av8shunmeckaneck Samba Member
Posted: Tue Mar 17, 2020 11:37 pm Post subject: Tail light vent idea |
Thought of this idea the other night and mocked it up in CAD. Has anybody seen something like this? Was thinking if could work well to use one side as a cold air intake. I had one of the original lenses sitting in a precarious spot. Of course i bumped it and it broke. Lemme know what you think.
Posted: Wed Mar 18, 2020 10:38 am Post subject: Re: Tail light vent idea |
WHY? |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 776 Location: Milwaukee
Posted: Wed Mar 18, 2020 11:30 am Post subject: Re: Tail light vent idea |
That's on the SubaThing right?
Why not use the existing side intake?
I ask because, as I understand it, the Thing suffers from low pressure in the back. Could look cool tho. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Wed Mar 18, 2020 6:40 pm Post subject: Re: Tail light vent idea |
I have no idea if it would work well or not in practice, however I really like the "what if I tried this" mentality. That attitude is serving you well in this project so far. What the heck give it a try, I like it. |
Joe 20 Samba Member
Posted: Wed Mar 18, 2020 7:30 pm Post subject: Re: Tail light vent idea |
If you were putting in the European rear lights it might be a way to cover the old holes... |
Posted: Thu Mar 19, 2020 2:02 am Post subject: Re: Tail light vent idea |
Just an idea.
I understand that vehicles in general have a negative pressure at the back of the car. My worry about doing this would be the dust that would likely be sucked into through the vents.
Also not sure how much of a restriction this would be if I used one side as a cold air intake. My thought though is that the benefit of colder air would outweigh the negative pressure issue.
I think I may try to find a way to do it without modifying the outside of the car. Maybe an upward vented scoop. Similar to the picture but with the opening at the top. It would need a baffle inside to deflect the FOD away from the air filter.
jakokombi wrote: |
I ask because, as I understand it, the Thing suffers from low pressure in the back. Could look cool tho. |
Thingaru. Yes.
Joe 20 wrote: |
Been thinking about those too. There are some decent similarly shaped LED tail lights advertised for trailers too. |
KAmes Samba Member
Posted: Thu Mar 19, 2020 4:45 am Post subject: Re: Tail light vent idea |
How about the opening being to the side, so it appears adjacent to the existing vents? It does seem like it it would be easy to make a box that would simply bolt through the existing tail light holes, especially for someone with superior welding skills (I don't mean me ). |
Posted: Thu Mar 19, 2020 11:08 pm Post subject: Re: Tail light vent idea |
KAmes wrote: |
Like this? Did some more CAD. Think they would wrap around the side a little more, maybe end at the aft edge of the louvers but slanted fwd like the louvers.
KAmes Samba Member
Posted: Fri Mar 20, 2020 4:45 am Post subject: Re: Tail light vent idea |
Cool! I like the wrap around idea. The scoop would visually give a little hint to the sleeper aspect of the car. |
Posted: Sun Mar 29, 2020 1:20 am Post subject: Re: Tail light vent idea |
I ended up going a different route now that I've had a chance to drive it a bit. It's experimental still but a huge improvement over no scoops.
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Sun Mar 29, 2020 5:13 am Post subject: Re: Tail light vent idea |
There was an aftermarket air scoop like that back in the 80's.
_________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
