thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Wed Mar 04, 2020 9:04 am Post subject: Dual Port Intake Fiber Gaskets. Install Them Dry? |
Years ago someone told me to put a layer of white lithium grease on these gaskets before installing them.
Opinions?
Does anyone else do this or do you install them dry? _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Mar 04, 2020 9:07 am Post subject: Re: Dual Port Intake Fiber Gaskets. Install Them Dry? |
I use anti seize. I apply a thin coat, rub it in and wipe off the excess.
It prevent the gasket from sticking the head. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Mar 04, 2020 12:03 pm Post subject: Re: Dual Port Intake Fiber Gaskets. Install Them Dry? |
Glenn wrote: |
It prevent the gasket from sticking the head. |
Interesting. I'll give that a try.
Thanks. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
houserjw Samba Member
Posted: Wed Mar 04, 2020 2:36 pm Post subject: Re: Dual Port Intake Fiber Gaskets. Install Them Dry? |
Chapstick is the only thing to use. Keep a tube in your toolbox. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Wed Mar 04, 2020 2:43 pm Post subject: Re: Dual Port Intake Fiber Gaskets. Install Them Dry? |
I was told to use grease to puff them up a bit. I've also tried Hylomar EAP5 – Exhaust Assembly Paste. _________________ www.vwnos.com [email protected]
Zed999 Samba Member
Posted: Wed Mar 04, 2020 2:45 pm Post subject: Re: Dual Port Intake Fiber Gaskets. Install Them Dry? |
I like the way they stick to the head. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Wed Mar 04, 2020 8:05 pm Post subject: Re: Dual Port Intake Fiber Gaskets. Install Them Dry? |
I use axle grease as that always seems to be around. It seems to keep them from getting brittle and cracking as soon.
It does also help them from sticking so they are easier to remove when you are so inclined. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
