Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Fri Oct 23, 2020 4:16 pm Post subject: Re: My first type 3 - 1973 Squareback |
Front blinkers: The housings are quite corroded which reduces the amount of bulb light reflected frontwards. You can remove the lens, cut some kitchen aluminum foil to the shape of the housing, and use spray glue or contact cement to attach the dull side of the foil to the housing so that the shiny side faces forward.
Bumper: You can reduce the visual "bulkiness" of the fat chick bumper by gluing a 3/4" wide stripe of black marine tape to the center groove. This black tape visually separates the height of the bumper, and is simple to do. Just wipe the groove with thinner first to remove any dirt on it. You can use black electrical tape, but that is too elastic so that it'll soon shrink back from the edges. If you have electrical tape at home, you can try it for a "quick and dirty" impression so see if you like that look. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Sat Oct 24, 2020 10:49 am Post subject: Re: My first type 3 - 1973 Squareback |
I think the lights are bright enough, almost to bright.
But I will try some tape across the bumper just to see what it looks like, if I like it I'll just mask n paint it.
QRP Samba Member
Posted: Sat Oct 24, 2020 1:32 pm Post subject: Re: My first type 3 - 1973 Squareback |
More silly stuff today, not much yellow to save on this thing.
QRP Samba Member
Posted: Mon Oct 26, 2020 6:41 pm Post subject: Re: My first type 3 - 1973 Squareback |
Type 3 amateur question???
What way does the tail light base rubber go on ????
EverettB Administrator
Joined: April 11, 2000 Posts: 69828 Location: Phoenix Metro
QRP Samba Member
Posted: Tue Oct 27, 2020 7:38 am Post subject: Re: My first type 3 - 1973 Squareback |
EverettB wrote: |
a is against the chrome base, it sort of wraps around it.
b is against the body/fender |
Thanks EverettB
This thing is no fun, any helpful hints to keep in on the base.
How do you guys keep it on the base to install it??? |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Tue Oct 27, 2020 11:53 am Post subject: Re: My first type 3 - 1973 Squareback |
QRP wrote: |
EverettB wrote: |
Thanks EverettB
I've used a dab of hot glue - just a tiny dot - to hold it while it takes a set over time. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
QRP Samba Member
Posted: Fri Nov 13, 2020 9:07 pm Post subject: Re: My first type 3 - 1973 Squareback |
Decided to take a shot at making some interior panels for the pig.
This thing came with zero as far as interior goes so I've gotta start from scratch.
Figured I can start with the hardest parts first.
Still not sure what direction to go as far as material to cover them with but I kinda got an idea in mind, if the raw panels come out ok I'll go hunting for it. |
Rome Samba Member
Posted: Sat Nov 14, 2020 8:45 am Post subject: Re: My first type 3 - 1973 Squareback |
Raw panels look good so far. If you want to keep them simple, how about sourcing some black vinyl from a local upholstery supply store or a car/marine interior shop? Not necessarily completely smooth vinyl, but having some minor streaks in it. Add some thin padding for the surface such as 1/4" thick foam, then glue the vinyl on, wrap the material around the back with an 1/2" to 3/4" overlap and staple it to panels. I'm sure there are some easy DIY videos on YouTube for homemade automotive door panels. If not black, then a color to match your seats.
Instead of the pleated map pocket which I'd think is not easy to make, you can attach a plastic storage tray near the bottom with screws from the back, and paint it using vinyl paint to match the panel color. |
QRP Samba Member
Posted: Tue Nov 17, 2020 11:15 am Post subject: Re: My first type 3 - 1973 Squareback |
Rome wrote: |
Thanks Rome, the assembly part seems pretty straight forward and no worries there.
Im gonna stay away from the typical black vinyl and was thinking of a plaid material, kinda like a Pendleton interior . . LOL.
If I can find a good color pattern to go with the mishmash I already have going it should work out.
Black, tan, yellow, white mix would be awesome. |
Rome Samba Member
Posted: Tue Nov 17, 2020 3:33 pm Post subject: Re: My first type 3 - 1973 Squareback |
Plaid- well you certainly are straying from "simple black"! How about looking at some 1970's VW baywindow camper plaid material? I don't think that there's a pattern that has all of your intended colors, but at least a few could be there. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
QRP Samba Member
Posted: Tue Nov 17, 2020 4:22 pm Post subject: Re: My first type 3 - 1973 Squareback |
Thanks W1K1 . . . A quick look and I see some potential already.
Bobnotch Samba Member
Posted: Wed Nov 18, 2020 9:06 am Post subject: Re: My first type 3 - 1973 Squareback |
Why not go to Joann fabrics and get something you like, like some Fido Dido material? Or something fun and different like that. Especially since you're doing your own panels. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
QRP Samba Member
Posted: Wed Nov 18, 2020 9:35 am Post subject: Re: My first type 3 - 1973 Squareback |
Bobnotch wrote: |
Why not go to Joann fabrics and get something you like, like some Fido Dido material? Or something fun and different like that. Especially since you're doing your own panels. |
Or maybe some hello kitty prints . . LOL
There's quite a few places near me, I'm sure I'll find something I like. |
QRP Samba Member
Posted: Wed Nov 18, 2020 1:14 pm Post subject: Re: My first type 3 - 1973 Squareback |
Some test fitting this morning, needed a little massaging to get the pull handle gizmo just right but not to bad.
I got it closer than I expected.
QRP Samba Member
Posted: Sat Dec 05, 2020 6:15 pm Post subject: Re: My first type 3 - 1973 Squareback |
Finally got back to work on the square today, got the panels fit in for the rear seat area
Had to pull out the back seats and discovered some big cracks in rhe body.
I guessing where the sub frame bolts on . . . UGH.
is this a typical problem with type 3s or is this really bad news for me????
Both sides look pretty bad.
QRP Samba Member
Posted: Sat Dec 05, 2020 7:36 pm Post subject: Re: My first type 3 - 1973 Squareback |
OK . . . I went back and stared at it for a while and maybe its not as bad as I thought it was.
Time for the welder to come out. |
andybla Samba Member
Posted: Sun Dec 06, 2020 4:32 am Post subject: Re: My first type 3 - 1973 Squareback |
I think it's typical, had the same spots on mine cracked, welded in some new pieces and ready |
QRP Samba Member
Posted: Sat Dec 12, 2020 9:42 am Post subject: Re: My first type 3 - 1973 Squareback |
After a test run with a yard of the plaid material I decided to keep it simple and went with plain old tan vynal.
It would've been a real pain keeping the lines straight on the plaid.
This old leather belt should make some nice pull straps too.
