Crankey Samba Member
Posted: Fri Aug 20, 2021 8:19 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Sodo wrote: |
Whoa Crankey, you’re willing to share your favorite industrial dumpster with me?
I’ll be your best friend. 🤣🤣 |
Realistically, I can't take it all.
I posted before I saw page 2 and 3 so didn't realize your already done. Looks pretty nice and not too much hassel to live with when it's wrench time under there. My moustache bar is now bare steel so I'll be adding some points of connection like that before it goes back into my rig. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Fri Aug 20, 2021 6:30 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
I’ll be your best friend. 🤣🤣 _________________
....KTMs, GasGas, SPOT mtb |
Posted: Thu Aug 19, 2021 7:34 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
swissarmychainsaw wrote: |
My humble suggestion would be to put 90 degree bends on the side of the sheet metal, and drill/tap hose in your square tube.
For a couple of reasons:
1. If you use this as intended, a nice flat bottom will slide over everything (christ!)
2. Not having you bolts all jammed up with mud and crud will make oil changes that much easier.
i have HATED bash plates on bikes that were bolted on from the bottom.
Please to be enjoy this non-technical, technical drawing:
I like the bolts on the side, the further forward bolts could also work as hinge points so the plate could unbolt at the rear and hinge down from the front of you didn't want to completely remove it.
If you go 1/8" steel you could also add ribs of 1/8 wall 3/4 leg angle to make it stiffer and act as slide rails...1/2" leg angle would also help and give a tiny bit more clearance.
I've never seen exactly how the rear of these things attach, looks like it bolts to the moustache bar... Maybe I'll add some mount points to my 2wd bar for a skid plate setup.
Looks cool I bet it gives you some peace of mind.
Even with a steel oil pan I'd be super worried about the impact shock on all the bolts and threads into the aluminum case without a skid plate.
There's a shop down in south park where you can get big (1-1/4" or so) ball bearings free from a dumpster to use as dimple pushers. Some off cuts of steel tube with radius carved on the I.D. as a receiver die would be a good set of home made tools for dimple. |
Sodo Samba Member
Posted: Wed Aug 18, 2021 8:59 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Doing its job.
Ida been in deep kaka without it.
Basically wouldn’t be able to drive in the rocks (as I did).
Concavity likely ushers the rocks towards the dimpled holes at the corners.
Also added a little 45deg ‘fairing’ to help it glance off or lift over a stump, rather than hook on it. _________________
4Gears4Tires Samba Member
Posted: Fri Sep 04, 2020 9:13 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Not bad for using what you already had laying around! Looks good. _________________ '87 Syncro
Sodo Samba Member
Posted: Fri Sep 04, 2020 4:06 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
OK I cheapened out and tried to use a couple sockets for "dimple dies".
It sorta worked.
Here's a good one and a not-so-good one.
Was difficult to center one socket ontop of the other. _________________
Posted: Mon Aug 24, 2020 9:07 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
My line of thought was the width of the work piece. My press has a 22" opening, which I think is fairly standard. If it's narrower than that, definitely get the die. _________________ '87 Syncro
Sodo Samba Member
Posted: Mon Aug 24, 2020 8:58 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
syncrodoka wrote: |
Dimple die AKA speed holes |
OK that would look nice too.
A 1" dimple die costs $33 on eBay, can't engage a machine shop for $33.
Or maybe I can fake it with sockets etc in the hydraulic press?
OK I'm gonna do that, one way or another. _________________
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Mon Aug 24, 2020 8:07 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Sodo Samba Member
Posted: Mon Aug 24, 2020 7:32 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Ain't following you there.....what benefit are dimples?
They wouldn't let the rocks out. _________________
Posted: Mon Aug 24, 2020 5:50 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Could you take that piece to a machine shop and get a few 1" dimples in it? _________________ '87 Syncro
Sodo Samba Member
Posted: Mon Aug 24, 2020 3:33 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Skid bars seem to be working good, but I haven't drug it over anything big & hairy yet.
But I did drive on LOTS of gravel this past month, about 6,000 miles of it.
As expected, the pan collects & holds a LOT of gravel.
Rocks wedge themselves into the cooling airspace between the case oilpan and the skidplate.
I thought about a screen to block the rocks from getting in, but that seems like it adds too much trouble, and reduces oil cooling.
A waterboxer already has trouble shedding oil heat.
I didn't want to weaken the membrane of the flat plate but clearly I'm gonna have to drill some holes.
Slamming onto a rock below could punch a little one into the cast oilpan & crack it. _________________
FrankenSubySyncro Samba Member
Joined: May 03, 2007 Posts: 638 Location: Vancouver, WA.
Posted: Sun Mar 22, 2020 1:29 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Looks good Tom! _________________ Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/ |
Posted: Sat Mar 21, 2020 6:46 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
I missed the end of your tow bar thread, that's pretty cool. I like the little skid plate wings you built to protect the exhaust manifold. Great idea. _________________ '87 Syncro
Zeitgeist 13 Samba Member
Posted: Fri Mar 20, 2020 3:24 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
I troll because I love. Be sure to use your skills for good and not evil. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Sodo Samba Member
Posted: Fri Mar 20, 2020 9:11 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Go easy fellas, Casey appears to be unseasonably 'content' this spring!
Maybe he went to remarry his wife last night and noticed a WRX in the driveway.
And took a little ride.
Just to prove how substandard it was, of course.
... a bite from the 🍎 Fuji apple.🍎
OK that's enough - a little gearboy chat oughtta dampen the current titillation (it always does).
Here's the cross-section of the skid bars
new = 1.5 x 1.5 x .120
old = 1.6 x 1.2 x .100
The Ix is called "area moment of inertia" and directly relates to the "stiffness" in the up/down bending axis;
New bar Ix=.21 and the OEM Ix=.11.
The new bars are double the "strength" (&40% heavier).
=======edit=======
This is not "failure strength" better called "twice the stiffness".
If'n you fellers need to self-engineer 'stiffness' someday (again,,,it's not failure strength!!)
Here's the link to the "area moment of inertia" calculator.
https://calcresource.com/moment-of-inertia-rtube.html _________________
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Fri Mar 20, 2020 7:55 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
wesitarz wrote: |
^^ Can't get over the fact that the Japanese took that sad 2.1 VW WBX to the next levels. |
Exactly! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Fri Mar 20, 2020 5:20 am Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Posted: Thu Mar 19, 2020 6:48 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
Your fabrication skills are mighty impressive. Once you get yourself a real engine, the van will be similarly impressive. [poke] _________________ Casey--
y u rune klassik? |
Sodo Samba Member
Posted: Thu Mar 19, 2020 3:52 pm Post subject: Re: Redesign Syncro skid bars to protect Smallcar Cast oilpan |
candyman wrote: |
Excellent work as always Tom! Curious what is That channel steel bolted to the pass side of your driveline protection bar? |
Thanks Candyman.
That's part of a towbar
Building a towbar to carry on the Vanagon
I got's lotsa stuff on the bottom of my van.
If #vanlife is piling stuff ontop I must be #ǝɟıluɐʌ
Lemme see if my daughters will do yoga poses under the van.
Hmmmm,,,,, now that the front skid bars can be unbolted individually they could be used as the two legs of the towbar triangle.... _________________
