malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Fri Mar 13, 2020 12:24 pm Post subject: ignition removal..... Tumblers |
How do you get the tumbler out?
2ndly why did someone drill a hole in this part?
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Fri Mar 13, 2020 12:29 pm Post subject: Re: ignition removal..... Tumblers |
you don't. the tumblers are in the barrel for good. (kind of)
unless you mean the mechanical portion of the switch. someone had a good write up. search "removing ignition lock"
basically you need to depress a spring and pull the lock barrel out. helps to have a key to aid in pulling the barrel from the lock mechanism _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 13, 2020 1:44 pm Post subject: Re: ignition removal..... Tumblers |
ALLLL righty then. I do have a key for the ignition. And a plan to send all the handles, latches and keyed things to all be keyed the same.
BTW, I got a glove box latch with a key, but the guy I bought it from said he thinks it will need to have a separate key. I guess I can deal with that, may never lock it anyway.
Thanks _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Fri Mar 13, 2020 1:49 pm Post subject: Re: ignition removal..... Tumblers |
the holes drilled are from a hack that couldn't access the hole for the retainer spring.
you can't easily open the ignition barrel, so when you get something keyed, you match the ignition to the rest of the car _________________
Jake Raby wrote: |
Brian wrote: |
Starbucket Samba Member
Posted: Fri Mar 13, 2020 2:24 pm Post subject: Re: ignition removal..... Tumblers |
malcolm2 wrote: |
Thanks
If you lock the glove box you won't be able to get to your gun in time to keep a crazed hippy from taking your bus |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Mar 25, 2020 9:43 am Post subject: Re: ignition removal..... Tumblers |
https://youtu.be/Vvmyv1jmJMQ _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
