KingAir42 Samba Member
Joined: May 24, 2002 Posts: 500 Location: Bakersfield
Posted: Mon Mar 23, 2020 7:03 pm Post subject: How far to go building a driver |
Just got a 62 bug I’m working on. This car will be a driver, not a show car. My main concern is paint, I have removed the fenders, hood, decklid, removed all seals from doors, wires etc. The plan is to paint the interior/exterior, as well as the trunk. I haven’t started sanding or prepping yet. I am not trying to impress anyone with the car, but I want it to look decent and not ghetto. I’m not sure where the line is between going full blown show car, or half assed prep and paint job. Any suggestions helping me find a happy balance ? |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Mon Mar 23, 2020 7:52 pm Post subject: Re: How far to go building a driver |
I would not paint it with a brush. |
mukluk Samba Member
Posted: Mon Mar 23, 2020 8:10 pm Post subject: Re: How far to go building a driver |
iowegian wrote: |
A roller, however, is fair game. _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Mar 23, 2020 8:13 pm Post subject: Re: How far to go building a driver |
Most of the expense in a paint job is the prep and assembly. You are doing that and saving big. I'd shop for a local paint shop to spray primer and color. Keep in mind since they didn't do the prep they may not offer much of a guarantee. |
Posted: Mon Mar 23, 2020 8:23 pm Post subject: Re: How far to go building a driver |
The trunk area for example, after the paint, I am going to use the trunk liners and cover most of it up anyways. I am wondering how someone building their car to drive vs building for show, would differ in their paint procedure ( trunk) |
Posted: Mon Mar 23, 2020 8:24 pm Post subject: Re: How far to go building a driver |
mukluk wrote: |
iowegian wrote: |
A roller, however, is fair game. |
I did the fuel tank with the roller, came out really nice. |
SoCal66Bug Samba Member
Joined: November 24, 2014 Posts: 7 Location: Southern California
Posted: Mon Mar 23, 2020 8:35 pm Post subject: Re: How far to go building a driver |
A friend of mine works in a very large dealership body shop here in SoCal. When it came time to paint his S-10 Blazer he prepped it and took it to a One-Day type shop to have it painted. It turned out great. His reasoning was that all that guy does all day is spray cars. Most of the work is in the prep. |
wayne1230cars Samba Member
Posted: Mon Mar 23, 2020 9:01 pm Post subject: Re: How far to go building a driver |
There are just so many variables here. Does it need rust repair? Certainly, as has already been suggested, doing disassembly, prep work and reassembly can save major dollars. Are you going to pull all the glass and reinstall with new seals? Masking the car is another important step.
Even then it will still cost you. You will have to decide if you want the underside of the trunk and deck lid painted and the door jams. Everything adds up. Ultimately it’s your call (and your wallets).Tough to pinpoint a cost. Good luck and post some pics. _________________ 1960 beetle
1970 beetle convertible |
Posted: Mon Mar 23, 2020 9:14 pm Post subject: Re: How far to go building a driver |
wayne1230cars wrote: |
Even then it will still cost you. You will have to decide if you want the underside of the trunk and deck lid painted and the door jams. Everything adds up. Ultimately it’s your call (and your wallets).Tough to pinpoint a cost. Good luck and post some pics. |
Ill post some pics tomorrow. The brake fluid reservoir area has some rust. Other than that, its pretty good. I am going to pull all the glass, but try to reuse the seals, they are in decent shape still. Underside of trunk and decklid will be painted. I am going to paint the car, now is the time to learn. Door jams too, I gutted the doors today, weather stripping on the door, window stripping, windows removed etc. It needs a new headliner, so that's coming out. Door panels are decent, so will reuse those. I am trying to reuse anything that's still functional. |
Danny604 Samba Member
Joined: October 09, 2019 Posts: 89 Location: Port Coquitlam BC Canada
Posted: Mon Mar 23, 2020 10:02 pm Post subject: Re: How far to go building a driver |
As said above the majority of the cost and the final outcome are in the prep assembly. With that being said, I painted a couple of motorcycle tanks a few years ago using rattle can off the shelf from home depot, then a 2 part spray can clear. I spent the time to get the prep work done and make it really smooth. Then a couple coats of primer, let it dry, wet sand it out to remove all orange peel and dust (I painted it in my backyard, outdoor). Then 2-3 coats of color (I did black), wet sand again. 2-3 more coats, wet sand again. Then the final 2 part clear, wet sanded again. Then I had to polish it, I did it by hand, but you would need a polisher. I had lots of time in my project for the multiple days of drying time between each stage, but with a spray gun and proper 2 part paint you wont have to worry about that. My thought was that with enough paint on the tank I could sand out the defects. It turned out excellent.
