Selsk Samba Member
Posted: Mon Mar 23, 2020 3:03 pm Post subject: Micro warning light bulbs |
Does anyone know what they are called or where to buy new ones? The tiny pin style bulbs in the center of the cluster. Warning lights for the OXS, Oil, High beams, turn signals etc. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Selsk Samba Member
Posted: Mon Mar 23, 2020 3:19 pm Post subject: Re: Micro warning light bulbs |
Perfect thank you! |
Vanagon Nut Samba Member
Posted: Mon Mar 23, 2020 4:03 pm Post subject: Re: Micro warning light bulbs |
Maybe sitting around so much today has limited blood flow to my eyes but I'm not seeing the dash warning light bulbs in the van-cafe links.
@ the OP. If you buy aftermarket LED's (what other kind is there these days?), make sure they're not the type meant for flashlights and what not. Unless I got my resistor values incorrect, they're REALLY bright even with a resistor in series.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9264964&highlight=way+bright.#9264964
1988 West DIY 50º ABA
VE7TBN |
Timwhy Samba Member
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Mon Mar 23, 2020 5:15 pm Post subject: Re: Micro warning light bulbs |
Vanagon Nut wrote: |
Maybe sitting around so much today has limited blood flow to my eyes but I'm not seeing the dash warning light bulbs in the van-cafe links. |
Odd - it must be your eyes! They both worked just fine here.
You can navigate there yourself - go to the VC website, choose your year, and then it's 'Body Electrical'/'Instrument Cluster'. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon Mar 23, 2020 5:23 pm Post subject: Re: Micro warning light bulbs |
Selsk wrote: |
fxr: I might not be seeing them on the van-cafe page but I think Selsk is looking for the warning light bulbs? _________________ 1981 Westy DIY 15º ABA
VE7TBN |
valvecovergasket Samba Member
Posted: Mon Mar 23, 2020 5:47 pm Post subject: Re: Micro warning light bulbs |
fxr: I might not be seeing them on the van-cafe page but I think Selsk is looking for the warning light bulbs? |
im not seeing them on there either?
i only see the twist in bulbs for lighting the cluster area, not the warning lights.
(i need to buy a couple more warning LEDs myself) _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Mon Mar 23, 2020 6:03 pm Post subject: Re: Micro warning light bulbs |
Selsk wrote: |
They are all the same, just in different locations. GoWesty had them in Red, Blue and Green as well as the original white.
https://www.gowesty.com/product/bundles-and-kits/2...led-ic-?v=
I use the Red for the backlighting of the symbols instead of the white.
The LED's work nicely in daylight.
_________________ This free advice is worth exactly what you paid for it.
jimf909 Samba Member
Posted: Mon Mar 23, 2020 7:30 pm Post subject: Re: Micro warning light bulbs |
Selsk wrote: |
I read this as the OP is looking for the idiot light LEDs. All I see on the Van Cafe links provided the little incandescents used to illuminate the cluster.
But my brain is kinda soft now. _________________ - Jim
Abscate wrote: |
Posted: Mon Mar 23, 2020 7:43 pm Post subject: Re: Micro warning light bulbs |
jimf909 wrote: |
Selsk wrote: |
But my brain is kinda soft now. |
You should get a prize! You're right. too much cabin fever here! 😷😷😷
Here's the correct link:
https://www.vancafe.com/Vanagon-Bulbs-s/3285.htm _________________ This free advice is worth exactly what you paid for it.
Posted: Mon Mar 23, 2020 8:03 pm Post subject: Re: Micro warning light bulbs |
Thar she blows....
Steve M. wrote: |
jimf909 wrote: |
Selsk wrote: |
https://www.vancafe.com/Vanagon-Bulbs-s/3285.htm |
Abscate wrote: |
Posted: Mon Mar 23, 2020 8:07 pm Post subject: Re: Micro warning light bulbs |
jimf909 wrote: |
Thar she blows.... |
Sniff sniff...smells like a brain fart! 😂😂😂 _________________ This free advice is worth exactly what you paid for it.
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Tue Mar 24, 2020 12:14 am Post subject: Re: Micro warning light bulbs |
The indicator lights are standard 5mm LEDs which were common in the 80s, except the high beam indicator as blue LEDs were not available at that time. That is a small bulb. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Timwhy Samba Member
Selsk Samba Member
