Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sat Mar 21, 2020 10:27 am Post subject: No more oil leaks! |
I pulled the engine and replaced the main seal, the oil cooler seals, the flywheel seal and I replaced the old and warped sump plate with a new one. In 35 years of VW ownership this is the first time I have ever had a bug that doesn't leak a single drop of oil! I didn't know this was possible !
_________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sat Mar 21, 2020 11:06 am Post subject: Re: No more oil leaks! |
Zylinderkopf wrote: |
Now you've jinxed yourself ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Mar 21, 2020 11:09 am Post subject: Re: No more oil leaks! |
You sure it didn't run out of oil _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
carcrazed Samba Member
Posted: Sat Mar 21, 2020 1:57 pm Post subject: Re: No more oil leaks! |
Give it a week or two. It will find a new way to leak oil. They all do and that is part of the charm _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Sat Mar 21, 2020 2:15 pm Post subject: Re: No more oil leaks! |
Old Vw's don't just leak oil.
They mark their spot! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
toxicavenger70 Samba Member
Posted: Sat Mar 21, 2020 2:58 pm Post subject: Re: No more oil leaks! |
I just did the same and no oil leak. But I do have a trans drip. |
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Sat Mar 21, 2020 5:41 pm Post subject: Re: No more oil leaks! |
Good job!
I did the same last fall and was leak free for about a month....until at least one push rod tube seal started to leak _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6616 Location: Houston, Texas
Posted: Sun Mar 22, 2020 7:34 am Post subject: Re: No more oil leaks! |
Wait until you start it up. That should get it flowing. _________________ www.vwnos.com [email protected]
gt1953 Samba Member
Posted: Sun Mar 22, 2020 7:40 am Post subject: Re: No more oil leaks! |
I will join in Give It Time. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Mar 24, 2020 8:54 am Post subject: Re: No more oil leaks! |
D'oh! -
This was too good to be true... a few drops leaking again. I think it may be the oil pump.
1966 Beetle 1300
1971 Super Beetle
1974 Thing
lboos Samba Member
Joined: November 20, 2015 Posts: 410 Location: Marietta GA.
Posted: Tue Mar 24, 2020 10:17 am Post subject: Re: No more oil leaks! |
deleted.
Cusser Samba Member
Posted: Tue Mar 24, 2020 11:40 am Post subject: Re: No more oil leaks! |
D'oh! -
This was too good to be true... a few drops leaking again. I think it may be the oil pump. |
You were warned !!!
Cusser wrote: |
Now you've jinxed yourself ! |
mukluk Samba Member
Posted: Tue Mar 24, 2020 12:28 pm Post subject: Re: No more oil leaks! |
D'oh! -
Might be the oil pump, but I'd lean toward the oil coming from the road draft tube and maybe the crank pulley. How's your blow by? _________________ 1960 Ragtop w/Semaphores "Inga" |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Zundfolge1432 Samba Member
Posted: Wed Mar 25, 2020 6:14 pm Post subject: Re: No more oil leaks! |
Wayne S. Johnson wrote: |
You need the Type 1 oil catch tray, it has an electric pump to return the oil back to the engine. |
No man you need a Toyota they don’t seem to leak much. |
AoxoMoxoA Samba Member
Posted: Thu Mar 26, 2020 7:12 am Post subject: Re: No more oil leaks! |
Note to self...
NEVER proclaim my engine to be leak free! _________________ '66 Beetle 1300 / Bahama Blue |
cyclehobby Samba Member
Joined: August 29, 2013 Posts: 156 Location: North Jersey
Posted: Thu Mar 26, 2020 9:30 am Post subject: Re: No more oil leaks! |
True words... My task with my 67 Beetle has been to MINIMIZE oil leaks and I've done pretty well so far.
Originally, I wanted to get LEAK FREE, but I had to give up that ghost and transition to where I am now.
I have an occasional drop or two from the sump plate but I'm happy enough with that knowing I got to that point NOT putting sealant on the mating parts or gaskets. This is a good thing to ease future oil changes. I simply cleaned everything thoroughly with brake clean, made sure my sump plate was flat (not dimpled) at the holes and carefully mated everything up. A drop or two every now and then, but I consider that JOB DONE!
I also used to have an occasional leak at my valve covers. Please don't hate me, but I got a set of SCAT stainless covers with bails that have the little tabs in them to keep the valve cover gasket in place. Again, being real clean (after adjusting my valves), I used good cork gaskets with a little, tiny bit of gasket sealant on the cover side only. Gasket in place, I located the covers to the clean head and locked the bails on. I can accurately say they don't leak a drop!!! Magic!!
I do also have a drop or two show up from the trans-axle, but It's not enough to worry about. That oil has been changed recently and all is well otherwise.
When I rebuilt the top end last winter, I also carefully sealed the cylinders to the case, I installed each pushrod tube with some sealant on the gaskets and I carefully removed, cleaned and reinstalled the oil pump using new gaskets and just a slight coating of sealant on the cover (so's not to jam up the working parts). Those areas were leakers prior to my rebuild and they're still dry today. Oh, and of course I replaced the oil cooler seals, but they weren't leaking before. Still dry there too.
Overall, based on the work I've done, I've been real happy with my minimally leaky VW. I rarely have to add any oil between changes, and if I do, it's really only to satisfy my obsession with keeping it filled, but not over-filled. I'm now comfortable with allowing it to leave a drop or two after a nice run and I am satisfied with it being slightly less than perfect.
Hey, we all leak a little. _________________ 1967 Beetle
Northern NJ |