Depending on your ability. You could build a basic spray booth in a garage, buy or rent a spray gun, get the proper air supply parts, then just buy the materials. My brother bought all the materials to paint a bay window bus and I think he said it was about $1800 Canadian all said and done. I think you could probably get the car painted for less than $2k Canadian including the booth costs. |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Tue Mar 24, 2020 8:15 am Post subject: Re: How far to go building a driver |
I don’t think anyone is going to advise you to do a shabby or rushed job. If you’re pulling the windows and seals you are getting serious about doing a decent job.
Likely, if you took your time and did the finest job you are capable of, you would still wind up with some blemishes and imperfections that would prevent you from using the car as a ‘show car’. Guys who get very good results have built on experience and know how over years.
Have you ever painted a car before or done metal work on an old car? _________________ Plate of shrimp |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Tue Mar 24, 2020 8:30 am Post subject: Re: How far to go building a driver |
A $10,000 paint job & a $500 paint job are both destroyed by a door ding or stone chip. A daily driven car will see a lot more of the wear & tear, how pissed do you want to be when it happens? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Zundfolge1432 Samba Member
Posted: Tue Mar 24, 2020 8:32 am Post subject: Re: How far to go building a driver |
Rollers? Just buy some beer and take over to one of the hack shops like Earl Sheib or Maaco. You won’t pay much and you won’t get much. Win win. |
Posted: Tue Mar 24, 2020 8:51 am Post subject: Re: How far to go building a driver |
panicman wrote: |
Have you ever painted a car before or done metal work on an old car? |
Good point, my best effort would never be near a show finish. Never painted a car before, but I have done metal work. |
Posted: Tue Mar 24, 2020 12:19 pm Post subject: Re: How far to go building a driver |
Here where I’m at so far
aa390392 Samba Member
Posted: Tue Mar 24, 2020 12:39 pm Post subject: Re: How far to go building a driver |
Think your going about the right way, check forum paint and body to get good advise.
I have taking a few cars to Macco, if you prep it right, they do a good job..after all they paint 200 cars a week. the painters sometimes bring their own equipment, and seem to be conscientious about their work, get to know em a bit. If you mask that helps as well. I hope you pick an og vw color.
Good luck _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Tue Mar 24, 2020 4:17 pm Post subject: Re: How far to go building a driver |
Looks like you have a pretty good car to start with. I’ve always liked the anthracite colour.
To do a headliner you need to pull the side and rear windows. When I painted my ‘60, I replaced all the window seals including the chrome trim. A year later I decided to replace the vinyl headliner that the PO had installed with a correct mohair liner. It was easy to remove and reuse the one year old seals. Older seals might present more of a challenge especially with the trim insert.
Keep posting pics and keep us informed of your progress. _________________ 1960 beetle
Posted: Tue Mar 24, 2020 4:35 pm Post subject: Re: How far to go building a driver |
TDCTDI wrote: |
A $10,000 paint job & a $500 paint job are both destroyed by a door ding or stone chip. A daily driven car will see a lot more of the wear & tear, how pissed do you want to be when it happens? |
I am frustrated at the moment. I can paint it myself a non vw grey color, and disappointment most of you. Or I can prep it myself and pay to have it sprayed with the original ruby red ( which I don’t like ). The anthracite grey, I do like. I will worry a lot more about the paint if I have it sprayed by a painter vs doing it myself with the non vw grey color. |
Acab77 Samba Member
Joined: August 09, 2015 Posts: 104 Location: Edgwood, WA
Posted: Tue Mar 24, 2020 4:47 pm Post subject: Re: How far to go building a driver |
You should be able to order paint using the code and have it be a VW color, if that's the route you want to go. _________________ SOLD '67 Beetle, "Rose"
SOLD '71 Super Beetle
'64.5 Ford Mustang
'67 Datsun Roadster
'72 Chevy LUV |
67ctbug Samba Member
Posted: Tue Mar 24, 2020 5:01 pm Post subject: Re: How far to go building a driver |
I can say in 99% confidence, that that car was never ruby red. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
