mexnotch Samba Member
Posted: Wed Mar 11, 2020 5:45 pm Post subject: Windshield washer tank and hose |
Hi,
This is the washer tank that was in my car before the restoration. It has no hose as you can see. Helphos
Is this the hose I need for it?
Thanks
_________________ Henry
1974 Mexican Bus
1965 Notch 1500S
1972 Type 181 Safari |
old_man Samba Member
Joined: June 19, 2018 Posts: 1381 Location: Newfoundland
Posted: Wed Mar 11, 2020 7:46 pm Post subject: Re: Windshield washer tank and hose |
Are you trying to make it completely original or are you trying to get a washer system that works? |
Posted: Wed Mar 11, 2020 8:36 pm Post subject: Re: Windshield washer tank and hose |
old_man wrote: |
I'd like to get it as original as possible if the cost is not outrageous.
What would you suggest in order to just get it working?
Thanks _________________ Henry
1974 Mexican Bus
1965 Notch 1500S
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Thu Mar 12, 2020 12:31 pm Post subject: Re: Windshield washer tank and hose |
mexnotch wrote: |
old_man wrote: |
Thanks |
Hidden electric pump, and a micro switch to run the pump. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Mar 12, 2020 12:33 pm Post subject: Re: Windshield washer tank and hose |
Bobnotch wrote: |
mexnotch wrote: |
old_man wrote: |
Thanks |
Hidden electric pump, and a micro switch to run the pump. |
That's what I have in my bus.
If I wanted to go original, is the hose pictured above the way to go?
1974 Mexican Bus
1965 Notch 1500S
Posted: Thu Mar 12, 2020 12:53 pm Post subject: Re: Windshield washer tank and hose |
mexnotch wrote: |
Bobnotch wrote: |
mexnotch wrote: |
old_man wrote: |
Thanks |
Thanks |
I don't know. You'd have to ask a 1500 club member like Jason. My 65 had a similar set up, but I just added an electric pump and micro switch, as I wanted it to actually work, and leave me with a fully aired up spare tire. But then, my car wasn't rebuilt to be stock, it was rebuilt to be a driver, and I've been to PA and western Missouri in it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Mar 12, 2020 12:55 pm Post subject: Re: Windshield washer tank and hose |
Thanks
Bobnotch wrote: |
mexnotch wrote: |
Bobnotch wrote: |
mexnotch wrote: |
old_man wrote: |
Thanks |
Thanks |
I don't know. You'd have to ask a 1500 club member like Jason. My 65 had a similar set up, but I just added an electric pump and micro switch, as I wanted it to actually work, and leave me with a fully aired up spare tire. |
1974 Mexican Bus
1965 Notch 1500S
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Thu Mar 12, 2020 2:13 pm Post subject: Re: Windshield washer tank and hose |
Problems with the stock system include: leaks at hose ends; leaks at switch dripping water on electrics; leaks in cowl leading to rust, flat spare when you need it... |
Posted: Thu Mar 12, 2020 3:03 pm Post subject: Re: Windshield washer tank and hose |
KTPhil wrote: |
I get the picture.... _________________ Henry
1974 Mexican Bus
1965 Notch 1500S
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Fri Mar 13, 2020 9:22 am Post subject: Re: Windshield washer tank and hose |
The ‘65 system does not connect to the spare tire. You pressurize the tank directly using the Schraeder valve visible in the photo.
If you are going to keep the system original, do replace all the pressure hose between the tank and switch. There is a special 2.5mm hose for this purpose that is available by the meter from VW specialist shops. I know bughaus carries it.
Regular vacuum hose from the FLAPS will not hold the pressure and will burst/leak.
I have been using the original system leak free for a few years now after installing the correct hose. The tank can take up to 35 psi but I usually keep it in the 25-30 range out of concern for old plastic.
It lasts a long long time before having to repressurize. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Fri Mar 13, 2020 9:39 am Post subject: Re: Windshield washer tank and hose |
sjbartnik wrote: |
It lasts a long long time before having to repressurize. |
Thanks! Great piece of information! Plus it makes my life easier.. _________________ Henry
1974 Mexican Bus
1965 Notch 1500S
Posted: Fri Mar 13, 2020 11:45 am Post subject: Re: Windshield washer tank and hose |
mexnotch wrote: |
Hi,
Thanks
I think that hose set up is for Squarebacks of that vintage, since they run a higher air pressure thn a Notch did. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Mar 13, 2020 2:37 pm Post subject: Re: Windshield washer tank and hose |
Thanks
mexnotch wrote: |
sjbartnik wrote: |
Thanks! Great piece of information! Plus it makes my life easier.. |
1974 Mexican Bus
1965 Notch 1500S
