jpaull Samba Member
Joined: February 22, 2005 Posts: 3465 Location: Paradise, Ca
Posted: Tue Jan 04, 2022 6:17 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Witnin01340 wrote: |
Hi Everyone,This is for jpaull or someone that knows,i purschased a crane HI6N CDI and a new FAST E92 coil but the coil only has 2 studs for the wires to go on;the FAST E92 dont have the place as the crane LX92 coil has that the wires from the cdi plug directly in to the coil,so as i read on here that the FAST E92 is exactly the SAME coil as the LX92,so how do i wire the Crane HI6N to the FAST E92 coil ? I only purschased the FAST E92 coil because all the( NEW) crane LX92 coils for sale online has a bad rap and got me to thinking since crane is no more why is there new crane LX92 coils cheap online,maybe there not a oem crane coil is what i thought of time of purschase of the FAST E92 coil. Thanks for replying. |
This plug is what you need right?
https://www.ebay.com/itm/FAST-6000-6718-Ignition-C...632-2357-0
Witnin01340 Samba Member
Posted: Tue Jan 04, 2022 6:33 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Sorry,The real question is which wires goes where from the cdi to FAST E92 coil then to the to the distributor ? i can cut the wires and add the ends it needs as far as that but i dont have any instructions what wires goes where. the cdi is a crane HI6N,the coil a FAST E92,and the distributor is a msd clone from the A-Team. This is a first for me going cdi and im lost without any instructions about the wiring. Thanks |
jpaull Samba Member
Posted: Tue Jan 04, 2022 7:04 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
For the Hi6N:
Heavy Red = Battery Positive
Heavy Black = Ground
Lite duty Orange = Coil positive
Lite duty Black = Coil negative
In the shielded grey cable inside has the small gauge trigger wires that go to the distributor and is the mag pickup signal wires. These small red and black wires connect to the distributor (Mag pickup only, no points or points replacement) and on some of these its hard to know which wire goes where, as some are both black coming out. connect it one way and it runs like crap and barely starts. Connect it correctly and it runs awesome.
Tach = White wire. These are meant for V8 only, so it will only work with a tach that has 4,6,8 cylinder selection . |
dunk Samba Member
Posted: Wed Jan 05, 2022 4:10 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
jpaull wrote: |
i have personal experience with the exact situation above, and it aint great, but it might help and be relevant..
i bought an old "ish" crane hi6n and lx92 type coil... basically from before they changed to F.A.S.T., the connector had been cut off the loom for the coil!
so i purchased the 6000-6718 from jegs after seeing the exact picture posted above. The pic is exactly what i needed. Its NOT what i got. They send out the new style e92 wire. Basically, they havent updated their pictures.
https://th.bing.com/th/id/R.06996861e818a8699897b7...aw&r=0
The wire in the pic above, is the wire you will get...
possibly.. in this situation.. if you have the newer style coil, it might actually be exactly what you need!
hope that helps a little! |
Posted: Wed Jan 05, 2022 6:15 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Ok,yes the wire connector you show looks like it will plug into the FAST E92 coil but after plugging into coil does them wires go to cdi or distributor or both ? Also the 6 wires that come out of the cdi that has the 6 pin male connector i dont care to cut off or splice that connector, so do you know if they sell a 6 pin female connector to plug into the 6 pin male ? so i can add any connector it needs coming off the female side .
Lastly,if ANY of the wires coming off the cdi is lengthened will it cause any loss of energy ? bcause the crane LX92 coil, the cdi plugs directly into coil . Or do ya think it may be a better option to get a used oem crane LX92 coil so wouldnt have to maybe cut or splice the wires on cdi ? I can wire anything as long as i know which wire goes where lol; so thanks much for explaining that and everything else jpaull. |
dunk Samba Member
Posted: Wed Jan 05, 2022 7:44 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Orange and black wires go from hi6n unit to coil... nothing else goes to coil. Neither orange or black go to dissy.
Afaik.. I'm sure others will correct me if I'm wrong, one of the benefits of the "nascar" or "n" versions of crane or msd cdi units, is that the connectors are standardised... GM I believe?!... so with a bit of searching yes, they can be bought and rewired...
Type "crane hi6n instructions" or similar into google... summit etc have many o.e. instruction sheets including crane cams ones
you can download and view. |
Posted: Wed Jan 05, 2022 11:21 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Ok,Thanks much to all, Btw jpaull this is one of the best post,NICE . |
jpaull Samba Member
Posted: Wed Jan 05, 2022 9:59 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Dunk, thanks for the great info! That happens alot and very annoying when a seller lists a old picture that does not apply anymore. |
jpaull Samba Member
Posted: Wed Jan 05, 2022 10:02 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Glad you gave it a whirl! Did you get it running yet? Make sure to not crank the engine without having all the wires connected properly. |
Posted: Fri Jan 07, 2022 10:05 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Jpaull,no not yet im just getting everything ready to test to make sure everything works before installing and here in PA now its cold with some snow so it be awhile, but il post back when i do switch from a oem points setup to cdi let ya know, Thanks. |
Posted: Thu Jan 13, 2022 4:53 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Where can one find spark plug wires to fit this type distributor (msd clone) with the H.E.I.ends,with the low resistance 40-50ohms per ft spiral wound ?
