Ollie W Samba Member
Joined: May 20, 2004 Posts: 801 Location: Portland, OR
Posted: Thu Apr 06, 2017 10:25 am Post subject: Vent Defrost Foil Tube Size |
Hello all,
I realize now why my driver's side vent defrost doesn't work, but my passenger side does, the foil tube is missing?
Does anyone know the diameter size of this tubing? I can't find it listed on GoWesty or Van Cafe. Thanks.
These one's are what I'm talking about, for reference.
Thanks. |
dkoesyncro Samba Member
Posted: Thu Apr 06, 2017 4:08 pm Post subject: Re: Vent Defrost Foil Tube Size |
I used the 1 3/4" from empi found at your local discount import parts. I had to use the original cardboard tube to make some spacers/bushings.
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Thu Apr 06, 2017 4:25 pm Post subject: Re: Vent Defrost Foil Tube Size |
Hmm. Great tip and we have such a shop. I think I'll tape mine on as well - vibrations, etc could dislodge. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Fri Apr 07, 2017 9:43 am Post subject: Re: Vent Defrost Foil Tube Size |
I might try and find some shop vac hose that would fit. it comes in 1-7/8 outside diameter that might be just perfect.
_________________ 89 Westy 2.1 Auto |
GEEBEE Samba Member
Posted: Fri Apr 07, 2017 12:14 pm Post subject: Re: Vent Defrost Foil Tube Size |
It can be made in two ply flex silcone with fiberglass wire
I do it for aircraft...
GEEBEEPRODUCTS.COM
GB |
dasilva Samba Member
Posted: Fri Aug 20, 2021 6:24 am Post subject: Re: Vent Defrost Foil Tube Size |
Hi,
I'm trying to reassemble my front dash after an engine upgrade. I drive a 2WD, Automatic, 1989 Westfalia.
I got overenthusiastic with the cleaning. I removed a vent hose that is troublesome to push back behind the wheel, as per original routing.
Original routing pictured below.
Does anyone have any tips on how to get this hose pushed back into place? Though, it is not shown in the picture below, I have pulled out the front heater core (again) to buy myself some more working space.
Any help would be appreciated.
Regards,
Carl |
