jlrftype7 Samba Member
Posted: Sat Mar 14, 2020 8:02 am Post subject: Loss of all Automatic Gear Function: FIXED! |
Well, we just got stranded in Springfield MO this morning .
Moved the Vanagon from our hotel to a stop at Walgreen’s. Nothing appeared wrong at this point.
On restart, nothing, no gear engagement. Engine is not being pulled down by trans, so I thought, oh no, we lost our Flex Plate? Or something else...
Removed the hatch, started the engine, Torque Converter is turning with the engine .
Got under the Vanagon, shift cable and new circlip are still there , with lever moving with correct gear selection like normal.
Checked trans fluid with engine running, correct level and nice color and condition, so our GoWesty cooler has been doing its job on this long trip.
So, did I lose the D/R clutch with no warning, oil pump shaft broke?
Even in 1, I have nothing.
I actually have the tools to drop the pan and valve body with us, along with a sealable oil/fluid drain pan, so if push came to shove, I could investigate further.
We’re more of the mindset to get a rental vehicle , transfer our load, and have the Vanagon flatbedded to my work while we continue home with the rental vehicle . _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Mar 14, 2020 8:21 am Post subject: Re: Loss of all Automatic Gear Function |
That's what I would do. You've done the basics. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17014 Location: Retired South Florida
Posted: Sat Mar 14, 2020 8:56 am Post subject: Re: Loss of all Automatic Gear Function |
Did you watch the CV shafts? A broken CV and you won't move. Also, a disconnected CV in case the bolts weren't properly torqued last time the joints were serviced. _________________ ☮️ |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Sat Mar 14, 2020 9:28 am Post subject: Re: Loss of all Automatic Gear Function |
Bummer! I'm no expert in auto transmissions (but I own one in my '87 Westy) so I'm both interested in and baffled by your symptoms. I hope that you get her rolling again, and I assume you are headed from Springfield, MO back up I-44 thru St. Louis to Chicago? I'm in a western burb of STL if you're passing and get into more trouble. Hopefully you'll sort it out and get your Vanagon back home just fine...
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Sat Mar 14, 2020 9:31 am Post subject: Re: Loss of all Automatic Gear Function |
MarkWard wrote: |
Did you watch the CV shafts? A broken CV and you won't move. Also, a disconnected CV in case the bolts weren't properly torqued last time the joints were serviced. |
Ah, forgot about the CV /loss of drive issue. I doubt that’s it though since the trans won’t load the engine at all when a gear is engaged and your foot is still on the brake( that’s why I was worried about Flex Plate at first- we’re getting it towed, now raining pretty hard and cold too. Wife is at Enterprise getting a rental. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
blackglasspirate Samba Member
Posted: Sat Mar 14, 2020 2:23 pm Post subject: Re: Loss of all Automatic Gear Function |
I had something similar happen recently with my auto. Out of nowhere it did not want to engage and wasn't loading the engine at all no matter what gear the shifter was in. If I revved really high it would catch just enough to move it but not very well (not sure if you're experiencing that as well).
In the end it was a clogged pressure regulator valve in the valve body. It had just enough gunk in there (which wasn't much) to make it stick open.
Hopefully yours is that simple. _________________ '87 Vanagon GL Westfalia
IG: @holidayatsee
FB: https://www.facebook.com/holidayatsee |
Posted: Sat Mar 14, 2020 7:35 pm Post subject: Re: Loss of all Automatic Gear Function |
blackglasspirate wrote: |
Hopefully yours is that simple. |
. Thanks, I hope it’s that simple. Tow truck arrives later tonight at my work to drop off the Vanagon- I’ll drop the pan and valve body next week and try to figure it out.
It was the sudden loss that threw us- Moved one minute, then 20 min later after restart, nada.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Mar 16, 2020 11:11 am Post subject: Re: Loss of all Automatic Gear Function |
BulliBill wrote: |
Bill Bowman |
We ended up getting it towed[ whoa Nelly, large bill on that one... ]
And moving almost all items over to the Dodge Minivan. The drive home was , ahem, much faster than it would have been in the Vanagon even when it was moving on its own power. BUT, our LED headlights in the Vanagon are actually nicer and brighter than the rental car was... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2048 Location: Plymouth, MA
Posted: Wed Mar 18, 2020 2:39 pm Post subject: Re: Loss of all Automatic Gear Function |
Sorry to hear about your troubles. I've dissected two vanagon automatic tranaxles with your described situation and both had serious internal problems. On one the oil pump drive gear broke into 3 pieces and on another the drive shaft somehow got stuck and stripped itself to uselessness. I hope it's not anything like that. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Posted: Wed Mar 18, 2020 5:34 pm Post subject: Re: Loss of all Automatic Gear Function |
edgood1 wrote: |
Sorry to hear about your troubles. I've dissected two vanagon automatic tranaxles with your described situation and both had serious internal problems. On one the oil pump drive gear broke into 3 pieces and on another the drive shaft somehow got stuck and stripped itself to uselessness. I hope it's not anything like that. |
When you mentioned drive shaft, which one . Your Oil pump shaft or the Outer Turbine Shaft coming from the Torque Converter?
I’m hopeful that it’s a valve body issue since it powered itself quietly with no bad noises to the Parking Spot where we discovered the loss of all gears about 20 minutes later
Oil Pump snapping quietly I guess I could see happening , oil pump jamming , not sure.
Either way, I hope to drop the pan tomorrow and see what it looks like inside.
