shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Mar 17, 2020 5:08 pm Post subject: Motor mounts torque ratings - 1.9L |
I'm replacing the motor mounts on my 83.5 1.9L.
Bently says
engine mounts: 61ft lb
support member 33ft lb.
I just want to verify, but the engine mount to engine carrier bar is 61ft lb (the look like M10-ish). The 'support member' is the engine carrier bar to frame/body - they are M8.
Also the arrows on the engine carrier bar point towards the front of the van. I also hand tightened the motor mounts to engine carrier bar. I could not find toque values - but I'm pretty sure they are M8 sized as well.
Does all this sound correct? _________________ Brandon
Instagram @joannthevan |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Mar 17, 2020 5:51 pm Post subject: Re: Motor mounts torque ratings - 1.9L |
I’m sure the M8 bolts are a lot less. Somewhere around 18’ foot pounds. 10mm carrier bolts are also less. I’m thinking in the 44’ pound range. You can always find online torque tables for all hardware types _________________ ☮️ |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Mar 17, 2020 6:01 pm Post subject: Re: Motor mounts torque ratings - 1.9L |
MarkWard wrote: |
I’m sure the M8 bolts are a lot less. Somewhere around 18’ foot pounds. 10mm carrier bolts are also less. I’m thinking in the 44’ pound range. You can always find online torque tables for all hardware types |
Yeah a wicked rough general estimate is 10Nm for M6, 25 for M8 and 50 for M10
so it Ft Lbs -the M8 is 18 Ft-Lbs and the M10 is 36 Ft-Lbs, so your thoughts are indeed correct. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
