Parts list to repair sills and rear panel rust
Balmoral1958
Balmoral1958 is offline
PostPosted: Sat Mar 07, 2020 3:54 pm    Post subject: Parts list to repair sills and rear panel rust Reply with quote
Hi,
Don't normally do body repairs but wanted to know what parts I need to repair the rust in the attached. 1974 Ghia Coupe.
2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
ELFRIED
ELFRIED is offline
PostPosted: Sat Mar 07, 2020 5:25 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
pfiou...I'm afraid this is going to be a heater channel job...
c21darrel
c21darrel is offline
PostPosted: Sat Mar 07, 2020 5:37 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
very likely. Crying or Very sad
GhiaBuild
1967 DC build
Balmoral1958
PostPosted: Sun Mar 08, 2020 8:21 am    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
Thanks - best to separate the body and chassis to do the work?
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
c21darrel
PostPosted: Sun Mar 08, 2020 11:17 am    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
Yes, start taking her apart. Best of luck!
GhiaBuild
1967 DC build
Balmoral1958
PostPosted: Sun Mar 08, 2020 12:43 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
Thanks - just deciding if its worth the effort..
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
ELFRIED
ELFRIED is offline
PostPosted: Sun Mar 08, 2020 1:06 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
Aha. There are 2cv's in the States too?
Balmoral1958
PostPosted: Sun Mar 08, 2020 6:05 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
Yes!!!
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
J1
J1 is offline
PostPosted: Sun Mar 08, 2020 6:07 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
If the channel condition is like mine was and you are a relatively handy average Joe, the effort should be about 100 actual work hours and $1400... for one side. The second side should be less in time and cost. Now you can decide if driving in a cool head turner that wont taco on itself is worth that Laughing
https://www.thesamba.com/vw/forum/viewtopic.php?p=7777090#7777090
1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth.
56reddy
56reddy is offline
PostPosted: Sun Mar 08, 2020 8:22 pm    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
I decided to do the 2"x3"x1/4" heater cannel replacement
It took me about 30hrs to do the jobs and around $650 in materials.
I used the available outter rocker skin, lower front and rear quarter panel skins, 2 KlassicFab bus inner rocker, 1/2"x1/2"x18ga square tube and the 2x3x1/4 square tube.
New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VWs Fun Again.(MVFA)
KGCoupe
KGCoupe is offline
PostPosted: Mon Mar 09, 2020 9:03 am    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
I'm sorry to say that just based on what I've read here in the Ghia forum over the past decade and a half, if that's the rust you can see then most likely the rust that you can't see (until you begin cutting the body open) is roughly 10X that much.
I doubt if the rockers are the only area on your Ghia that will require rust repairs.
If, however, that is indeed the case then consider yourself lucky.
Balmoral1958
PostPosted: Mon Mar 09, 2020 9:21 am    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
Thanks - yes there is definitely more rust - the other side is almost as bad.
Toss up if I can make it work financially - I'm going to have a good look this weekend - if not I'll just part it out.... its a '74 so not as much value as an earlier model.
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
KGCoupe
KGCoupe is offline
PostPosted: Mon Mar 09, 2020 10:05 am    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
The later models may never be worth as much as the earlier ones, but it seems as though Karmann Ghia values in general may finally be on he rise.
If values go the way of other early model Volkswagens and Porsches, eventually even the rusty ones (and aren't almost all of them rusty to one degree or another at this point) will be sought after.
Balmoral1958
PostPosted: Mon Mar 09, 2020 10:15 am    Post subject: Re: Parts list to repair sills and rear panel rust Reply with quote
yes - I did get this pretty cheap - it has a motor and transmission - just a matter of opportunity cost - do I do this or buy a less intensive project... could get it running and sell-on ...
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
