nsracing Samba Member
Posted: Mon Nov 21, 2022 8:14 pm Post subject: Re: My milling machine is bigger than yours |
I have to be up in Upstate, NY to pick up a couple of things. I hear - 5 feet of snow up there now. I bought 2- Sunnen hones. One is tooled and other not. Both same models.
The mill is in Ohio -
T/hen January, I have to drive down to TX to deliver 2 machines to a friend of mine. A boring mill and a flywheel grinder.
I took few months off work - I need a break from all the sick people.
I just want to deal w/ machines right now. I turned down 2 engine builds recently coz I cannot get to them.
Hope this winter will not be too bad. |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1852 Location: Grass Pants, Orygun
Posted: Tue Nov 22, 2022 11:58 am Post subject: Re: My milling machine is bigger than yours |
Brian_e wrote: |
stealth67vw wrote: |
I have a 2020 Haas CL-1 at work that replaced a 2004 Omniturn GT-75 that is now in my shop. The Omni, even with gang tools is a better, faster machine. The CL has been down for almost 3 weeks now. |
Ours has been great so far, but we don’t push it real hard. Light cuts and no huge runs. The guy running it is a Cnc newbie, so it’s easy for him to handle for now.
Brian |
we are limited to 360 brass, 6061 aluminum and Delrin. The collet closer mechanism doesn't allow for tighter gripping and tougher material will push in the collet. We have had several crashes from stock being pushed thru the collet while clamped. Haas and Selway have been zero help and our shop is phasing our all of our Haas mills and lathe for Doosans. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Thu Jan 12, 2023 7:03 am Post subject: Re: My milling machine is bigger than yours |
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Wed Jan 25, 2023 10:16 pm Post subject: Re: My milling machine is bigger than yours |
sold a tool like that some time back. did not think I needed it. But second thought, maybe I do -
If anyone knows where I can grab one, lemme know. |
Posted: Thu Jan 26, 2023 6:57 am Post subject: Re: My milling machine is bigger than yours |
nsracing wrote: |
In case of a zombie apocalypse? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Tue Mar 21, 2023 2:21 pm Post subject: Re: My milling machine is bigger than yours |
My milling machine is smaller than yours. Actually it’s a Linley Jig Borer. It takes LB collets. If anyone has any?
Posted: Wed Mar 22, 2023 7:26 am Post subject: Re: My milling machine is bigger than yours |
Oh heck - that is plenty! It does not really take much milling machine to do cases and heads.
I am already dreading losing mine soon -going to TX to deliver. But I may pick up something on way back w/ empty trailer being a waste.
I always take a load back so make the trip useful. |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1059 Location: St. Louis
Posted: Wed Mar 22, 2023 8:22 am Post subject: Re: My milling machine is bigger than yours |
Finally getting there with my rig! Picked this up from a local guy who also runs a little shop. It weighs just over 2 tons so it's interesting to move around, but not a problem for me. It holds a few tenths on hole diameters on circular interpolation stuff, so nailing bearing and shaft press-fits is no problemo. The iron seems young, mileage-wise. It's an '86 and the hardware is all metric even though it is a Racine, WI built machine, so that's awesome.
It's hard to take on VW stuff because job shop work pays so much more, but I'm working on getting some VW "leisure time" on the machine to develop some parts I want to see out there. TO DO LIST: Re-parameterize the control to use M-codes so I can control coolant (oil droplet air blast) in my code instead of the cheesy manual switch. Tidy up the panel and add an EMC filter for the servo drives. Keep making tooling and make the tabletop lathe chuck for round work cooler. More chip spray guards to keep the shop floor cleaner. Add CAT40 tool changing station to my "wall of fun". Re-write the postprocessor so that it moves the table out of my way on tool changes, and moves the table way forward at the end of the program.
Cheers mates, keep turnin' and burnin'. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
Posted: Wed Mar 22, 2023 8:23 am Post subject: Re: My milling machine is bigger than yours |
NSracing, You can bring back a bug in El Paso for me. Lol I’m pretty sure you won’t be out that far.
This machine was in a marine shop that rent space off my Father, probably 30 years ago. Then my Father used it a little, then gave it to me. And it’s been in his shop just sitting for 20 or so years. I just brought it home. I have to try to get the collet set that was with it. If not it has a 3/8 in it. And I read you can modify
3-AT collets to fit. I think the biggest they make is 1/2”. The collet is only .687” diameter. Maybe cut down the Berg fly cutter with 3/4” spud to 1/2”. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Wed Mar 22, 2023 11:48 am Post subject: Re: My milling machine is bigger than yours |
Damn Jimmy - you gots the machine! There is not enough money to even warm up your mill.
Unless - you are doing them top line racing engines people plunk big money for you might just break even w/ your rig.
