Seeking Factory Alignment and Geometry Specs
jed166
jed166 is offline
PostPosted: Thu Mar 12, 2020 7:32 pm    Post subject: Seeking Factory Alignment and Geometry Specs Reply with quote
Hello. I am looking for alignment and factory geometry specifications for a 1965 Beetle. Specifications that a frame shop would have to compare against. (ie. Geometry and measurements for the chassis, to make sure that everything is straight).
Background: My beetle needs a Canadian salvage inspection. The inspection should be straightforward to pass as the body is straight, but the mechanic’s database does not include factory specs for a 1965 beetle.
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Mar 13, 2020 8:45 am    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Are you looking for just wheel alignment data? Or chassis measurements to evaluate frame damage?
jed166
jed166 is offline
PostPosted: Fri Mar 13, 2020 11:33 am    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Hello. I am looking for chassis measurements to evaluate frame damage. So far I have checked with Mitchell automotive, and have inquiries ongoing with Chief and ALLData. Mitchell has said they do not have anything for beetles older than 75.
jed166
jed166 is offline
PostPosted: Fri Mar 13, 2020 12:19 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Update: Chief does not carry the '65 Beetle in their database.
mukluk
mukluk is offline
PostPosted: Fri Mar 13, 2020 12:45 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Not sure if this will be helpful or not since it's unclear exactly what measurements you need.
jed166
jed166 is offline
PostPosted: Fri Mar 13, 2020 3:42 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Mukluk
Thanks so much. I'm going to try taking this to the frame shop to see if this is satisfactory.
74 Thing
74 Thing is offline
PostPosted: Sun Mar 15, 2020 12:09 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
http://i61.photobucket.com/albums/h58/davidsigouin/alignment/Untitled8.jpg
jed166
jed166 is offline
PostPosted: Tue Mar 17, 2020 7:05 am    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Thanks 74 Thing.
jed166
jed166 is offline
PostPosted: Tue Mar 17, 2020 2:22 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
All,
A Samba user PM'd me a really helpful excerpt from what appears to be a VW Service manual.
Please let me know if you are reading this and need it, as I cannot post it here.
Chickensoup
Chickensoup is offline
PostPosted: Tue Mar 17, 2020 4:11 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
jed166 wrote:
All,
hey, id really appreciate it if you'd PM it to me. im gonna need it when i un-damage my front clip... Very Happy
thanks
Smurf
Smurf is offline
PostPosted: Sun Apr 05, 2020 10:04 am    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Trying to figure out my pans now and came across this post.
I have WW pans and the drivers side pan is 65 7/8” while my passenger side is 66 1/16”. That’s a huge difference! What’s the dimensions from the two front holes to the first hole in the floor pan?
Nevermind: I did it the old school way and drug the chassis out of the garage and bolted back up to the body. Even with this method there was a lot of tweaking to be done to get all the holes lined up properly.
1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work
jed166
jed166 is offline
PostPosted: Sun Apr 05, 2020 7:18 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
Sorry can’t help you there but have you looked through the body repair forum? I’ve found some helpful stuff there before.
coolbugfan
coolbugfan is offline
PostPosted: Sun Mar 28, 2021 9:41 pm    Post subject: Re: Seeking Factory Alignment and Geometry Specs Reply with quote
74 Thing has great data specs. But why are there no specs for the rear of the Beetle?
