor Build
What’s That Noise?!? |
andybla Samba Member
Posted: Sun Oct 18, 2020 11:15 am Post subject: Re: My first type 3 - 1973 Squareback |
Had the same thing with my bus couple of months ago, i used an angle grinder wire cup brush, that removed the most but was also a bit aggressive because it went through the original paint here and there, but then again, it had filler all over the place so didn't mind..
before
after
QRP Samba Member
Posted: Sun Oct 18, 2020 5:59 pm Post subject: Re: My first type 3 - 1973 Squareback |
Driver side is almost there.
QRP Samba Member
Posted: Thu Oct 22, 2020 3:20 pm Post subject: Re: My first type 3 - 1973 Squareback |
Brakes on the SB have been kinda spongy for a while so I figured I'll start with new braided hose to replace the rubber ones.
Did all for corners but only took a few pics out front. Those rear lines are a bummer to get on and off, spilled a little blood in the process.
Also took some of the slack on the pedal and thats when I noticed the burned out fuse . . . The brakes are awesome now but now I have no brake lights . . UGH!
Don't know how long I was driving around without them working.
Put a new fuse and it blew right out. Blinkers and running lights still work fine, any ideas where I should start to fix the brake light issue.
QRP Samba Member
Posted: Thu Oct 22, 2020 3:53 pm Post subject: Re: My first type 3 - 1973 Squareback |
Tried another fuse again, with the key on and hitting the brake pedal everything was cool, then I started the car and watched the fuse pop right after.
WTF????? |
Posted: Fri Oct 23, 2020 7:31 am Post subject: Re: My first type 3 - 1973 Squareback |
def short circuit.. have you tried removing the brake lamps and see what happens? |
QRP Samba Member
Posted: Fri Oct 23, 2020 10:15 am Post subject: Re: My first type 3 - 1973 Squareback |
andybla wrote: |
Just tried. still popping |
Posted: Fri Oct 23, 2020 10:31 am Post subject: Re: My first type 3 - 1973 Squareback |
Maybe wire insulation gone bad?
Best is to go through this step by step
See wiring diagram below, maybe you could start by disconnecting the wire from the brake switch that goes to the brake lamps, if it pops, problem's in that wire or further down the line, if it stays, problem is not in that wire etc...
brake switch is J3 near the middele top
https://www.thesamba.com/vw/archives/info/wiring/type3_1600_66.jpg |
QRP Samba Member
Posted: Fri Oct 23, 2020 10:58 am Post subject: Re: My first type 3 - 1973 Squareback |
Rigged up this little gig so I can use these fuses that I don't need.
Then disconnected the wires in the trunk under the brake fluid thing.
Still no go.
Then After a closer look at the wiring diagram I saw that the horn was also connected to that fuse, I was fooling around with that the other day then the light over my my head lit up. BINGO!
Horn wire was grounding out. Taped it up and all is good. . . Thanks for the help guys. |
QRP Samba Member
Posted: Fri Oct 23, 2020 2:58 pm Post subject: Re: My first type 3 - 1973 Squareback |
After getting the brake light issue figured out I was in a good mood so decided to give my little pig her front blinkers back, they are big and and ugly but so is she . . . LOL
lucky for me all the parts came with the car, a little beat but they still work.
