Ovally Samba Member
Posted: Tue Mar 10, 2020 10:48 am Post subject: Question air cleaner system Porsche 2.2S MFI 1970 |
Does anyone know if there should be a hose on the air cleaner system (red arrow) of a 1970 Porsche 2.2S MFI.
The engine runs fine without hose but I have seen several photos and some 2.2S MFI have that hose and others do not.
Thanks and regards.
_________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Joined: December 28, 2016 Posts: 276 Location: atlanta ga
Posted: Wed Mar 11, 2020 9:33 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
preheat from the heat exchanger for faster warmup, should be a chamber with a fitting on the heat exchanger to connect a hose to that closes when the car is warmed up and then cuts the hot air from going into the snorkel |
Ovally Samba Member
Posted: Thu Mar 12, 2020 12:58 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
[email protected] wrote: |
Thanks.
This is the only connection I can find, it comes out and stays in the body and has the same diameter as the one on the snorkel.
That connection is located next to the bottom left of the oil filter, barely visible and not connected to the heat exchanger.
There is also no fitting for that hose on the right side heat exchanger MFI.
Is this what you mean?
Better photo.
Here is another photo (not my car) of a 2.2S MFI
VW Bug 1200 D motor
Ovally Samba Member
Posted: Sat Mar 14, 2020 2:12 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Found it.
Indeed, a hose must be connected to the snorkel for faster warmup.
Here is an interior view of the chassis/body along the right side of the engine.
The tube with the connection behind the oil filter that I mentioned in my previous post, can be seen here.
All Porsches 911 '65 -'71 (carburetor and MFI) have this tube.
The heat exchanger on the right has no fitting but is connected to the heating control box which is connected to the chassis / body where that tube is also located.
Another clever solution from the Porsche designers!
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Ovally Samba Member
Posted: Tue Mar 17, 2020 10:58 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
The correct hose (preheat) and 2 clamps arrived today.
I drove the car and the engine warms up faster.
Now I can also push the hand throttle lever down faster without the engine tending to stall after a cold start.
Regards.
VW Bug 1200 D motor
Speedsterboy Samba Member
Posted: Wed Mar 25, 2020 2:23 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Sorry for the hijack but while we are in the subject of hoses, in my 911 flat6 equipped 1968 912 Targa, the original air filters are gone as it now has a pair of Webers and Weber type air filters. Consequently, I have a breather tube alongside the oil filler neck with nothing on it and just blowing oil fumes into the engine bay. My question is; should I plug it or better yet, install a hose from this breather tube on the filler neck and route it into the 'pipe' as shown on 'Ovally's' photos with the red arrow? Would this be safe and not harm the engine? Thanks very much! _________________ Are you under the impression you'll live forever? All that shit you're hoarding is meaningless. You never know what's around the corner. Enjoy life now! |
Ovally Samba Member
Posted: Fri Mar 27, 2020 12:52 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Speedsterboy wrote: |
Sorry for the hijack but while we are in the subject of hoses, in my 911 flat6 equipped 1968 912 Targa, the original air filters are gone as it now has a pair of Webers and Weber type air filters. Consequently, I have a breather tube alongside the oil filler neck with nothing on it and just blowing oil fumes into the engine bay. My question is; should I plug it or better yet, install a hose from this breather tube on the filler neck and route it into the 'pipe' as shown on 'Ovally's' photos with the red arrow? Would this be safe and not harm the engine? Thanks very much! |
Do not install a hose from the breather tube alongside the oil filler neck into the "pipe" sticking out of the chassis.
If you do that you get fumes in the cabin !!!!
That "pipe" is intended to connect a hose (preheating) that goes to the snorkel of the air filter housing.
Also don't plug it.
You have Webers and Weber type air filters.
I've seen solutions, from simple to more complicated, at the http://forums.pelicanparts.com/
Like this one for example with a modified old washer fluid bottle attached to the firewall.
I suppose there should also be a drain at the bottom of the bottle : a hose to this pipe with valve, attached to the engine tin / flywheel side.
VW Bug 1200 D motor
Posted: Fri Mar 27, 2020 1:03 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Thanks for the response Mate but I can't seem to find specifically on Pelican where or what to do with the other end of the hose as an alternative to the washer bottle. Thank you very much again! Cheers! _________________ Are you under the impression you'll live forever? All that shit you're hoarding is meaningless. You never know what's around the corner. Enjoy life now! |
Ovally Samba Member
Posted: Fri Mar 27, 2020 3:07 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Thanks for the response Mate but I can't seem to find specifically on Pelican where or what to do with the other end of the hose as an alternative to the washer bottle. Thank you very much again! Cheers! |
Here you see another solution for the hose : 1969 Porsche 912 to 911 engine conversion.
In my opinion a nicer solution.
Post a photo of your engine bay / compartment.
VW Bug 1200 D motor
Posted: Mon Mar 30, 2020 9:43 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Wow, thanks a lot Mate, now I understand. I actually have those holes on my air filters as well for those 'L' type plastic fitting/tubes or the whole kit? Thanks so much again!
Ovally Samba Member
Posted: Mon Mar 30, 2020 9:03 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Looks like you need something like this vapor kit.
https://www.partsklassik.com/p-3031-vapor-kit-for-pmo-air-filters.aspx
VW Bug 1200 D motor
Posted: Thu Apr 02, 2020 2:43 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
I was sent this photo by someone else who had the same issue, it seems like the 'prettiest' and simplest way of dealing with the issue. A 'breathing' filter directly on the breather pipe outlet. Any thoughts? Good or bad? Thanks!
https://www.early911sregistry.org/forums/attachment.php?attachmentid=520199&d=1585820451 _________________ Are you under the impression you'll live forever? All that shit you're hoarding is meaningless. You never know what's around the corner. Enjoy life now! |
Ovally Samba Member
Posted: Thu Apr 02, 2020 9:55 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
It does look neat indeed, don't know it will have much effect but you can try it.
You may still have some greasy fumes and smell the oil vapors in the engine compartment.
Some recommend that it is better to use an oil catch can with a filter at the top.
A catch can seperates oil and vapors better than only a filter on the oil filler neck and can be drained regularly if necessary.
In either case, I think it will always smell and be a bit greasy.
For the environment I suggest to direct the catch can vapors into the air intake filters.
VW Bug 1200 D motor
Posted: Fri Apr 03, 2020 2:52 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Thanks again Ovally. That's a really nice looking oil catch can. Do you know where I can buy it from? I looked online and can't find that exact one on your photo. _________________ Are you under the impression you'll live forever? All that shit you're hoarding is meaningless. You never know what's around the corner. Enjoy life now! |
Ovally Samba Member
Posted: Fri Apr 03, 2020 9:39 pm Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Thanks again Ovally. That's a really nice looking oil catch can. Do you know where I can buy it from? I looked online and can't find that exact one on your photo. |
Don't know the brand.
This one looks close : Moroso 85400.
You may need to replace the inlet fitting to match the inner diameter of the breather hose.
You can ask Himni-racing, they have fittings and adapters.
http://www.himni-racing.com/accessories/oil-catch-...ring-inlet
Some other oil breather tanks.
https://www.himni-racing.com/accessories/universal-oil-catch-bypass-tanks
VW Bug 1200 D motor
Posted: Sun Apr 05, 2020 5:54 am Post subject: Re: Question air cleaner system Porsche 2.2S MFI 1970 |
Thanks a lot for all your assistance Mate. I've sent this guys an e-mail. Cheers! _________________ Are you under the impression you'll live forever? All that shit you're hoarding is meaningless. You never know what's around the corner. Enjoy life now! |
