andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed Mar 04, 2020 5:09 am Post subject: 74 Super speedo rubber missing - suggestions? |
This car is REALLY frustrating me with what all is missing. Just discovered that the rubber ring that secures the speedo is missing and I don't have any. pondering a couple wraps with duct tape. Any better ideas? _________________ D-Dubya Manx clone - 63 Short pan,1914.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Wed Mar 04, 2020 6:41 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Take speedometer with you to Ace Hardware or plumbing store, and see what big-diameter O-ring will fit.
I just did similar with my B2200 distributor as such seal is not available new. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Mar 04, 2020 9:05 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Cut up an old innertube, if you have one? |
Posted: Wed Mar 04, 2020 10:18 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
FreeBug wrote: |
And just glue it around the speedo? O ring wont work. Need depth _________________ D-Dubya Manx clone - 63 Short pan,1914.
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Wed Mar 04, 2020 10:39 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
like this?
https://www.mecatechnic.com/en-GB/100-mm-tachometer-seal-for-beetle-1303_KB11050.htm
I think drain pipe gaskets are made with a similar shape. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Xevin Samba Member
Posted: Wed Mar 04, 2020 10:41 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Do you have time to order one. I believe the one I got locally from Averys Aircooled was from WCM. Maybe Wolfsburg.
Edit: my ring was for a 74 std beetle. Sounds like you might be dealing with a Super? Edit: Duh, it’s in the title _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Wed Mar 04, 2020 11:11 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
andk5591 wrote: |
FreeBug wrote: |
And just glue it around the speedo? O ring wont work. Need depth |
If it's the right diameter, it will stretch and hold that way...It's just an idea, I'm just thinking out loud, iirc the original is about a half-inch wide, with ridges, and split.
It seems someone is making repros, but I'd try a lot of things before I'd pay for a little strip of rubber...but I'm a cheapskate. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Mar 04, 2020 2:54 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Put in a WTB ad for a collar, or a broken speedo with a good collar. Place the ad in the Samba Classifieds, Parts Type 1 Bug 1968 and Up.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Starbucket Samba Member
Posted: Wed Mar 04, 2020 4:51 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Go to Walmart and buy a roll of thin rubber weather stripping (it is selfstick foam rubber) and trim a piece to fit. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Mar 04, 2020 9:37 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
It always up my confidence in a vendor to see them listing a replacement part that the car never had.
"100 mm tachometer seal for Beetle 1303 "
Tachometer in a 1303? Did I miss something? Oh well, at least the part's available. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Wed Mar 04, 2020 10:14 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
SBD wrote: |
Tachometer in a 1303? Did I miss something? Oh well, at least the part's available. |
Might have been a translation screw-up: in French (Mechatehnic is French), a speedometer is called a "tachygraphe". Probably some lazy tranlator never bothered to look it up, and they sound alike, so.... |
GArBa Samba Member
Posted: Thu Mar 05, 2020 1:09 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
that's likely an automatic translation, I usually use that site in its native French. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
tzepesh Samba Member
Posted: Thu Mar 05, 2020 1:54 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
The 1303 speedo is 120mm, not 100mm. I know because I have the same issue as the OP. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
Ovally Samba Member
Posted: Thu Mar 05, 2020 4:49 am Post subject: Re: 74 Super speedo rubber missing - suggestions? |
tzepesh wrote: |
The 1303 speedo is 120mm, not 100mm. I know because I have the same issue as the OP. |
You can try the Porsche 911 rubber ring 115 mm, think this will work.
Porsche part number 911.641.903.00
https://www.partsklassik.com/Porsche-911-1972_p-3277-dash-gauge-ring-gasket-115-mm-tachometer.aspx
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Posted: Thu Mar 05, 2020 11:55 am Post subject: Re: 74 Super speedo rubber missing - solved. |
Black duct tape - narrowed a little and I think about 5 layers. With the lower panel removed, it can still be pulled out. Nice and snug with the panel in place. Thanks all and sorry for not posting my solution _________________ D-Dubya Manx clone - 63 Short pan,1914.
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Thu Mar 05, 2020 2:25 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Wow, that's a whole bunch of random thoughts. Cocaine.
Xevin wrote: |
Edit: my ring was for a 74 std beetle. Sounds like you might be dealing with a Super? Edit: Duh, it’s in the title |
_________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Thu Mar 05, 2020 3:52 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
I thought there was a supplier for these. Wolfsburg west? Otherwise, weather stripping sounds good. You need to keep the moisture content out. _________________ www.vwnos.com [email protected]
Posted: Thu Mar 05, 2020 3:59 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
Volks Wagen wrote: |
Xevin wrote: |
Cocaine? C'mon, man that's not cool. It's meth.
Just joking, my brain works like that too, sometimes....
My only concern with duct tape vs. rubber is that the rubber is probably there to absorb some vibration? But then again, the 1300's speedo is bolted down, so?
Back to my crack pipe. |
Posted: Thu Mar 05, 2020 7:42 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
heimlich wrote: |
I thought there was a supplier for these. Wolfsburg west? Otherwise, weather stripping sounds good. You need to keep the moisture content out. |
Moisture? This just holds the speedo in place. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Xevin Samba Member
Posted: Thu Mar 05, 2020 8:28 pm Post subject: Re: 74 Super speedo rubber missing - suggestions? |
FreeBug wrote: |
Xevin wrote: |
Yes
See, that’s just funny. It’s why I didn’t delete my dumb ass post when I caught it. Gotta have some humor when working on these cars Well done fellas.
Clatter wrote: |
SGKent wrote: |