Oil pump shaft will be easy to check once the fluid fitting for the GoWesty Trans Cooler is removed off the nose of the trans since it’s visible through the threaded hole.
Then I’ll need to turn the engine by hand to see if the pump and shaft turn with it. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Wed Mar 18, 2020 5:56 pm Post subject: Re: Loss of all Automatic Gear Function |
Shameless plug I have a pump shaft with drive foot in the classifieds. I also have a turbine shaft listed. There is a pressure port for testing the automatic prior to disassembly covered in the Bentley manual. Easier to check prior to dropping the pan. _________________ ☮️ |
Posted: Wed Mar 18, 2020 7:35 pm Post subject: Re: Loss of all Automatic Gear Function |
MarkWard wrote: |
Shameless plug I have a pump shaft with drive foot in the classifieds. I also have a turbine shaft listed. There is a pressure port for testing the automatic prior to disassembly covered in the Bentley manual. Easier to check prior to dropping the pan. |
Shhhh, I’ve been meaning to contact you about those parts.... ixnay on the partsa in public....
I actually bought a Trans Gauge set a few weeks ago, so this would be the time to break it out and test at the port.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
pburkeame Samba Member
Joined: October 29, 2018 Posts: 42 Location: British Columbia
Posted: Fri May 01, 2020 10:39 pm Post subject: Re: Loss of all Automatic Gear Function |
I’m also experiencing Auto trans problems. I fixed an ongoing engine problem and I was out for a test run when all of a sudden the transmission started making a high pitched noise and then stopped working. After a 15 minute cool down it worked again. It did this 2 more times until I could it get it home.
I did have a stock cooler fail last fall. The coolant was contaminated, but the ATF was clean and continues to be clean. At the moment, I don’t have a cooler, just a length of hose from fitting to fitting.
Sounds like we have different problems. If I find anything I’ll pass it on. _________________ 1987 Vanagon Syncro, Manual
1987 Vanagon 2WD, Automatic
1986 DOKA Syncro, Manual
1980 Westphalia, 2WD, Manual (Under Construction) |
Posted: Sat May 02, 2020 6:10 am Post subject: Re: Loss of all Automatic Gear Function |
pburkeame wrote: |
Sounds like we have different problems. If I find anything I’ll pass it on. |
. My issue was shearing of the oil pump driveshaft probably due to needle bearing failure at the end of the oil pump.
Oil pump looks okay after disassembly and turns easily, but I have other things to repair and check while I have the transmission apart. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sat Jun 20, 2020 6:29 pm Post subject: Re: Loss of all Automatic Gear Function- Repaired |
A big thanks to MarkWard and Kourt for their help and encouragement with me repairing our Automatic Trans.
I bought an end plate for the oil pump from Porsche to repair the gouges in it.
I had a needle bearing fall apart , it sits at the end of the nose on the pump assembly, to support clutch assemblies mounted there.
I then had to drill and install a helicoil for one of the pump bolts . It neatly pulled out threads as I was hand tightening it using a 1/4” hand ratchet.
I also needed a Sprag Clutch assembly, the plastic ring on mine kept breaking the more I tried to reassemble it.
Kourt sent me a spare, so that fixed that issue. While all of this was going on, the Torque Converter seal started to leak when I was moving the Vanagon around the lot at work, limping on the weak spare transmission I originally had to begin with. So that meant more Van Cafe parts to order before I could drop the whole transaxle and swap out the now rebuilt 2nd transmission that I finished in my basement.
Today was the day, Transaxle came out, TC seal replaced, Rear Main Engine Seal replaced , and transmission swapped out from the rear of the Transaxle.
New Converter bolts courtesy of McMaster Carr, rounded out the parts list.
Happy to say that Hilga is back on the road with all 3 speeds working and no more leaks .
Long Saga is over.....
Now on to all the other I need to do to the Vanagon... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sat Jun 20, 2020 6:32 pm Post subject: Re: Loss of all Automatic Gear Function- Repaired |
Can the mods change the title to reflect current status of this older post?
Thank you _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sun Jun 21, 2020 8:50 am Post subject: Re: Loss of all Automatic Gear Function: FIXED! |
Great to hear! Congratulations on a job well done. |
Posted: Sun Jun 21, 2020 9:01 am Post subject: Re: Loss of all Automatic Gear Function: FIXED! |
I was wondering? Did you by any chance trace the fluid path of the cooler when you had the pump out of the case? Mark _________________ ☮️ |
Posted: Sun Jun 21, 2020 9:28 am Post subject: Re: Loss of all Automatic Gear Function: FIXED! |
MarkWard wrote: |
I was wondering? Did you by any chance trace the fluid path of the cooler when you had the pump out of the case? Mark |
Upper port does appear to be feed back/return into the pump due to where the case hole lines up with the pump gears.
I’ll take a picture of the old Pump backing/face plate and post it , the wear marks on the plate from the pump, and where that upper hole and plate align will be good info for all of us. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sun Jun 21, 2020 7:23 pm Post subject: Re: Loss of all Automatic Gear Function: FIXED! |
Here you go Mark, the upper hole /cooler port is the return, as there is no way to build pressure with the gaping hole in the cover plate, and the fact that your driveshaft and drive button or ‘flower’ piece that is splined to the driveshaft are sitting out in the open, behind that big hole.
Pressure can only come out the bottom /port hole, I’m adding a few pictures. And yes, my cover plate was pretty messed up....