It is quite a feat to move that much weight -by yourself. I learned a little bit from old people over the years buying machines all over the place. |
mark tucker Samba Member
Posted: Thu Mar 23, 2023 10:42 am Post subject: Re: My milling machine is bigger than yours |
NJ John wrote: |
swap meets,pawn shops/junk stores/flee markets. Ive seen lots of them, almost bought a bunch with small lathe years ago, but knew I would never need them unless I got into watch repair... if I were to use that machine for head serfacing eye wood use a rotery table with end mill or smaller flycutter. and spin the head. ( witch I have done on 2j bridge port also. you get a much better finish than with big flycutters that tend to chatter&clog up and or drag the chips. I hate these big head cutters. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Thu Mar 23, 2023 1:03 pm Post subject: Re: My milling machine is bigger than yours |
Mark, that's one of the things I have really enjoyed doing in my CNC- is using a smaller endmill and circular toolpaths to flycut and open up heads. I can almost see myself in the finish. Awesome compared to those big ole' cutters you're talking about that re-cut and swipe chips. Can't stand it. Especially when people use them down inside a hole like a VW head without at LEAST air-blast or something to encourage those chips to get out of there. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Posted: Thu Mar 23, 2023 2:10 pm Post subject: Re: My milling machine is bigger than yours |
I have yet to try it, but I liked the idea as well. I now have a small 8” rotary table. Not quite as big as I wanted, but it is something. I have some 1” thick cast tool and jig plate I could make a head fixture on and bolt it to the table. Worth a shot. The ability to just use a standard end mills for all sizes of registers on a manual machine I was the appeal to me. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
RWK Samba Member
Posted: Fri Mar 24, 2023 8:09 am Post subject: Re: My milling machine is bigger than yours |
Yes jimmyhoffa, do all your heads and decks with an end mill if you have a cnc, I use a 1/2 with corner rad for the heads, so no sharp corner. Also cut's flatter then fly cutter with some arbitrary angle ground on it,
_________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Sun Mar 26, 2023 4:43 pm Post subject: Re: My milling machine is bigger than yours |
I clicked on this topic not long after it started, didn't understand anything that was happening in it, so I made my way back to the topics that better covered my level of ignorance. Since then I've taught myself how to use the 12x24 Atlas/Craftsman lathe that had been sitting unused in the shop for years, and we bought a Pullmax for sheetmetal work. Thought it would be a good idea to find a milling machine to help make dies for the Pullmax, and in 2021 we bought a Bridgeport from a friend who was closing down his shop. One of the first things I bought to use with it was a 10" rotary table to accurately redrill lug patterns in wheels and brake rotors/drums.
Probably the greatest use for the mill I've found so far- finally satisfy your OCD by knowing that your DIY engine turned panels are now ultra consistent.
Late '22 I found a 12x36 Atlas lathe on a factory stand for $500 so I bought it to upgrade from the previous bench mounted 12x24 that took up more space and had less capacity. It's currently disassembled for deep cleaning, deburring, derusting. Eventually I'd like to find a larger lathe that can handle wheels.
The Pullmax. A bit off topic but it's why we got the Bridgeport. It's a P7, has a 48" throat, and weights about two tons. It's super handy for making precise profiles in sheetmetal when recreating or repairing body panels. It'll do pretty much anything a bead roller will do but the dies can be set up to stretch the metal as it adds a bead, so that the extra surface area needed is created as it's stamped, whereas a bead roller pulls metal from the sides and distorts the panel. It came with a lot of dies, including louver dies.
This die set was made for recreating the correct profile for the top of '66 F100 fenders. The sandpaper is used on a test panel to quickly find the high spots or pinch points of the dies so they can be smoothed for less pinching/stretching as the profile is shaped. The lower die holder is threaded, which works great when a profile tapers in depth from one end to the other like the fender profile does.
Test piece- crappy repro fender profile on top, newly made piece on bottom, profile gauge showing the difference.
I found an old Delta carbide grinder on Marketplace and started learning how to grind my own HSS- with help from This Old Tony.
Late last year dad got a call from a friend who owned a building that had been rented by a machine rebuilder, he thought that we might be interested in some of the machines or tools left by the tenant. In the back was a huge Pond Machine Tool Co metal planer, with a 12' by 54" bed that had been updated with a Bridgeport clone head to turn it into a planer mill. There was another smaller planer in the shop as well.
Another big piece was a Pratt & Whitney 3B jig borer.
The planer and jig borer were cool to see but we had no use for them and nowhere to move them to, but I was able to buy a decent amount of tools from there including a 30x36" cast iron surface plate, a smaller 24x36 surface plate, lots of measuring tools, a few camelback straight edges with various angles on their sides- all scraped for flatness, right angle plates, a keyway cutter set, machinist jacks, v- blocks, and a few books on machining. Most of it is outside of my skill level but it's nice to have, and I've been watching scraping vids on youtube so I'm itching to try it out.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Sun Mar 26, 2023 5:43 pm Post subject: Re: My milling machine is bigger than yours |
I love watching people get sucked into "the vortex" It seems like just yesterday I was pushing my little desktop mill in on a hand truck, thinking that was totally the bees knees.
Next thing you know, I'm lowering a 5000lb machine on a hydraulic drop-deck trailer in my driveway, asking the people helping me rig it if it's rigid enough for clean cuts with my Sandvik 3" face mill.
Yes. Yes. Let the machine tools flow through you. You've got some sweet stuff Astronaut _________________ 1974 Chenowth 2RL #1244 Street Legal
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Mon Mar 27, 2023 5:10 am Post subject: Re: My milling machine is bigger than yours |
Heck of a shop you've assembled there! _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Fri Mar 31, 2023 9:43 pm Post subject: Re: My milling machine is bigger than yours |
Geeze Astro - are you ill?
Goodness, I thought I had an addiction w/ machinetools. YOu take it to new heights.
ARe you keeping the camelbacks? Let me know how much if you are selling them.
The cast iron surface plate might still be in tolerance. So check with precision gage dial indicator in tenths. |
JaredJ Samba Member
Posted: Sat Apr 01, 2023 7:25 am Post subject: Re: My milling machine is bigger than yours |
nsracing wrote: |
Hey NSracing, I sent you an email. Are you still doing line bore and thrust cuts on VW cases? Where are you in Northern VA? I am in Harrisonburg.
-Jared |