Everywhere i look there out of stock.
Thanks. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Thu Jan 13, 2022 6:27 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Thanks. |
I purchased a set of MSD wires from O'Reilly's.
They are cut to fit. And come with a nice cheap crimping tool.
I had a choice of the distributor cap ends I needed to install the wires. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Thu Jan 13, 2022 7:50 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Jeff, I just saw some of your videos. I hope you don't have an HOA |
bw65vw Samba Member
Joined: August 04, 2020 Posts: 149 Location: Tennessee
Posted: Thu Jan 13, 2022 8:11 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
I have been reading through this thread and have gathered up some parts. A Crane Hi6N box, Crane LX92 coil, MSD copy dizzy and Taylor Thunder bolt 8.2 wires. I can't seem to find anywhere in this thread about what plugs would work well with this combo? |
Posted: Thu Jan 13, 2022 8:24 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
bw65vw wrote: |
Non-resister!
Pick your poison! _________________ I have learned over the years.
Buy Once, Cry Once!
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1058 Location: St. Louis
Posted: Thu Jan 13, 2022 9:41 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Dam you guys. I'm stuck at home with the 'rona virus and going stir crazy so I impulse bought this stuff. Right now I'm at $380 but I need RPM limiter chips for the 6ALN and a distributor cap so I'll be past $400 for the whole setup. I also have MSD wires that came with the Dizzy and CB's wires if I want.
What struck me most was how well the MSD distributor is made and how well the coil is made and what a steaming pile of garbage the 6ALN is in comparison from a fit-and-finish standpoint. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
jpaull Samba Member
Posted: Fri Jan 14, 2022 1:17 pm Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Witnin01340:
Great question. The Magnaspark wires which are Taylor Thundervolt were my first choice, but now CB only sells the "high resistance" new magnaspark wires that are not gonna help spark.
Pertronix would be a last resort that is better then some. MSD is still the best but not everyone likes screaming red wires.
Kegs:
No HOA thankfully, and i live next to a super busy street that covers alot of my shenanigans. I will test the neighbors patience again this weekend with some more dyno runs.
BW65VW:
For plug wires, copper core non resister. I like the multi-ground strap plugs but they are not always easy to find and usually 14mm only.
Jimmy Hoffa: Thats a nice USA made combination of parts that although used, should work and live for a really long time. Check the gap and strength of that pickup in the distributor. If it feels weak at all, i would spend $35 on a new MSD pickup. That coil is great combo for the 6 series box. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Sat Jan 15, 2022 7:41 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Thanks for replys guys.
I called cb talked with a guy he said taylor thundervolt wires went out of business.
I was thinking the clone msd took H.E.I.ends but they dont or at least mine dont,it takes standard ends.
About the msd clone,just got mine from the A Team for $89.99 it has the floating drive etc and is made VERY WELL !
I never had a real msd but id like to put this clone beside a real msd and see where the $300.00 difference is. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Sat Jan 15, 2022 8:19 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Thatīs really sad to hear. Taylor made good wires IMHO.
But, it probably explains why CB has gone with Magnecor instead. I never understood the reasoning behind the Magnecor philosophy except in a few specific situations. On a second note there are some NGK wires out there which are made along the same lines. They too are not especially good on anything but some very specificset ups.
Granatelli makes good 0 resistance copper wires (also on measure) but be aware, if youre not on top of them they will hang you out to dry, especially if you are overseas like me.
MSD wires -are - good, at least from my point of view. and you - can - get them in more than red I use the grey version a good deal. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
jpaull Samba Member
Posted: Sat Jan 15, 2022 10:22 am Post subject: Re: Chinese MSD Distributor Tips & Tricks + Budget ignition Demo |
Alstrup, are the grey ones a MSD Universal set? If not, it would be super helpful to get a part number for those.
Specifically for the MSD 8485/HEI VW I can only find that MSD makes the red 31939 set:
https://www.ebay.com/itm/284464790993?epid=1311821357&hash=item423b6c3dd1:g:WWIAAOSwnothTupt
I see some of the universal sets like below, and a person would just have to add their own air deflectors. But it is nice as it has HEI or standard vw styel distributor terminal ends.
31153
https://www.ebay.com/itm/294643684397?epid=1527588684&hash=item449a21d42d:g:e9gAAOSwxDlhvLO5 _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
